Hitachi 58HK6100U Strange Issue
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi guys i was given this as a freebie. switched it on and screen displays nothing but backlights are on. first thought was panel so i tried some troubleshooting.
    left tab unplugged - right side of screen fine
    right tab unplugged - left side of screen fine.
    i then plugged in left tab while the tv was on and both sides where fine, could access menu, NO SIGNAL splash screen etc.
    powered off with screen ok and powered back on, back to black screen.
    anyone else know what the issue could be ? i have another set the exact same with lines on screen so tried tcon and av board from that (same model) but didnt make a difference.
    any help is appreciated.
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Re: Hitachi 58HK6100U Strange Issue
    Anyone ?
      • 12181
      • U.S.
      I could be way off, but wondering if it could be similar to the issue a while ago where a member fixed tv with a bigger resistor?? Thread is there: https://www.badcaps.net/forum/showthread.php?t=107445
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        Hes having a slighlty different issue. Its strange how both sides work perfect and even when i plug each side in one by one the panel is perfect.
        • wizard13
          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
          by wizard13
          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
          I have checked the forum and the available documentation but could not find a solution specific to my issue.
          • Brand & Model: Dynabook Satellite Pro C50D-B-100
          • Part Number (P/N): PYU13E-00C00PFR
          • Serial Number (S/N): 22028896H
          • System Configuration (SC): A1PYU13E1127
          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
          • Power Input: DC 19V –
          02-28-2025, 02:43 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • cloudy
          HELP - Contrast/brightness issue with subtitles on screen
          by cloudy
          Hi everybody
          Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
          Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
          Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
          It occours both on ubuntu and windows...
          01-01-2023, 05:12 PM
        • ravi_1617
          HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
          by ravi_1617
          Hello to all ,
          I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
          Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
          on external VGA port image is perfect /normal , Attached image...
          07-25-2025, 12:07 AM
        • ScHAmPi
          Samsung UE48JU7000 screen issue after backlight replacement
          by ScHAmPi
          Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
          I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
          07-15-2024, 05:41 AM
