Lg 65uh5500
  • EazyBone
    • Jun 2023
    • 1350
    • United states
    Lg 65uh5500
    So ran into this problem similar to the link I'm showing. Just wanted a reference for someone else If they ran across it. Good luck!
    https://www.badcaps.net/forum/showth...ghlight=Uh5500
    This is a old thread but I picked up a TV with almost exact symptoms. Has no voltage to TCON either. Led tester showed all backlights working. Decided I probably wasn't going to buy a new main board but was unsure. Decided to reflow the main chip on the main board for shits and giggles and TV turned on again. So verified main board. Unsure if it will stay working but for the symptoms it was main board issue.
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
