L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
  • cekanayake
    • May 2019
    • 16
    I am a noob with some elementary knowledge trying to fix this TV that I have no history on. Any help or guidance will be much appreciated.
    When I first examined it was completely dead. saw that the fuse was blown and the ICM801CS blown. I searched and found that the FSFR1800HSL might be the replacement and got one from ebay and replaced it. But when I pulled the ICM801CS I could see the last 3 letters on the blown up part was XSL. So may be I replaced it with the incorrect part. I fixed the fuse and turned it on and it now gives me a standby light blinking twice five times, then clicks and repeats. Checked the entire board and cant find any other visually defective parts. Pulled /20UA60DN and checked it as it's heat sink screw was stripped. It showed 0.469v when negative multimeter lead on middle pin and positive on either side pins and showed no connectivity in reverse therefore I think this one cheched out. Put board back on TV and disconnected the main board lead and turned it on and the backlight came on but when it is connected the blinking standby light happens.
    Since I the ICM801CS part number is not legible if anyone can help me find the correct part and any other advice on this endeavor is much appreciated.
  • Diah
    • Feb 2013
    • 6363
    Re: L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
    how about you post photos on the PSU and of the socket print chart which it go to main boards.... also measure and listed all voltage you have on the socket with pin name while the 5 blinking time.
    • lotas
      • Jan 2016
      • 4589
      • Russia
      HS and XS are completely different series, they differ in 2 pins.
      • Diah
        • Feb 2013
        • 6363
        PFC goes high when MB disconnected so BL turn on.. LED indicator lit on mean STBY V present.... but how about Power on signal !!! yours photo of the socket print chart not clear at all.
        • cekanayake
          • May 2019
          • 16
          I mounted the PSU board back on the TV to measure the voltages and now it is flashing the back light continuously.
          Here are the voltages I measured when the main board was disconnected. Pins 2, 4, 6, 8 around 2.5V and 10 at 11mv 12 at 2.43V 18 at 5.38V 20 at 3.37V. Pin 1 at 0V 3 at 1.11V pins 7, 9, 11, 13 at 7.62V pin 17and 19 at 4.22V
          I measured the voltages of the outer pins as they are exposed and could not get good readings of the inner the pins. Pins 7, 9, 11, 13 were jumping to 10V temporarily and pins 17 and 19 were jumping to 5.37V. Jumping meaning they were not constant and held at that voltage for enough time to read them and then showing some milli volts.
          I am afraid now that something else has gone bad on the board.
          • cekanayake
            • May 2019
            • 16
            OK got it. The only legible letters on the IC are XSL. Pictures attached. What could be the actual part I need to fix the board? I looked all over the internet for a schematic for it and could not find it.Aafter looking at the board and the schematic for the HSL I thought it would be the correct part and thats why I got this replacement.
            • Diah
              • Feb 2013
              • 6363
              you need to measure voltage while MB connected and give attention on pin 20 reading
              • cekanayake
                • May 2019
                • 16
                When main board plugged in pin 20 shows 3.3V while back light is lit and goes down to 255mv when back light is off. This keeps cycling continuously. What can this mean.
                • lotas
                  • Jan 2016
                  • 4589
                  • Russia
                  Yes, you need to install exactly this one (FSFR1800XSL), it will not work with another one.
                  • Diah
                    • Feb 2013
                    • 6363
                    in this case.. u need to check pin A5V if its stable
                    if stable mean pin 20 power on caused by Main boards didn't boot ( boot loop)
                    if its not stable then the issue at PSU
                    • lotas
                      • Jan 2016
                      • 4589
                      • Russia
                      Yes, you don’t need to measure anything, you first need to replace it with the original microcircuit.
                        • 12146
                        • U.S.
                        Ok, so put the correct FSFR1800XSL in, then continue testing as advised, how could it possibly work with 2 pins completely different, it won't.
                        • cekanayake
                          • May 2019
                          • 16
                          Yes, you don't need to measure anything, you first need to replace it with the original microcircuit.
                          Upon closer examination of the burnt IC the last few numbers on the part number may be 100XSL. So could this be an FSFR2100XSL? If so I will replace it with this part and update here. Thank you everyone for the quick responses to my issue.
                          • lotas
                            • Jan 2016
                            • 4589
                            • Russia
                            Well, then you need to know exactly what should be.
                              • 12146
                              • U.S.
                              If you can find a quality service manual it might have a parts list in it.
                                • 12146
                                • U.S.
                                Saw a parts list but wouldn't you know it they didn't list the suffix, just FSFR1800, so if you can read the last part then it looks like it is indeed a FSFR1800XSL.
                                • cekanayake
                                  • May 2019
                                  • 16
                                  Looking at the remnants of the IC-pictures posted, I think it might be FSFR2100XSL. Please take a look at it let me know what you think
                                  • lotas
                                    • Jan 2016
                                    • 4589
                                    • Russia
                                    Yes, it is very similar to 1, put it, that is, FSFR2100XSL.
                                    Just for your "65" diagonal, it is the most powerful of this series.
                                    In "46" the diagonal is 1800.
                                    • cekanayake
                                      • May 2019
                                      • 16
                                      Thank you. I will order it. I will update after I make the change.
                                        • 12146
                                        • U.S.
                                        Yep, that makes sense, the parts list I saw was for a 55 inch.
                                        • Seb932
                                          LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
                                          by Seb932
                                          i'would like to fix my not working LG 49UB850V tv.
                                          Symptoms:
                                          -AC plugged in, Standby LED not working
                                          -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
                                          Checked already:
                                          -Powersupply Output in Standby => 3.5V ok
                                          -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
                                          Any suggestions what to check next?
                                          Thanks in advance!
                                          09-14-2023, 06:28 AM
                                        • brithepi2k
                                          Samsung UE75TU7020k No picture, Standby blinks 2 times
                                          by brithepi2k
                                          My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                          04-23-2025, 10:05 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • Jackching
                                          Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                                          by Jackching
                                          I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                                          04-15-2024, 05:14 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
