RCA L42WD22 No Picture
  • Doming0
    • Sep 2010
    • 56
    Re: RCA L42WD22 No Picture
    The transformers being the rather large rectangular objects on the inverter boards pictured in the post above? Sorry, I am ultra noob. =)
    • Doming0
      • Sep 2010
      • 56
      I have found the specs on the transformers used in my tv. Now I am going to try and ascertain if they are good or bad.
      http://www.bujeon.com/project/front/...r&menu_idx=546
      EDIT: I was going to test them but the spec sheet doesn't give me Primary and Secondary Ohm's ratings to go off of. Any ideas?
      • retiredcaps
        • Apr 2010
        • 9271
        I'm guessing the primaries will be around 1.3 ohms. The secondaries might be around 950 ohms.
        Report all the measurments. If the secondaries deviate by more than 3%, it might be defective.
        A ring tester makes the testing a lot easier.
        Here is a youtube video showing the process on how to measure secondaries
        http://www.youtube.com/watch?v=eNuGWBPRGKA
        or if you have a ring tester, see this video
        http://www.youtube.com/watch?v=HMUazhb0bhc
        --- begin sig file ---
        --- end sig file ---
        • Doming0
          • Sep 2010
          • 56
          Ok here's the transformers. Since I can't find a decent (maybe discernable to me would be more apt) schematic. Can someone point out to me which are the Primary and Secondary leads?
          Oh and I unfortunately do not have a ring tester. I want one though! =)
          • retiredcaps
            • Apr 2010
            • 9271
            [QUOTE=Doming0;126013Can someone point out to me which are the Primary and Secondary leads?
            [/QUOTE]
            If you can't find a diagram to show the two, just do it this way as described in #4
            https://www.badcaps.net/forum/showthread.php?t=10419
            I believe the secondaries are the ones leading to the ccfl connectors. If you flip the board over and follow the transformer pins to the ccfl connectors, those should be the secondaries.
            • Doming0
              • Sep 2010
              • 56
              #26
              I was testing the transistors and found 2 bad (no signal) on the Slave Inverter board. They are designated Fairchild 1h28sr FDD 8447L.
              • Doming0
                • Sep 2010
                • 56
                #27
                The Master Inverter seems ok from tests run thus far. The slave board has an additional bad zener diod.
                Question.. should I unsolder the transformers in order to test them? Also, how would I go about checking the multi-legged IC's in the middle of both boards?
                Once again, I thank all of you for your help. I'm learning as I go here and hope to one day shed my noob status. =)
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  The transformers an be tested "in circuit".
                  For multilegged ICs, look up for the part number datasheet. If it is a FET, test s-g, g-d, s-d for shorts.
                  • Doming0
                    • Sep 2010
                    • 56
                    #29
                    Many thanks R.C.
                    After additional testing it seems the Pico fuse is shot as well. I will test the IC's this weekend. From everything that seems to be wrong with the Slave Inverter and the amount of parts required to fix, would it be better just to order a new one.
                    The master seems ok but the slave seems fried beyond repair IMO.
                    EDIT: I needed to switch things up from running tests, so I decided to change the caps in an AOC 17" LCD that a friend gave me off the recycle pile.
                    Changed 3 caps, and I'm using it right now to type this. =)
                    • OldNewTech
                      • Sep 2010
                      #30
                      Same exact problems with the same tv I'm currently working on. The 2 bloated caps on the master inverter board. Replaced those. Transformers look/test good on both boards. Then I jumped over to the slave board and, unlike the master, 25 volts was not going past that smd fuse. So something must have popped it. Found the same 2 smd transistors shorted. Nothing else though.
                      I just bought a slave replacement from shopjimmy.com, couldn't find the transistors online due to error in reading make/part number of the transistors. Now that you've posted them, I could've gotten them from newark.com for $1 each... damn!.
                      Will post what happens when the board arrives.
                      • Doming0
                        • Sep 2010
                        • 56
                        #31
                        Sounds good O.N.T., keep us posted.
                        • Doming0
                          • Sep 2010
                          • 56
                          #32
                          Ok, wow, that took forever and I probably did it wrong! But that's how you learn I suppose.
                          Anyhow, attached you will find the test results of the Master Inverter Transformers. Please, if you have the time, take a look and see if I'm doing this correctly and what it all means.
                          Thanks =)
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Okay, these tests results don't look right. You have 4 inverter transformers (those black square boxes) in total.
