Help for Hitachi 42HDX99
  • purplebird05
    • Aug 2010
    • 8
    TV goes through power cycles when turned on. Stays on for 5-10 seconds then turns off for 5-10 seconds. This process is repeated until the tv is unplugged. I replaced two potentially bad caps (very slight bulging) without improvement. Next step?
    The blue light on the front of the TV flashes 8 times. I am having trouble locating a service manual, any suggestions?
  • seanc
    • Nov 2008
    • 1319
    Re: Help for Hitachi 42HDX99
    The power supply is shutting down and restarting.
    We need clear pictures of the power board, back and front.
    • purplebird05
      • Aug 2010
      • 8
      You can see the pictures here...
      http://i838.photobucket.com/albums/z...PowerBoard.jpg
      http://i838.photobucket.com/albums/z...2HDX99Back.jpg
      • retiredcaps
        • Apr 2010
        • 9271
        Your pictures are a bit out of focus and low resolution.
        1) Post clear focused pictures of your boards after reading
        https://www.badcaps.net/forum/showthread.php?t=1868
        2) Please do not post pictures inline as they slow down the loading of pages.
        3) For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
        --- begin sig file ---
        --- end sig file ---
        • purplebird05
          • Aug 2010
          • 8
          Try viewing these...
          http://s838.photobucket.com/albums/zz304/Purplebird05/
          • PlainBill
            • Feb 2009
            • 7034
            PlainBill
            • Nate M.
              • Mar 2011
              purplebird05,
              Did you ever find a solution to your 42HDX99 shutting off and coming back on? I have the same TV with the same problem. Please let me know.
              • zklgfs
                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                by zklgfs
                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                08-11-2025, 02:14 PM
              • twonk9098
                Lenovo Legion 5 high fan spin turns off after 34 seconds
                by twonk9098
                I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                I have tried a few new bios but exactly...
                07-14-2024, 11:19 AM
              • liquidzorch
                Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                by liquidzorch
                Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                10-18-2024, 05:19 PM
              • Rick_1234
                by Rick_1234
                Good evening, gentlemen.
                Things I tried
                06-22-2024, 04:44 PM
              • PowellSkier
                Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                by PowellSkier
                A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                06-17-2024, 11:43 AM
