Samsung UN75RU7200FXZA - Right 1/3 Portion of Screen Dark
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Set from 2019.....sad this is all they last anymore. Ok, obviously a backlight problem. From what I understand there are 3 strips in these, mounted vertically....one seems to be bad. The image is present behind the darkness, not a LVDS or TCON issue.
    This TV is a beast. I can't even manhandle it by myself, let alone try and lift the screen out to restrip it.....but I haven't even gotten this far yet....I can't seem to find strips for it.
    I found a set for the UN75RU7100FXZA but not the 7200.
    https://www.shopjimmy.com/samsung-bn...strips-bars-3/
    Knowing samsung, they're not interchangeable.... I never thought I'd see the day I'd scrap a 75" TV over something so trivial....but without parts, it's scrap.... Any insight as to whether the above strips would be compatible? If not, anyone know of someplace that may have them?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • R_J
    • 9610
    Re: Samsung UN75RU7200FXZA - Right 1/3 Portion of Screen Dark
    It is possible that there is a bad connection on the led section, bad connection on one led on the strip or maybe one led only is defective, just a guess.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      I take it the link you edited out was not compatible?
      Team : 49813
      Join in!!
      Team Stats
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        • ducky29
          • Dec 2015
          • 369
          • Europe
          Yes those strips are compatible but there are cheaper alternatives if you search on Ali.
          Also check the light sheet guide if its damaged or not.
          You should replace them both in case its damaged.
          • Storyteller12
            • Jun 2020
            • 625
            Just did one of these. There’s 3 strips total so need to replace all 3. As Ducky29 mentioned, I would open it up before ordering to confirm the diffuser isn’t cracked. A lot of times they melt/ crack on these models when the backlights go out. If you do replace the lights make sure to turn the backlight down as much as possible to prevent this from happening again
            • R_J
              • 9610
              I think it likely was, but after a closer look it did not list that exact model, so I deleted it, other sites seem to confirm that is the same part used in those other models.
              This was the Amazon link for $28.00; https://www.amazon.com/Replacement-U.../dp/B09B6RVDMV
              $20.00 from aliExpress https://www.aliexpress.com/i/4001120...yAdapt=glo2isr
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                Thanks for the info. I have not taken this apart, I'll have to get an extra set of hands for this one, its just too girthy for one guy unless you have a 7ft arm span...
                FWIW, it did have a mild abrasion on the screen that would not rub out with simple cleaners.
                I used some nifty stuff called Novus. This took it out to the point I can't even tell where it was. Perfect restoration; can't be seen with the screen on or off. I'll post an after pic when I have a little time. ON a matte screen, it will leave a shiny spot....but on a shiny screen, it disappears completely. No marks at all.
                Team : 49813
                Join in!!
                Team Stats
                • Diah
                  • Feb 2013
                  • 6501
                  you don't have faulty LED.. its issue with strips socket..
                  RU strips are 4 in total each build from 3 pieces clipped together via easy metals pin plug in if the panel / chassis get wrong mounted or forced to be curve shape as it its thin design the clips will get losses.
                  you have the left side all dark.. mean one line of this contact got lost
                  sdit: the one i have 2 set new for GU 75 not RU
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    Are they accessible from the rear; IE the panel doesn't have to be disassembled? I am not looking forward to dismantling this panel. The largest I've done is a 70 (by myself), and it was a real joy.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • howardc64
                      • Jun 2017
                      • 653
                      I've done 2x 75" backlight recently (LG & HiSense) There are some unique challenges for such a large screen.
                      - 4x 2-1/4" suction cups removed it easily and securely with 2 people. Just have a flat surface close by to minimize transfer distance.
                      - Chassis can flex. Ideally have a bunch of spacers to make sure the chassis is nice a flat. If just lay on a hard surface, wall mount studs will push up the metal. I did it on a mattress which keeps it reasonably flat. Probably stripes of 2x4s and some spacers for the wall mount studs would be helpful to keep it flat. This becomes an issue depending on how the backlight and reflector paper is secured onto the chassis tub. I had particular problems with the HiSense and had to make the tub flat and even to avoid LED light bright spots from chassis bowing too much (very shallow tub, double sided sticky tape to secure reflector paper)
                      • Diah
                        • Feb 2013
                        • 6501
                        panel should disassembled. the problem with Samsung U panel are so thin like onion shale , if one person do the job the risk are high.
                        • NWArkGuy
                          • Jul 2023
                          • 5
                          I have the same model of TV with a similar issue. Instead of the right hand side, the center is dark on mine. I found the TV on my local Craigslist for free because the former owner didnt want to spend the $$$ to fix it.
                          I am techy enough to try to replace the backlight in this. This will be my first attempt to do so ever. I know that I will have to take apart the screen to get to the backlights; but, is there a video or walkthrough somewhere that could walk me through this?
                          Also, I would like to confirm that these parts are correct for this panel...
                          • Chrissygizmo
                            by Chrissygizmo
                            02-10-2025, 12:33 AM
                          • Chrissygizmo
                            samsung galaxy ao2s very temperamental after screen replaced
                            by Chrissygizmo
                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                            Ive eventually managed to get it on and working but it's very temperamental...
                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                            05-26-2024, 12:05 AM
                          • JunkmanJimbo
                            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                            by JunkmanJimbo
                            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                            Please help. Thanks in advance!
                            08-12-2025, 11:45 AM
                          • Kiberge
                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                            by Kiberge
                            HI guys!
                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                            04-22-2024, 11:28 AM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
