LG OLED65C9PUA post Windex repair?
  • Expunge
    • May 2023
    Hey,
    A few months ago I had an issue with my C9 OLED involving some Windex in the screen. I sprayed some contact cleaner into the panel and noticed an immediate difference in the picture. I set the TV flat on a table and took it apart and sprayed some more into the panel from the back side of the TV and after waiting a few hours I tried turning it on and I got a perfect picture! I reassembled the TV and set it up and got a brief green-ish flash before it powered off again.
    I did some googling and looked around for some other things to check and here's what I tried/noticed:
    - Noticed some residue along the seam on the bottom of the panel. I sprayed some cleaner in it to clean it up, and more contact cleaner in the panel itself. This made no difference.
    - Visually inspected all boards and disconnected/reconnected all connections. Didn't notice any problems.
    - Power reset multiple times between everything I tried. No difference.
    - Inspected the screen itself. I didn't notice any cracks or damage on it. I used a bright flashlight and covered every inch.
    - After letting it sit for a few days I went through everything again and the TV managed to produce what appears to be a perfect picture, but also a garbled one: https://youtube.com/shorts/DG4h5zmpg0g?feature=share
    - The t con board feels quite hot if I leave the set on for more than a few minutes
    I would like to have a certain root cause before I take it out to be recycled. Anything else I can check? I will keep reading the forums here for a bit and record anything else I try.
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: LG OLED65C9PUA post Windex repair?
    Oh... looks like the liquid got to the panel and corroded the board or part of the panel itself, this is certainly a panel issue, unfortunately access to the panel boards or side tabs (if they exist on this model) is not realistic, would require taking a saw to the metal to do a visual inspection on the boards, or un-glueing the panel from the metal frame to inspect side tabs.
    But you said few months ago? This increases the odds of some windex residue that stayed on the panel and did the job.
    I also have this tv model and don't see how the liquid could've gotten to the boards, but I don't know about the metal edges, if there's some copper at the edge of the panel.
    • Diah
      • Feb 2013
      • 6440
      under the metal cover at the bottom of the Module , there are just normal puffer boards with COFs like any other LCD,
      Module self at the back of it. there are aluminum sheet to transfer the heat to chassis then reflector white sheet and black one mounted on it the OLED Cells.
      spraying at the back will never go thru to Cells. but if it did on the edge of the metal cover then buffer boards will effected.
      • Expunge
        • May 2023
        Are you guys thinking panel? In all my research so far I haven't found a case quite like mine. If the panel is indeed shot could it present the way it is now? I did spray some contact cleaner through the gaps in the panel as soon as I learned what happened, roughly 2-3 hours later before I put the TV in the corner of the room.
        Last night I removed the t con and went over it with a multimeter and found a few ceramic caps that appear to have shorted. (Probing both ends of the caps show continuity) I think I would like to try replacing them to see if that makes a difference.
        Also during my research I found a video of someone who made a video of separating the OLED panel from the frame. It looks like I might be able to do this myself if I am careful. While I'm not the world's best electrician I am pretty mechanically inclined. Perhaps I could even replace the back panel with a cnc milled one. I make large aluminum aerospace frames at work all the time. Worst case I could provide some pictures of exactly what happens if you clean a TV with Windex.
        I also found a video of someone repairing those puffer boards by replacing some components on them.
        • Diah
          • Feb 2013
          • 6440
          as per yours video it show some kind of issue between T-CON and Module buffer boards.
          the module clued with thin double side type by 4-5 line . no way to take it out with out broken it. bur if you take all boards / cable out side leave the panel solo with chassis .. and make Alcohol 99% bath and let it sitting in bath...all the type will mild and easy take it from chassis with suck cups.
          • Expunge
            • May 2023
            Interesting idea
            • howardc64
              LG 49UJ6500 LCD panel lighter band that goes away
              by howardc64
              49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
              Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
              02-19-2023, 12:13 AM
            • triplefour
              SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
              by triplefour
              TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
              tcon is built into mainboard.
              Only one cable goes to panel boards.
              there is a cable from one panel board to the other that links them.
              cost cutting measure that results in us having harder time to diagnose.
              removing the link to the second panel board allows TV to stay on with stable backlight but no image.
              used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
              07-28-2022, 07:59 PM
            • Storyteller12
              QN55Q60R Service Menu Panel Help
              by Storyteller12
              I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
              I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
              I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
              the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
              01-13-2024, 01:57 PM
            • maneatingmonkey
              Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
              by maneatingmonkey
              I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
              There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
              03-27-2024, 07:17 AM
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
