Magnavox 42MF230A/37 no picture no sound!!
  • RJR
    • Sep 2010
    Hello I have a Magnavox 42MF230A/37 its a plasma. When I turn it on the red standby LED turns blue and I hear the relay click and that's it. After I turn it on at the controls on the TV, the only way I can get it to turn off is by unplugging it.
    I found and replaced 4 bad caps three on the power supply board and and 1 on the Y main board. still no picture or sound.
    If anyone can help that would be amazing.
    Thanks RJR
  • PlainBill
    • Feb 2009
    • 7034
    Re: Magnavox 42MF230A/37 no picture no sound!!
    Thanks RJR
    The service manual is here. Dowmload it, study it, then test the output voltages of the power supply. If they are good, the fact that you cannot turn the TV off from either the power button or the remote indicates a problem on the Small Signal Board or one of the sub-boards. Those boards should be well documented in the manual.
    I would question if it is worth putting a great deal into that TV unless you are sure it has very low hours. That uses a very early plasma panel.
    PlainBill
    • RJR
      • Sep 2010
      Well I've got good voltage going to and coming out of the sub power supply board and good voltage going to my main power supply but nothing coming out of it. So that sounds like a good place to start. The TV was free got it from a friend so I've got nothing in it but some time and a few caps.
      Thank you sooo much for your help!! I'll be posting again if that fixed it or not.
      RJR
      • dzooem
        • Oct 2010
        "Hello I have a Magnavox 42MF230A/37 its a plasma. When I turn it on the red standby LED turns blue and I hear the relay click and that's it. After I turn it on at the controls on the TV, the only way I can get it to turn off is by unplugging it."
        I just fix my TV today.same model # and same problem You have .I found bad diode on Power supply board supply 155V/VE voltage for driving X board
        • jeffescortlx
          • May 2011
          • 40
          I have the same modle with the same problem. I went over the power supply 3 times, "155V/VE" does'nt seem to be a part number, or a location.
          Could you give me a hint on what kind of diode I'm looking for, or it's location?
          I back tracked the X sus board plug and could'nt find any bad diodes. Then I checked every diode on the PS.
          • jeffescortlx
            • May 2011
            • 40
            Looks like my problem is different but same "LED goes blue, get a click, but no picture or sound"
            My Y main has two open burnt resisters. There fairly high wattage, 3-5 watts or so, lifted off the board.
            I backed pinned what I could get to and identify on the power supply. It seem's to have power where it should. So the Y board must be keeping the TV from powering up. Does this sound right?
            • jeffescortlx
              • May 2011
              • 40
              Y sustain board LJ92-01200A has a shorted D5009 Diode, and R5028 & R5090 are burnt open. It looks to be tired into a 7815 voltage regulator.
              I checked all the cap's and fuses and looked for shorted semiconductors, fet's, diodes, 7815 and looked for bad solder joints on the Y board and power supply and any thing else I could find. I cant find any other bad parts on this board.
              I replaced the bad diode and resisters. They just burnt up again.
              Any one know how to check that big STK under the heat sink? Thats the only thing I did'nt meter. But the parts that are frying dont seem to be related to the STK pack.
              • PlainBill
                • Feb 2009
                • 7034
                This plasma panel is very problematic. Google the Coppell TV Repair Blog for information on locating shorts on the Y-Sustain and Y Buffers.
                PlainBill
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • jord4231
                  Toshiba 37AV500A Regza TV good power supply no sound no picture
                  by jord4231
                  Hi Everyone,
                  I'm working on a Toshiba 37AV500A Regza TV.
                  The issue:
                  TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                  The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                  I checked the PSU voltages and everything looked good.
                  No bulging caps or signs of heat.
                  24v aud = 24.41v
                  12v = 11.98v
                  5v = 5.062
                  p_o/f = Goes high...
                  03-29-2022, 09:21 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