                            Number them T1, T2, T3, and T4. For each transformer, number each pin any way you like, but make sure it is consistent for each transformer.
                            For each transformer, you want this these resistance (ohms) test (assuming 8 pins).
                            1-2, 1-3, 1-4, 1-5, 1-6, 1-7, 1-8,
                            2-3, 2-4, 2-5, 2-6, 2-7, 2-8,
                            3-4, 3-5, 3-6, 3-7, 3-8
                            4-5, 4-6, 4-7, 4-8
                            5-6, 5-7, 5-8,
                            6-7, 6-8
                            7-8
                            You should have 4 sets of the above readings.
                            • Doming0
                              • Sep 2010
                              • 56
                              #34
                              Ok, thank you RC.
                              What I did was redundant I suppose, since I measured everything 8 times on each of the two Master transformers.
                              (The inverter is split into two separate boards on my tv Master and Slave and each has two transformers)
                              So I believe I do have all those results for the first two, I just have to reorganize the data. Then I can test the Slave transformers with the formula you showed me.
                              BTW I am using a digital auto ranging multimeter set to ohms. Should I be using the diode or continuity test instead?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Put the dmm to ohms.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  If you haven't retested the transformers, number like the above url.
                                  I beleive NS is secondary is the URL above.
                                  • Doming0
                                    • Sep 2010
                                    • 56
                                    #37
                                    Ok, here we go again. Just finished up following the same diagram as in the url stated.
                                    Attached you will find the testing done for all 4 transformers.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #38
                                      The transformer numbers look consistent, however, the only potentially strange readings are the 16 ohm ones.
                                      This transformer test doesn't find shorted turns. A ring tester will find that.
                                      • Doming0
                                        • Sep 2010
                                        • 56
                                        #39
                                        Unfortunately I do not have a cool ring tester.. would you know where to get one on the cheaper side?
                                        Regarding the 16 ohm readings, they may be strange but they are also consistantly strange across all 4 transformers. I wish I knew what it meant! lol
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          The numbers are interesting, but I don't see any indication of how you numbered the pins. Further complicating the issue is the lack of clear pictures showing the ends of the transformer. I've marked up one of the pictures and would like some points cleared up. One problem is none of the readings fall into the range I would expect for secondary windings. I would expect the secondaries of the transformers to read in the range of 1K - 2K ohms. 16 ohms implies a much heavier wire than I have seen on an inverter transformer.
                                          For starters, I have marked 'terminals' 1A, 3A, 4A, 5A and 7A. These may be wrap points for the windings, or they might be soldered to the circuit board. The pictures aren't clear enough to be certain. Visually, are they soldered to the circuit board? Resistance readings are not necessary.
                                          On the other end of the board we have more confusion. We have 4 pins on each of two transformers, but only two obvious output pins. What is worse, from the pictures it appears all pins are soldered to a common plane, which makes very little sense. To illustrate, Pin 1 is very obviously soldered to one plane. Pins 2 and 3 are obviously soldered to a different plane. Pin 4 is soldered to a third plane. Also obviously the center two pins of the lower transformer are connected to the center two pins of the upper transformer. It appears likely that the upper left pin of the lower transformer is connected to pin 1 of the upper transformer; certainly all of these planes have features which suggest they handle power - drive to the transformer windings.
                                          Which pins on the right side of the transformers are visually connected together?
                                          The next step is more complex. Set your DMM to the resistance scale. Put one probe on point 14 - one lead of the output connector. What are the resistances to points 5, 6, 7, 8, 9, 10 ,11, 12. If any of these read open (greater than 1 megohm), repeat using point 13 as the reference.
                                          Background - I have seen at least one design that appeared to use a two stage inverter. A high voltage section sat on the power supply, wires ran to transformers mounted at the CCFLs. So, could you post a single - over-all shot of the back of the TV?
                                          PlainBill
                                          • brithepi2k
                                            Samsung UE75TU7020k No picture, Standby blinks 2 times
                                            by brithepi2k
                                            My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                            04-23-2025, 10:05 AM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • madan1
                                            DALI SUB E-12F class D, fluctuating power rail
                                            by madan1
                                            Good day everyone.
                                            I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                                            The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                                            The normal value of the positive and negative power rails is +/- 43V.
                                            The positive rail stays...
                                            10-15-2025, 10:33 AM
                                          • slimsoul
                                            Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                                            by slimsoul
                                            Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                                            I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                                            I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                                            The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                                            03-12-2024, 03:55 AM
