Re: Hisense H6750G stumped on this
105V by LED tester sound to me not good.... how about when you start the tv did you have any up and down V, u need to put the probe in place then turn on
BTW STB 2.6V very low
so you need to do the first test and second leave the PSU alone with out MB connected and check V on the its socket we want to know STB
Check XP901, voltage on the BRI pin, check it in standby then power on tv, what voltage do you get in both situations?Leave a comment:
Picked up another free one. The original owner replaced power board to try and fix them gave up gave to me
Problem: Red led standby light blinks once every 5 seconds repeatedly for ever.power button does nothing. Nothing turns on.
PSU, 12v are all 12v to main, 18v are all 16.6 stby is 2.6
Disconnect main and 12v is 10.5 and 18v become 14.4.
This is the same for BOTH psus.
Backlight tester turns on backlights at 105v each strand and work properly.
I cannot get ANY voltage to backlights on either power supply. They remain zero always.
I am stumped. I put pictures. Is there any way to jump this on or does anyone have any insight. The main is getting some voltages as it should.
Does the main tell the PSU to turn on backlight voltages? Should I have some sort of voltages at the PSU for LEDs? Help lol
Also thanks everyone whose been helping me! I've fixed many many tvs now and it's going great 👍👍👍💯💯💯Tags: None
Hello
Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v... -
by cheeky2I suppose the real question is whether the existing pinouts from ether a 17IPS71 psu are cross compatible with a 17IPS12 psu? If they are then the exchange of the main boards should have no issues providing the screen is compatible with both main boards. Obviously you can change the screen configurations easily enough (providing you have the correct files) for the main board. Why may you ask would I do this? Well a lot of the smart features are no longer working on a Hitachi 48HBT62U main board I wish to give it a new lease of life!
Obviously the same LVDS connector for the screen connection... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by BadCapexHi,
I am yet another unfortunate owner of a 65H6570F with a main board that failed due to an inherent flaw with the eMMC.
Reference: https://www.badcaps.net/forum/showthread.php?t=117406
The exact replacement board for a 65H6570 model TV is RSAG7.820.8831/ROH (aka 265223, aka 244991). It is very rare or expensive ($150+) to purchase currently and arguably not worth it if they're all just ticking time bombs.
A very similar board was identified in the above referenced thread, RSAG7.820.10315/ROH. It is more reliable, cheap, plentiful, and... -
by LemoneyFHi all
I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
I have tested the power supply and found the following:
363V and 373V across the input caps
bri- 0V
ana- 0V
vamp-17.03V
vamp-17.03V
stb- 0V
12V- 9.3V
12V- 9.3V
To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v... - Loading...
