lg plasma fixable?
  • dchoiper4
    • Sep 2010
    lg plasma fixable?
    can anyone tell off hand whether this tv would be worth attempting to fix? it is a lg 50 in plasma
  • PowerAmpFreak
    • 982
    • Sweden
    Re: lg plasma fixable?
    You could at least tell us what model this is.
    Give us half a chance to help you.
    • PlainBill
      • Feb 2009
      • 7034
      Well said. My first thought was "Absolutely not. Ship it to me (prepaid) and I will dispose of it properly."
      PlainBill
      • cadiman
        • Mar 2010
        • 397
        Do you think you can fix this tv?.....I don`t think......I know!....I don`t think you know either! The real answer is...yes you can fix this tv! Start with ribbon cables. Make sure they are seated properly in the control board. ( The board just below the power supply behind the tuner board it will have green leds on it) You want to check the flat cable going to the y drive from the control board. The y drive board is the large board on the left side of the tv as you look at the back of the tv. start with that then give us a model number.
        be careful with the connections they are easy to break.
        • cadiman
          • Mar 2010
          • 397
          I think we lost another one!....I will try to be nicer next time.
          • Simplebeans
            MacBook Pro A2338 keeps restarting when attempting to install macOS
            by Simplebeans
            I have just got in a MacBook Pro A2338 which was initially displaying the Apple logo followed by an explanation mark in a circle as described here:- https://support.apple.com/en-gb/102164.
            After some error messages attempting to revive and restore the machine via DFU mode i have finally got the machine revived however now the issue seems to be when attempting to install macOS Sequoia via a bootable USB installer or via macOS recovery the machine just keeps freezing and restarting before the installation is complete, usually the installation has just started or is mid way trough before...
            08-10-2025, 11:04 AM
          • ArMaaN376
            Samsung PS51E550 Plasma TV
            by ArMaaN376
            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
            Opened TV cover & observed foll
            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
            How to confirm Y -Buffer board...
            06-19-2024, 04:05 AM
          • jm1234
            Panasonic plasma TX-P42ST50 - 6 blinks
            by jm1234
            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
            I checked that board for any obvious faults...
            05-22-2024, 06:59 AM
          • KYBOSH
            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
            by KYBOSH
            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
            No picture but you hear the TV static (white noise) playing loud and clear.
            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
            But it seems they didn't get too far and just left it.
            When I first took a look I was amazed at how pristine the inside looked.
            Its as if the TV had been in a time capsule.
            Caps looked like they were just pulled off the self.
            Copper coils had no sign of corrosion on...
            02-01-2023, 11:10 PM
          • chazh
            LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
            by chazh
            This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
            I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
            The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
            09-01-2025, 08:56 PM
