[Help] LG 49LH570T Random Shutdowns
  • manubali
    • Feb 2017
    • 23
    • New Zealand
    Hi, i was wondering if anyone can help me troubleshoot LG 49LH570T tv, initially it came for no power issue, but after leaving everything unplugged overnight, it started working in the morning when i was about to start diagnostics process.
    It will turn on for 10 minutes and will die afterwards, and when i try to turn it on, a solid red LED will come up for few seconds, followed by two short blinks and then it completely shutdown, i have examined power supply and main board for visible damage or shorts, but its all fine.
    The power supply PCB number is EAX66851401 REV 1.0.
    One thing that i have noticed is that PSU makes hissing noise constantly
  • Storyteller12
    • Jun 2020
    • 625
    Re: [Help] LG 49LH570T Random Shutdowns
    Sounds like the caps may be bad. You can try heating them with a hair dryer next time it won’t turn on and see if it works Or if you have esr tester
      • 12241
      • U.S.
      Look over the solder joints of powerboard very closely, reflow any that look suspect just in case, can search bad solder joints to see images if needed.
        • 12241
        • U.S.
        Originally posted by Storyteller12
        Sounds like the caps may be bad. You can try heating them with a hair dryer next time it won't turn on and see if it works Or if you have esr tester
        +10, heat m up see if tv stays on longer.
        • manubali
          • Feb 2017
          • 23
          • New Zealand
          Fixed, After checking for cold/broken solder joints and hair dryer method, i focused on main board, and reflowing XD engine (LGE2111A-T8) BGA chip fixed the issue.
          Thanks everyone.
            • 12241
            • U.S.
            Glasd to hear it, if you can get a fan blowing on your bga it will last a lot longer.
            • h0m3w0rk
              Random Shutdowns/Startup Failure with Corsair SFX 450
              by h0m3w0rk
              I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
              For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
              02-09-2025, 03:19 AM
            • EvazX
              ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
              by EvazX
              I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
              Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
              For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
              However, after some time, the replacement motherboard...
              08-25-2025, 06:09 PM
            • Lisa Su
              Samsung P2250W Hissing (Newbie)
              by Lisa Su
              I've been using this monitor for last few years.
              Symptom started by OSD menu popping on and off randomly by itself. So i tried to clean the touch control area with some cloth but it didn't help.
              After 20 minutes monitor started hissing from the back. And then 30-40 seconds later screen started fade off/on like as if i was turning down the brightness that's when i turned it off by power button (hissing stops) and replaced it with spare monitor.
              Today i opened up the monitor, excited to repair my first monitor (or big electronics) hoping it's a bad...
              03-07-2022, 05:58 AM
            • N3Star
              Acer Aspire Series 1300 random shutdowns
              by N3Star
              I have a retro laptop in which I have replaced entire upper body as damaged were CCFLs, new screen is the bigger version (15" vs. 14.1"). The laptop now has trouble going beyond POST screen or even staying in BIOS, it seems like it entirely cuts off power (as in videos). Earlier, it sometimes booted into Windows, but smallest load would shut it down, also Aida reported CPU temperature as 2 degrees celsius. In the schematics I can see LCDID1 line that differ when changing LCDs, but going back to the damaged screen doesn't change anything. I will be grateful for any tips...
              05-12-2021, 12:44 PM
            • Prosatanosz
              Asus B85M-GAMER no hdmi output and random restarts
              by Prosatanosz
              Hi!
              Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
              10-19-2024, 05:27 AM
