HiSense 65H6510G no boot
  • howardc64
    • Jun 2017
    • 634
    Re: HiSense 65H6510G no boot
    Originally posted by Diah
    there are tool to read the Mstar firmware extractor key... hope i could find it on my pc..... 2 time i had format it lol
    Thanks.
    I have no idea is this emmc dump path is possible to repair the failed eMMC board. I tried varied MStar commands that seemed useful and made the following document.
    • I'm guessing I properly dumped boot1 boot2 and user
    • 512b of ECSD is retrievable
    • RPMB requires knowing [addr] [size] [start block] and its an authenticated read so I'm assuming a write to new eMMC requires setting the authentication key
    • lotas
      • Jan 2016
      • 4711
      • Russia
      #122
      eMMC and UFS memory chips have an access-protected section called RPMB (Replay Protect Memory Block).
      In the UFS chip, the partition that performs the RPMB functions has the ID: W-LUN 0xC4.
      How it works in more detail:
      If the key (Key) is missing, then the device (processor) programs the key into the chip.
      The key is generated from the SN of the processor and the CID of the eMMC, and thus the key is different for different processors and different eMMCs. Further work takes place in the same mode as with a programmed key. The programmed key cannot be changed.
      If the key (Key) already exists, then, as a rule, the counter has a value greater than 0.
      With a microcircuit that already has a key (16 bytes), the device (processor) can only work through data encoded by the key (Key) and the record counter (Counter).
      Read mode: the device (processor) receives the counter value from eMMC, requests to read the data (in blocks of 256 bytes), receives the data encoded by the counter and key, decrypts it using the stored key and counter value, checks the validity of the data.
      Write mode: The device (processor) receives the counter value from the eMMC, encodes the data using the key and the counter (in blocks of 256 bytes) and sends it to the chip. The chip decrypts them using the stored key and counter value, checks the validity of the data. If the data is valid, the block is written, and the value of the write counter (Counter) is increased by 1.
      Thus, the value of the write counter (Counter) shows how many blocks of 256 bytes (or how many times) have been written to the RPMB area.
      In order to write to the RPMB partition, you need to know the key that is stored in the chip (eMMC).
      In order to read, you can try to apply a certain method of obtaining data. Although it is impossible to guarantee their validity, the experiments conducted by the Z3x Easy JTAG team show that data read in this way is valid in more than 90% of cases.
      In the latest versions of the Z3x EasyJTAG Classic program (3.4.4.0 and higher), the output to the log of the RPMB area status line has been added (whether data has ever been written to it or not).
      An example of a line in the program log:
      EMMC RPMB is not yet programmed (clear) or NO Error
      or
      EMMC RPMB is programmed and written 12 times
      At the same time, it is possible to read RPMB experimentally by selecting the RPMB partition (in the ROM selection combobox).
      Important:
      1) when writing Firmware to eMMC, the internal NAND memory of eMMC is re-initialized, with the key, counter and RPMB data being erased
      2) there is no other way to remove a key from RPMB or change a counter other than incrementing the counter by writing data encoded with a valid key.
      • howardc64
        • Jun 2017
        • 634
        or
        Important:
        Wow, thanks for the explanation @lotas! I worked in network content delivery systems before so am aware of the general security mechanisms (HW+SW keys and naturally evolved to put the most important keys inside most complex chip. iPhones have been inserting security inside various complex chips including LCD screen so mod chips can not be made). Your explanation of using SOC key, eMMC key, and access counter make sense to increase security. JTAG is also ultimate HW debugging tool for development and often used for break security
        I guess SONY Android TVs can be repaired with pre-programmed eMMC sellers because SONY must not keep per device keys in eMMC? HiSense keeps it in eMMC and unfortunately when non secured area of eMMC break eMMC, then everything disappears
        I guess probably to have all the tools and knowledge to repair this HiSense failed eMMC board is beyond most DIYers including me haha.
        • howardc64
          • Jun 2017
          • 634
          BTW, the service manual method of recovery probably requires MS ISP hardware? I use generic USB UART and encounter the following
          • MStar TV tool doesn't have Show DeviceID button. Without getting device ID, can't email MStar and get ID password (no idea if still get reply from email)
          • MStar ISP tool doesn't launch at all (Win10) Cursor just spins and stops..
          Anyway, even if these tools worked, still need to get mboot bin file and know how to load it to new eMMC. And still need to gather all the security keys from failed eMMC.
          Seems to need many detailed special knowledge to actually save this main board...
          • howardc64
            • Jun 2017
            • 634
            Searched for Android TV RPMB and found this post. SONY Android TV with dying eMMC. Poster recovered most of eMMC but not RPMB. Lost Netflix, Chromecast etc after writing data on new eMMC
            https://forum.xda-developers.com/t/s.../post-86106623
            https://forum.xda-developers.com/t/s.../post-86206099
            I guess RPMB recovery is the most challenging even if eMMC isn't completely dead. But losing Netflix/Chromecast or even all smart apps is okay as new Fire/Roku stick is much faster anyways. However, losing HDCP would be the biggest problem. The preprogrammed eMMC seller in post 82 ( link ) said HDCP/Netflix/HBO Max etc. will be lost without original eMMC. Does any know if HDCP will work if skip flashing RPMB?
