Vizio e65-f0 oddity
    • 12094
    • U.S.
    Re: Vizio e65-f0 oddity
    Thinking that you should be able to test powerboard as stand alone and get the backlights to come on, if someone knows why it would not, enlighten us, have not dealt with this exact model, can you get a focused picture of all 4 of the legends by the connectors on the powerboard?
    • EazyBone
      • Jun 2023
      • 1306
      • United states
      Check out first post, they are there
        • 12094
        • U.S.
        Yep, there they are, I forgot what the 5V SW pin is for, don't know if it has to be jumped to get the backlights to come on in stand alone test or not, maybe Diah can help, he's pretty good at the stand alone testing.
        • EazyBone
          • Jun 2023
          • 1306
          • United states
          Don't know. It's not connected to any wire, for some reason it's just 5V
            • 12094
            • U.S.
            Any progress on this one?
            • EazyBone
              • Jun 2023
              • 1306
              • United states
              #26
              I actually lost my cat, then got all discombobulated and then found him and decided to.put one down for a second and pick up the Sony with backlight issues, and I think I found the problem. But I don't know how to solve it. Over to that thread!! I'll get back to this later lol
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • Iain P
                Vizio E65-F0 really dead
                by Iain P
                Hi everybody!
                I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
                So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
                I decided to check the voltages coming off the power supply they are as follows:
                connector CN201
                pin 1 (18vsb1)...
                02-23-2023, 11:32 AM
              • howardc64
                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                by howardc64
                Failure Symptom
                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                Where is the short?
                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                05-27-2025, 02:56 PM
              • howardc64
                Vizio SmartCast TV software bug that looks like hardware
                by howardc64
                Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                11-16-2024, 05:17 PM
