Panasonic TH-55AS670A no picture no sound
  • mar1in
    • Sep 2023
    • 28
    Re: Panasonic TH-55AS670A no picture no sound
    i was just wondering, should there be a clicking sound (for a relay ?) when you turn on the TV, because this one seems to be doing no clicking.
    Just realised, because I had a look at a similar model of Panasonic the other day and there was a clicking sound once turned on.
    That would indicate a problem with the power supply board, but in my case I measured most of the test points with valid voltages.
    If I understand it correct, it could be something with the LED driver that is also on that same board?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4309
      • Italy - Milan
      Hi, the standby software and diagnostics can be tricked by a not working power rail, check ic5300 pin 2,3,7 on A board
      • mar1in
        • Sep 2023
        • 28
        ok that's interesting, how would I do this, using a jumper wire ?
        • mar1in
          • Sep 2023
          • 28
          i've just measured the pins of IC5300, see image attached.
          doesn't matter if TV is in standby or turned on, there is only 16V on one pin, the others are all 0V.
          does that indicate a fauly IC ?
          the other IC8705 has Voltages (from 0.8V to 120V) on almost every pin except one.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4309
            • Italy - Milan
            unfortunately it lacks of enable signal so it is not faulty that chip but probably there are problems in software, the other ic cannot have 120v, are you kidding? Check the meter battery.
            • mar1in
              • Sep 2023
              • 28
              ok, there is no easy fix for a hobbyiest like me i guess.
              i have to measure again but i think the multimeter showed something above 100V on two pins, 16V and 5V and 1V and 0.8V on the others
              • mar1in
                • Sep 2023
                • 28
                at this stage the best i can do IMO is to look for a spare mainboard
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4309
                  • Italy - Milan
                  #28
                  for the research i made seems 13 blinks are a communication problem (emergency sos) between ic5000 and ic8000 (cpu), since my schematic is for a similar model but the writings are blurred, wait buying a new board, maybe i find something..
                  it seems ic5000 provides reset signal to cpu
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4309
                    • Italy - Milan
                    #29
                    i found the correct serv. manual and sharp images schematic, so try to check IC5000 pins 1,2,6,8,14,31,32, it is defective or it detects a problem on the sub tensions and shuts all things, comprised the CPU via reset signal.. check well also usb and hdmi connectors with lens, a bent pin can cause all this..
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                      by sam_sam_sam
                      After all of...
                      07-13-2024, 08:14 PM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • slimmy182
                      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                      by slimmy182
                      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                      Looking on google I found this:...
                      01-14-2023, 11:55 AM
