sony kdl-40v2500 no picture
  • jasonssony
    • Sep 2010
    my sony bravia 40" has no picture. it turns on, green light power stays on, no flashing code that i can see, just solid green. sound still works, and i can change the channel and hear it in "the background". i blindly switched video inputs to a known live feed, and heard and paused its playback, confirming that everything else but the video screen is working on my tv. where do i start? ive been searching this forum, and found a thread where replacing the t-conn worked for him, but in the same thread, a visitor mentioned it didn't work. how do i start this project?
    researched link..
    https://www.badcaps.net/forum/showthread.php?t=8606
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: sony kdl-40v2500 no picture
    Well other than researching the threads as you did.... maybe taking a look inside and posting picture of the boards.
    • CyberPhoenix
      Issue with picture quality of Sony bravia TV
      by CyberPhoenix
      Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
      01-22-2024, 02:08 AM
    • noisykid
      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
      by noisykid
      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
      12-30-2024, 07:15 PM
    • iglitare
      Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
      by iglitare
      i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
      Backlight seems to work, Sound (Setup menu after reset) works.
      If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
      Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
      With my small knowledge i would think at least the cables are good.
      Can this happen because of a bad tcon board?
      Or is it always a bad/shorted...
      09-04-2025, 07:13 AM
    • tree5656
      diagnosing sony XBR-75X900H. NO PICTURE
      by tree5656
      This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
      11-09-2023, 04:55 PM
    • DKWS89
      Sony XBR 49x900E - Sound and backlight on but no picture
      by DKWS89
      Hey Guys,
      So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
      All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
      12-14-2023, 04:30 PM
