Friend of mine gave me a Sony SLV-D300P DVD/VCR Combo unit to look at. It does not power on from the front panel switch or light up to show it has any signs of life while plugged into the wall. I at least checked to see if the switch has continuity and if the input voltage to the unit can read after the main fuse. Other than that- ???? I tried to look at some repair technician forums, but can't get access. Anatek isn't much help with this newer model. Just wanted to know if this model has specific inherent problems that could be simply fixed much like the motherboards I've been repairing. Thanks guys
Need help diagnosing DVD/VCR Combo player
Re: Need help diagnosing DVD/VCR Combo player
i had two denon dvd players dvd-1400 completely dead after power surge. No other unit in the house was damaged.
maybe it was power surge also for that unit.
check the thread, some troubleshooting tips were given
https://www.badcaps.net/forum/showth...light=dvd-1400
i cant help further cos under warranty they replaced the entire system board for both units.Comment
Hello everyone !
I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
Feel free to share your experience if you ran into other issues.
DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
CD tray would not come out of the player
I could hear a motor spinning inside the player but the CD tray would not come out.
Turned out that the issue was the CD tray belt that aged poorly and began to...-
11-05-2025, 03:11 AM -
by ngmlI am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
This indicates an error in the communication between the outdoor and the indoor unit.
The outdoor unit is fine, so the problem is the indoor PCB.
The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
Does anybody have the schematics of this board,...2 Photos02-01-2025, 12:55 PM -
by DrDosI have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...1 Photo
by kokopelli75Hello!
My mother has a Victrola Navigator player that stopped functioning after a storm. I checked out what I could - all player functions appear to work, but there is no audio output in either the speakers or the headphone jack. I suspect (with my limited knowledge) that the amplifier part of the device is toast. Photo of the suspected board is attached. There's separate boards for front display, record player, etc. This board has a section for power regulation and a section for amp. There's a UTC7266 7+7W dual bridge amplifier IC and a CSC2314F sound processor IC on the board. Visually,...1 Photo-
by nobbnobb1Hi guys,
Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...-
02-03-2022, 11:14 AM -
- Loading...
