Toshiba 49V6863DG firmware request
  • sda
    • May 2015
    • 11
    • Greece
    The above set boots with logo, then black screen with B/L on and continues with the alternate red/green flash.
    An upgrade file would be welcomed before desoldering the flash spi/nand chips.
  • sda
    • May 2015
    • 11
    • Greece
    Re: Toshiba 49V6863DG firmware request
    Some details
    Main - 17MB130S
    Panel - VES490QNYL-2D-N01 with external T-Con
    • yokoono
      • Apr 2010
      • 505
      17MB130S panel VES490QNYL-2D-N01 nand + spi;
      https://files.fm/u/gw5kr7bb6
      For stick;
      https://files.fm/u/j9j2kgcwv
      • sda
        • May 2015
        • 11
        • Greece
        Thank you @yokoono
        At the end I used upgrade files I had in hand for the Hitachi 49HK6000 which is exactly (including the subw amp) the same as my Tosh, and solved the problem.
        Of coarse it came in as a Tosh, and leaves as a Hitachi.
        Is it possible to change the boot logo splash-screen?
        Good to have the files you uploaded for me, specially the nand dump.
        Thanks again
        • yokoono
          • Apr 2010
          • 505
          The logo can be changed, but I don't have the file. However, you can delete that logo by saving the profiles from the TV and deleting the logo with the VestelToolbox utility.
          • sda
            • May 2015
            • 11
            • Greece
            Thanks.
            I will try it out.
            Cheers
            • piavushka
              • Jan 2021
              • greece
              Hi, can you reupload the files?
              • piernov
                Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                by piernov
                Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                I suspect corrupt firmware but I haven't been able to find anything for this TV.
                TV model: Finlux 65-FUC-8060
                Mainboard: Vestel 17MB130S 23473048
                Panel: VES650QNTS-2D-U11
                At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                06-01-2024, 12:57 PM
              • anlu
                Vestel Firmware - Toshiba 32W133DN
                by anlu
                Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                02-04-2023, 12:59 AM
              • wattage
                by wattage
                Hello Badcaps Community,
                07-13-2025, 04:41 PM
              • Bazilwrc164
                Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                by Bazilwrc164
                I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                If anyone can provide:
                • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                • Or a compatible EEPROM dump
                07-23-2025, 12:15 PM
              • EduCabral
                [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                by EduCabral
                I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                🔧 Details:
                • Model: YT-M06
                • Interface: Pioneer 1
                • MCU: Fujitsu MB89F202
                • Goal: Find a valid .bin firmware file or memory dump from a working unit
                I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                07-15-2025, 12:26 AM