            This kind of tool ( https://unlocktool.net/ ) exist for smartphones to backup RPMB and write it to eMMC. I guess it must know? can read? can change the SOC's key+counter to read and write to new eMMC RPMB region.
            • howardc64
              • Jun 2017
              • 634
              I guess eMMC wear could be from aggressive streaming app buffering. When turn on HiSense Android TV, it will show streaming app video quickly. This requires prefetching the video content and store locally on TV. If this is written to eMMC rather than DDR, then this can be a source of wearing out eMMC.
              This is just a guess, maybe the best usage mode is to turn off network (and maybe delete as many smart apps as possible?) and exclusively run smart feature via external smart device such as fire/roku stick.
              • Diah
                • Feb 2013
                • 6427
                streaming last will be most on DDR and Soc.
                the key i was talking on its about the firmware extractor. not license keys. dtump/ write eMMC will take care on them 1 to 1.
                but to tell the truth.. i still don't think yours emmc dead since we have sandwich boards .. every things possible.
                • howardc64
                  • Jun 2017
                  • 634
                  Yes, good point. I guess to 100% confirm require ext ISP to read eMMC without powering on main. I'll try acquire and try.
                  • Diah
                    • Feb 2013
                    • 6427
                    USB to TTL are fixed baudrate.. you need to connect with TTL end another adapter such serial to TTL. 1-2$ this adapter will response to any request of changing the rate as reguested... then TTL will remain work with out error... i did explain this before. each section Soc request other rate of data transfer... this the function of the ISP
                    • howardc64
                      • Jun 2017
                      • 634
                      Unfortunately I don't understand this idea at all. re-read post #101 to #107 including @lotas's comments and unfortunately don't understand
                      My understanding to read eMMC on main board without powering on main is to use external ISP or USB SD Card reader. Connect VCC, GND, D0, CMD, CLK and access eMMC in 1 bit mode. This video ( link ) provide detail steps. Poster took careful step to cut eMMC 1.8v 3.3v line from main board rails for board protection and drove 1.8v line with 3.3v from ISP/SD Card Reader.
                      If there is someway to connect PL2303 and CH340G to eMMC without power on main board. Please explain where RXD, TXD, 3.3V, and GND should be soldered to on eMMC. I also don't understand what you mean by "log" What do we do to get the log without powered on main?
                      • Diah
                        • Feb 2013
                        • 6427
                        my last post#129 wasn't about to write eMMC as you planed in off mode.. because you can read too i mentioned the Soc baudrate request.. its explain on my thought i wrote at post
                        so you can write firmware on it in power mode. and there many succeed with Mstar Soc listed on xda developer portal.
                        • howardc64
                          • Jun 2017
                          • 634
                          Found more documentation and combining with @lotas's RPMB explanation in post #122. I think this is general process to repair failed eMMC
                          boot1 and mboot both contain device specific keys
                          Found guides that outline how to produce production firmware from existing eMMC. It says need to use original boot1 and mboot as any boot1/mboot copied from existing eMMC has device specific key
                          link1 link2 link3
                          Based on @lotas's explanation in post #122. Device specific key is combination of SOC ID (often implemented by blowing tiny fuses on chip called efuse) and eMMC ID. This means if eMMC is changed, keys need to be recalculated.
                          Likely Process
                          1. dump boot1 and eMMC user area
                          2. dump RPMB keys
                          3. maybe extract keys from boot1?
                          4. flash original boot1 to new eMMC
                          5. flash eMMC - mboot + original mboot to new eMMC
                          6. boot board with new eMMC
                          7. write device key to eMMC
                          8. write dumped RPMB keys to RPMB
                          So far, I achieved only #1 haha. #2 require knowledge of how to use MStar mmc rpmb read commands (I tried and don't have detailed understanding of command arguments)
                          Anyway, continuing learning.
                          Here is updated MStar command guide link
                          Also maybe eMMC access has failed due to some component failure on board. Will check around eMMC and compare working and failed board to see if any difference.
                          • d_boy_jq
                            • Jun 2023
                            • US
                            #133
                            Hi, I have the same model of Hisense TV and had the similar symptoms. I've seen every posts in this thread and seems like emmc is a problematic part and it's very hard to replace it. I'm wondering if we could fix it differently to make the TV working as a normal diaplay only, then we could connect it to a streaming tv box. And are there any tips to purchase a new TV without having to worry this emmc problem? I dont think the TV sellers could tell if the Tv has emmc or not.
                            • howardc64
                              • Jun 2017
                              • 634
                              I think best repair is still replace mainboard at reasonable price. Need to register for notification and act fast on following 2 sources when they appear.
