Sony KP 51HW40 A Signal Board 1-680-875-14
  • jo28pe
    • Sep 2010
    Hi. Want to apologize in advance if i don't do a good job here, first time posting.
    I have a Sony 51HW40 rear projection tv that i've had for quite a few years. It's always worked great. Recently a door was left open during some rain and the tv's on screen menus and the colors seem to have disappeared. It's a clear good quality image, but in like sepia like color .
    My repairman says that all i need for the tv to work just fine is the "Sony KP 51HW40 A Signal Board 1-680-875-14"
    But I've searched everywhere online and can't find it. My repairman man says that without that part, there's nothing he can do due to the moisture on that particular part.
    I was hoping someone could give me advice on either salvaging the part, or how to possibly find a replacement.
    Thanks in advance!
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • delpiero3
    Sony Vaio SVS MBX-261 board failure
    by delpiero3
    Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
    Nevertheless, let's say, i don't come as a total beginner.
    I have this old laptop, which suit perfectly my needs, with the...
    10-29-2024, 06:16 AM
  • huj3r
    Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
    by huj3r
    Hi there!
    I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
    Photo of the situation after the black shadow dissipates:
    After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
    I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
    > This indicates HFR Communication error. [ HFR Communication...
    08-15-2023, 10:55 AM
