Vizio Flex Cable / Address Bar Repair
  • Grasshopper2Ant
    • Jul 2023
    • 15
    Vizio V755-G4 LED
    Doing backlight LED strips replace. All good till I decided to clean the screen with the address bar taped to screen.
    I accidentally dislodged the flex cable on the LED screen.
    I was choked after reading it was a pain to repair.
    Anyone out there have a solution for a layman without a bonding machine.
    I saw a square heating attachment to solder iron but have no idea where to get it.
    Any suggestions appreciated.
    I was so close to getting this damn thing assembled.
  • Grasshopper2Ant
    • Jul 2023
    • 15
    Re: Vizio Flex Cable / Address Bar Repair
    Here is the flex cable that I tore off.
    • diif
      • Feb 2014
      • 6978
      • England
      It looks like one side came off clean but it tore the the other side ?
      • Grasshopper2Ant
        • Jul 2023
        • 15
        Sorry for the bad pic. It tore off clean. The flex ribbon is in tact.
        After some reading, I have to use ACT remover (G-450 product) to remove the film on the traces.
        Does any know what I can use as a sustitute. Would acetone work as it is more readily available or any other
        Is this pic any better?
        • Prott
          Soldering flex cable - tips & tricks
          by Prott
          Hello fellow badcappers,
          I have to solder a MacBook (A1708) screen flex - one of the two data flexes got slightly torn (2 broken traces). I've seen some videos on youtube where people scrub the coating and then simply apply flux and solder to the exposed copper traces (and then run a jumper wire). However no matter what I try the copper does not take the solder at all - the more flux I add the more it actually stays only on the iron itself.
          I am practicing on a spare flex cable and it's gettiing quite annoying - to a point I am actually thinking I have to be doing something...
          10-04-2023, 06:25 AM
        • SeaglassPearl
          Vizio E420VA 5v drops to 3v when power cable is connected
          by SeaglassPearl
          Folks, I have a Vizio flat screen that doesn't show any signs of life (and no orange vizio glow either).
          I tested the voltages from the power board (at the connector) and I can see the 5V supply drops to 3V after the power cable is connected to the main board (5V supply reads as 5V when cable is disconnected from main board). All other rails (12V and 24V) are reading fine.
          I looked for the usual bloated caps and saw none on either board and no other tell-tall signs (black marks, burned components, etc) on either side of both boards.
          Given the 5V rail...
          12-30-2022, 05:55 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
          Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
          This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
          09-07-2024, 07:20 AM
          09-07-2024, 06:38 AM
