Sharp LC-40LE730E losts channels, need dump
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4326
    • Italy - Milan
    Needs new channel search every turn on, i need dump, i have read the Nand flash, it has no common partition formats on it, i guess system is propietary not linux... Thanks!! bye..
    PS: sorry this is the NET version
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4326
    • Italy - Milan
    Re: Sharp LC-40LE730E losts channels, need dump
    it's probably linux but has yaffs2 partitions, need to find the way to read write them
    • lotas
      • Jan 2016
      • 4597
      • Russia
      Still need dump nand? Do you have such a motherboard QPWBXF915WJN2 / DUNTK915? What programmer do you have and can you post your dump and I'll take a look?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4326
        • Italy - Milan
        Hi Lotas thanks, the board is exact, how can you watch the firmware inside? It's hard to upload it, it's 128mb, i have no fiber only adsl, i'm trying to use binwalk to watch inside and after extract the yaffs2 partitions, with yaffey i must read all files then create a new partition and put back files, seems a common yaffs2 design problem.. but binwalk for windows does not work, newly installed, gives me error, it's crap, i can try linux version, i hate losing hours with searches and tries.. dump read with tl866ii+
        • lotas
          • Jan 2016
          • 4597
          • Russia
          Try it, link to dump in private messages.
          After flashing nand, you also need to update via usb with firmware (Software_Version_1-121G).
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4326
            • Italy - Milan
            Thanks very much Lotas, unfortunately no go, i have written 3 tries but it always find 2 bad blocks, when rewriting the original dump all things ok, so bad dump, it stores 2 bad blocks data..
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4326
              • Italy - Milan
              Update, the dump file was ok, it was the memory support damaged, after reprogramming a new chip (actually chinese seller sold me an used chip marked as new but it worked) now all things ok. Thanks a lot Lotas..
              PS: sorry for the title, loses channels..
