Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
  • rustinjust
    • Jun 2022
    • 49
    • England
    My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
    The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
    It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
    I have to turn the tv off and then on again with the remote in order for me to get out of it being stuck on a channel.
    Question it likely a faulty component in the tv causing this ? And which component ?
    Any good advice appreciated
  • nomoresonys
    • 12206
    • U.S.
    Re: Advice needed- Tv works but then sticks on a channel and won't change channels ok
    Did you try changing channels with the tv buttons?
    • rustinjust
      • Jun 2022
      • 49
      • England
      I just tried it on the tv itself and it won’t change channels once it stays only on one channel. The tv when I first turn it on will change channels on the remote or on the tv itself for a while but after a while such as 5 or 10 mins it won’t change channels. The volume button on the remote will still work even if it won’t change channels.
      Sometimes after pressing the changing channels button it will change channels a long time later and other times not at all. What’s the likely problem? A bad capacitor or another component?
      Also, earlier before it wouldn’t change channels but then I pressed the up and down button lots of times on the remote and it moved but the screen went black/blank, then I pressed the standby button to reset it and the light on tv flashed blue and flashed on and off for around 20 times or so then it stopped on solid blue which is the colour it goes to when it’s working ok. Only when it stopped blinking on and off was I able to turn the tv on again with the remote.
      Tv is a Technika Lcd 32- 207
      Also…. Would this board help fix the problem ? https://www.ebay.co.uk/itm/324304452175
      • nomoresonys
        • 12206
        • U.S.
        might not help but try a simple reset, unplug tv for 5 minutes, hold power button in on tv for 30 seconds then plug tv back in and try it. An update might help.
        • EazyBone
          • Jun 2023
          • 1341
          • United states
          Use remote. Turn camera on smart phone and face it at the top of the remote, hit the buttons on remote and camera will pick up infrared flash if the channel buttons are working on remote. I know you said tv buttons also but maybe they both not working.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4337
            • Italy - Milan
            obviously it is not there the problem, there must be a problem in the standby software or main software, since you are not a tech i suggest you to carry it to a service center to reprogram it..
            second possible chance is bad soc soldering..
            • rustinjust
              • Jun 2022
              • 49
              • England
              I have already tried that last week, didn't fix it.
              • rustinjust
                • Jun 2022
                • 49
                • England
                The remote does change channels sometimes, for maybe 5 or 10 minutes after I’ve first turned the tv on, which is why I think the issue is with a component inside the tv itself rather than a remote control problem.
                Also I’m iunsure what you mean by turn my phone camera on, do you mean put my phone camera on to video mode to pick up the infrared from the remote? If so I don’t think the remote is the issue as it changes channels just fine at first for a while, then it will stick on one channel and won’t change channels. I’m thinking a bad cap or comoonebt
                Another question after you’ve read the above information would this board likely fix the problem if I bought it? Which board on my tv, link here to board https://www.ebay.co.uk/itm/324304452175
                • rustinjust
                  • Jun 2022
                  • 49
                  • England
                  Continuing on from more information above, would this board fix the issue
                  https://www.ebay.co.uk/itm/263267032623
                  • nomoresonys
                    • 12206
                    • U.S.
                    So you want to buy a new board before trying a simple update.
                    • Diah
                      • Feb 2013
                      • 6376
                      yours TV used Vestel mainboards
                      you can try to log in service menu and from there do hard reset to reset yours TV as new..
                      service menu of vestel pressing menu on RC followed with 4 , 7 , 2 , 5 .
                      if didnt work google after vestel service menu
                      • yokoono
                        • Apr 2010
                        • 486
                        MENU, 4725, Diagnostic, Factory reset, OK.
                        • rustinjust
                          • Jun 2022
                          • 49
                          • England
                          What simple update? How?
                          • rustinjust
                            • Jun 2022
                            • 49
                            • England
                            I got in to the service menu and pressed factory reset, it then said press green so I pressed green button and tv went in to standby. Now tvs back on. Hopefully this will fix it. I’ll keep you all posted
                            • EazyBone
                              • Jun 2023
                              • 1341
                              • United states
                              The remote does change channels sometimes, for maybe 5 or 10 minutes after I've first turned the tv on, which is why I think the issue is with a component inside the tv itself rather than a remote control problem.
                              Also I'm iunsure what you mean by turn my phone camera on, do you mean put my phone camera on to video mode to pick up the infrared from the remote? If so I don't think the remote is the issue as it changes channels just fine at first for a while, then it will stick on one channel and won't change channels. I'm thinking a bad cap or comoonebt
                              Another question after you've read the above information would this board likely fix the problem if I bought it? Which board on my tv, link here to board https://www.ebay.co.uk/itm/324304452175
                              I mean turn your camera on like to photo, and just point it at the top of the remote. It will show a flash on your remote every time you hit a button. If it isn't flashing then that's the issue. Simple to rule that out, it probably isn't but is good to check
                              • rustinjust
                                • Jun 2022
                                • 49
                                • England
                                Update: I tried that and it hasn't worked. If I buy a main board will that fix the issue?
                                • rustinjust
                                  • Jun 2022
                                  • 49
                                  • England
                                  Question: would a replacement main board fix the issue or is it one of the other boards inside the tv with the fault? Which capacitor/component is responsible for changing channels?
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4337
                                    • Italy - Milan
                                    replace main board
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      this is a t con board and not the mainboard the mainboard is the one with hdmi/tuner on etc make sure all numbers on replacement board matches your old one.
                                      (board should look like this) https://www.ebay.co.uk/itm/264916707...4aAhIkEALw_wcB
                                      • rustinjust
                                        • Jun 2022
                                        • 49
                                        • England
                                        There is also this main board without the small board attached on a wire that’s in the link you sent https://www.ebay.co.uk/itm/263267032623
                                        I’ll get the one that matches the number on my board cheers
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                        • mikey5791
                                          Help on car amplifier only one channel works
                                          by mikey5791
                                          Hi all forum members,
                                          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                          08-06-2025, 10:36 PM
                                        • Camarada78
                                          Carvin PA620 shutting down
                                          by Camarada78
                                          I have a Carvin PA620 powered mixer with a weird problem: channel one shuts down the entire speaker output when plugged in. Its not a short because it still outputs sound through the line outs.
                                          1. voltages are somewhat correct (-42/+42, -26, -17/+17, when it should be +-43, -24, +-18).
                                          2. Channel 2 if plugged works normally, no issues, any volume.
                                          3. Channel 1 if plugged very low volume, works normally. if goes a little louder, it shuts down everything (both speaker channels)
                                          4. line out works normally in any situation, even after shutting down the speakers.
                                          10-15-2024, 12:07 PM
                                        • dicky96
                                          American Audio VLP1500 Distorting on one channel
                                          by dicky96
                                          Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                                          Protection and Clip LED are off
                                          There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                                          I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                                          The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                                          07-13-2022, 05:25 AM
                                        • dicky96
                                          I need to block a UHF channel but not sure how to do it
                                          by dicky96
                                          Hi guys
                                          I couldn't really find a section on the forum for this question so I guess I will put it here
                                          I do a lot of work in one of the local apartment hotels (an apart-hotel they call them here)
                                          Mostly I am maintaining the equipment in the 'TV' room or at the pool bar
                                          Anyway, I have a problem with the system in the TV room - most of this was a system I 'inherited' off the previous technician who no longer lives on the island
                                          Basically they have (see pic it probably explains it better) the following system. The UHF cabling is daisy chained...
                                          01-31-2022, 05:24 AM
