Philips 42PFP5332D/37 Plasma HDTV black screen
  • Mishannya
    Badcaps Junior
    • Sep 2010
    • 31
    I have defective Philips 42PFP5332D/37 Plasma HDTV about three years old.
    TV turns on, turn of, has good sound, switches channels etc... except one thing - No Picture at all. The scree remains BLACK all the time. Anyone had the similar issue or have any ideas?
    Any advice is warmly welcome!
    Best regards. Mike <--------------
  • PlainBill
    • Feb 2009
    • 7034
    Re: Philips 42PFP5332D/37 Plasma HDTV black screen
    The best advice is to be very careful - plasma TVs pack a bite. This MIGHT be a Y-Sustain problem. Or it might be something else.
    A parts list is available at Electrotanya. The service manual for the chassis is also there.
    The general troubleshooting process is simple. Pull the back off the set. Center bottom is the Small Signal Board (SSB).
    Above the SSB is the main power supply. On the back of the panel itself is a label with various voltages listed. Va Vsc, etc. You will see bundles of heavy wires running to the Y-Sustain (to your left as you stand behind the TV) and the X / Z Sustain (to your right). Turn on the TV and check for these voltages either at the power supply or at the sustain boards - the connectors should be labeled. Again, note these voltages - 200 VDC at 2 amps will light up your life, so care is recommended.
    If all voltages are present and correct, turn off the TV, unplug it, and wait 5 minutes. There should be several fuses on both the Y -Sustain and X/Z Sustain. Check them for continuity.
    If any of the voltages are missing or incorrect (off by more than 10%), turn off the TV, wait 5 minutes, then unplug the wire bundle from the X/Z sustain. Plug in the TV, turn it on, and recheck. If the voltages are now correct, the X/Z Sustain was the problem.
    If the voltages are still incorrect, turn the TV off, unplug it, wait 5 minutes and reconnect the wire bundle to the X/Z Sustain card. Now disconnect the wire bundle from the Y-Sustain card, hook up the power cord, turn the TV on, and recheck the voltages. If the voltages are now correct, the problem is the Y-Sustain.
    If all voltages are correct, and all fuses are good, you have a problem. I suggest taking an over-all picture of the TV from the back. Somewhere on the plasma panel should be a label giving the model number of the panel - not of the TV.
    Whoops!! You have the S42AX-YD02 plasma panel. Search for the service manual for that. It has a lot of information.
    PlainBill
    • Mishannya
      Badcaps Junior
      • Sep 2010
      • 31
      Voltage readings on SN8006 & SN8007 is :
      Vg - 15.0V
      Vscan - -187.6V
      Vset - 195.4V
      Vs - 199.7V
      All fuses are O.k, I cant see "Vg" on the label with voltages. Also I attached two images, one of label with various voltages listed and second of connector. Please take a look at them. Thx.
      • PlainBill
        • Feb 2009
        • 7034
        Vg - 15.0V
        Vscan - -187.6V
        Vset - 195.4V
        Vs - 199.7V
        If you haven't already done so, download the panel service manual. They cover troubleshooting the panel, sustain and main control card. Note: IIRC, the second manual is the prefered one. The first one is in Spanish.
        One test that can be done is putting the main control card into a test mode. This eliminates the SSB and the cable from the SSB to the main control card.
        PlainBill
        • celiabrown
          Issue with Plasma Philips 37inch chassis FTL2.1
          by celiabrown
          Hello guys,
          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
          Can someone has any symptom like this ?
          Thanks​
          05-09-2024, 10:56 PM
        • KYBOSH
          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
          by KYBOSH
          Saved this beast from the landfill this weekend.
          Manfactured July 2013 in Mexico.
          I love working on plasma TVs.
          Its been a while but I was lucky enough to find 2 this week.
          The TV powers on and stays on but no picture. Havent checked for sound yet.
          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
          Will start troubleshooting tonight.
          10-17-2024, 01:17 PM
        • Spork Schivago
          Questions about Plasma voltages (PN60E530A3FXZA)
          by Spork Schivago
          Hi!
          I am working on a Samsung PN60E530A3FXZA and had some questions. The power supply looked pretty bad. There where heavy burn marks on the two thermistors and all the traces on the cold side from the larger transformer. For the larger transformer, there was discoluration on some of the traces for the hot side as well.
          I have seen other SMPS's for this panel that looked similar and replacing the thermistors did not fix the issue. The thermistors readed short circuit.
          Anyway, replacing the SMPS wasn't too expensive and I did along with the Y-Sustain board,...
          03-08-2019, 07:41 PM
        • alro7779
          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
          by alro7779
          Hello, guys!
          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
          09-14-2025, 12:25 AM
        • G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
          by G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
          It does power up when pressing the power button.
          I already try the power button while plugin the plug with no result.
          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
          Could this be an PSU or eMMC issue ?
          07-19-2025, 03:43 AM