                              • ~$70 per post #112
                              • ~$30 from ebay seller goodpointrecycling (save a search for this board and notification)
                              Boards come up every 2-3 weeks so far.
                              Looked into closely related Roku model equivalent by HiSense in post #65 but wasn't able to secure one to compare t-con output to see if compatible (also need wifi module+cable as they are different)
                              https://www.badcaps.net/forum/showpo...5&postcount=65
                              I think to just turn it into display without smart features is fine but probably will at least need HDCP keys.
                              Every smart TV use eMMC since ~mid 2010s and most run fine. Main eMMC failures I read about are all Android TVs by HiSense, SONY etc. Don't know if newer versions of Android TV OS is better... I guess won't know until a few years. But modern TVs do fail so fast from variety of reasons.. Samsung LCD panel failure. LED backlight on all cheaper brands. At least latest ones aren't dying of thermal cycle breakage of main SOC solder balls anymore.
                              Finally I'm in Sammamish if you are in Redmond, WA. Have the service port dongle to confirm eMMC failure.
                              • 360electronics
                                • Aug 2022
                                • mexico
                                #135
                                hi, any progress in this? do you have find any firmware for these model?
                                • howardc64
                                  • Jun 2017
                                  • 634
                                  HiSense website does provide download of USB upgrade firmware. However, if you have eMMC failure, need to locate/recover a bunch of stuff that HiSense doesn't provide. Read starting post #119
                                  Replacement board availability is challenging in US. Maybe almost impossible in other countries
                                  • Diah
                                    • Feb 2013
                                    • 6427
                                    just an idea...
                                    since its android ....how about we use SDCARD and let the firmware from hisense on it and we add on the root of the SD script with extension .pkg to drive the Soc to the other firmware location on SD !!!
                                    or we inject on SD recovery for the Soc from other brand.
                                    • d_boy_jq
                                      • Jun 2023
                                      • US
                                      #138
                                      Seems it's tough to get a replacment main board of the same model. The main board for this model is out of stock everywhere and I don't want to order from OEM which is too expensive. Is it possible to replace the main board with another Hisense TV model which had the same screen size? It's ok that some functions are not working, but at least the display can power on and I can stream from a TV box.
                                      • howardc64
                                        • Jun 2017
                                        • 634
                                        I posted the answer in post #134. 65R6G is close but I didn't get one in hand to confirm t-con signals match. Wifi flex + board is also different so will need to get that.
                                        Most cost effective solution is what I posted in #134. Need to save search on ebay and register for stock availability on TVPartsToday (setup your account + credit card, boards will disappear within an hour after becoming available. Lots of people have registered for notification)
                                        • kikokramer
                                          • Apr 2019
                                          • España
                                          #140
                                          Yes, many companies are already making eMMC firmware (with keys), binding to the ID of the SOC itself, and if you write someone else's eMMC dump, we get a castrato (crippled). That's why they try to pull as much data and partitions out of eMMC as possible.
                                          Hello, I have read the emmc of a Hisense H65B7300 that works well and I have transferred it to another TV H65B7300 in which the emmc had reached the end of its useful life, I have used a new emmc but I can never get it to come out of Standby, What could be the problem?
                                          • Dragunov
                                            Need firmware for HISENSE 40A5NQ
                                            by Dragunov
                                            i need firmware for HISENSE 40A5NQ so i can flash it via USB...
                                            Tried via USA website but it doesnt accept my serial number TV was bought in croatia.
                                            Remote works only to power on tv and after that i cant select firmware update or anything else...
                                            07-07-2025, 01:33 PM
                                          • joby91
                                            SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                                            by joby91
                                            I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                                            I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                                            I found one chat about firmware on ************** forum but i cannot read the comments.
                                            https://**************/forum/108-114100-1#880537
                                            09-04-2024, 01:34 PM
                                          • privato89
                                            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                            by privato89
                                            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                            Let's begin:
                                            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                            03-26-2024, 06:37 AM
                                          • DoubleBogey817
                                            HISENSE 65H6510G (13 AUG 2020) - POWER ISSUES
                                            by DoubleBogey817
                                            HISENSE 65H6510G (13 AUGUST 2020)
                                            When powered on, initial splash screen (HISENSE ANDROID TV) displays for a few seconds then power shuts off. Tried updating firmware with USB flash drive (can't find 4GB drive but did format larger drive in FAT32) with no luck. Flash drive would be accessed but would never get to the update process. I have ordered a board (RSAG7.820.7911/ROH, PART# 242585) from eBay which will arrive in a few days. Does anyone have any input of whether I am chasing down the right trail or should I be trying something else? I appreciate your time and wish to say thank...
                                            02-16-2024, 10:58 PM
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            Replaced emmc.
                                            Terminal log
                                            UART
                                            AC_ON
                                            E-B
                                            FDE enabled
                                            06-01-2025, 02:11 AM
