Dead Sharp Aquos LC-32LE430E
  • borstar_micke
    • Mar 2023
    • 11
    • Sweden
    My 12y old daughters tv (that she got after her grandpa, has sentimental value to her) was just dead without stby light a couple of weeks ago.
    I´ve repaired a couple of computer monitors, classic blown capacitor replacements, a 55" Sammy led with t-connboard replacement and a 42" Panasonic edge led where I replaced the led-strip.
    Not a master with the multimeter, which is cheap and 10-15year old btw...
    So please make it basic...
    To the issue at hand.
    As stated, the tv is totally dead with no standby light.
    Have measured on the power board and have 320V after the 3 capacitors on the hot side and also 320v by 2 zener diodes closer to the cold side (will add a photo of the power board). No voltage at all at the connector going to the main board or anywhere on the cold side.
    Attached powerboard photo with the 2 diodes with 320v marked and the repair manual.
    As you see I really need some advice here... stuck...
  • Diah
    • Feb 2013
    • 6395
    Re: Dead Sharp Aquos LC-32LE430E
    as i remember this power boards suffer from joint soldering points at Transformer pins.. so take it out of boards and check the down side and re solder all suspected soldering points
    then put it in place and with reference to Tv chassis check the socket which goes to MB if any volts you can find on it.
    • borstar_micke
      • Mar 2023
      • 11
      • Sweden
      Ok,thx, will try that tonight!
      • borstar_micke
        • Mar 2023
        • 11
        • Sweden
        Melted a lot of solder joints, still no go...
        • R_J
          • 9555
          The first voltage you need is the Standby +5.2V (page 127) see if it is there.
          • borstar_micke
            • Mar 2023
            • 11
            • Sweden
            No voltage AT ALL on the cold side...
            • R_J
              • 9555
              You likely have a bad IC9301, pins 7~12 are hot ground, so using that as your meter ground, check the voltage on pin6 (320v), then check the voltage on pin1
              On the back side of the board, check that ZD9301 is not shorted, then also check that R9325 (4R7Ω) is not open.
              • borstar_micke
                • Mar 2023
                • 11
                • Sweden
                Thanks for the help, greatly appreciated!
                Measured IC9301; pin6 at 317v, pin1 at 0v
                ZD9301 measured 003/003
                R9325 I just cant seem to find... strangely only the 32" seems to miss the schematics of the B-side of the power board in the repair manual... also cant find ZD9301 or R9325 in the parts list for the 32"...
                • Diah
                  • Feb 2013
                  • 6395
                  from yours measurements its look ZD9301 shorted. release one side of it from boards and measure it again... in case it had same read at both side / shorted.. mean there are R on the way open too.
                  so better upload focused high resolution photos to the top and down side of Hot area.
                  • borstar_micke
                    • Mar 2023
                    • 11
                    • Sweden
                    It´s a smd zenerdiode so I´ll just remove from the board and measure both ways then?
                    • borstar_micke
                      • Mar 2023
                      • 11
                      • Sweden
                      Removed and measured the ZD9301, now 762 / 1 so I guess that makes it ok?
                      Attached 2 photos of the hot side.
                      • R_J
                        • 9555
                        R9325 (4R7) is just above J9542 it connects the transformer feedback winding to D9311. (likely not your problem.
                        If you look at the schematic, ZD9301 should not read 003 (shorted), since it tests ok out of circuit, something else may be shorted, maybe C9312, C9316 or D9311
                        You can lift one end of J9041 which should isolate ZD9301 from C9312 this should point you to where the short might be.
                        • Diah
                          • Feb 2013
                          • 6395
                          i don't think there are any short.. its to me open circuit. of sure he tested ZD9301 with out discharge the hot section so the read 003
                          • lotas
                            • Jan 2016
                            • 4649
                            • Russia
                            Most likely, the PWM is not working (3 pin is shorted from 4pin.), such a malfunction came across.
                            • borstar_micke
                              • Mar 2023
                              • 11
                              • Sweden
                              Life got in the way, so I´ve first now had time to look at the board again.
                              Measured C9312 for continuity, gives a reading of zero both ways, indicating open circuit.
                              Also measured both sides against pin12 (hot ground) on IC9301, gives the same result.
                              Measured across C9311 which gives a reading of 1 both ways, indicating short circuit.
                              Against ground 1 one way and zero the other way.
                              Have also measured all resistors on the hot side which seems to be ok, and as good as I´m able too measured the other capacitors too and found C9816 that measures 1 both ways so also seems to have a short circuit.
                              ZD9301 is still not resoldered.
                                • 12206
                                • U.S.
                                Those are good pictures, can you post one of your multimeter, need to get consistent readings.
                                • borstar_micke
                                  • Mar 2023
                                  • 11
                                  • Sweden
                                  Here is a picture of my old multimeter.
                                    • 12206
                                    • U.S.
                                    That meter is fine for the job, the thing about meters that are not auto-ranging such as yours, is if you get a 1 it can mean out of range, as when checking in ohm mode, so say you are on the 200 ohm setting and get 1, you will want to move up to 2000 and recheck still 1 move up higher etc. Recheck all those you checked in ohm mode.
                                    • R_J
                                      • 9555
                                      Look at the schematic... If you have a short across C9311, either the cap is shorted or the optocoupler ic9312 is shorted (3~4), unsolder the optocoupler as it is easier and check for the short again. However if it is shorted, and you had standby voltage, the power supply would actually be ON all the time.
                                      • borstar_micke
                                        • Mar 2023
                                        • 11
                                        • Sweden
                                        Unsoldered ic9312, and c9311 still measures short, no continuity (both ways) while measuring in diode mode.
                                        And I have no power at all on the cold side....
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • WEJ
                                          Sharp aquos tv screen dead pixels & burning screen after 10 years
                                          by WEJ
                                          I have this LCD TV SHARP AQUOS 40".After use 10 years, it experiencedead pixels & screen burning, what the couse of it? How to fix it? Any idea, quys?🤔...
                                          05-21-2021, 07:54 AM
                                        • jonah1024
                                          Sharp Aquos LC-40UG7252E LCD TV burn in?
                                          by jonah1024
                                          Hello!
                                          I'm a few days old into this TV screens repair universe so please bear with me.
                                          Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                          - I did a factory reset as well...
                                          07-16-2024, 04:23 AM
                                        • Joekhoe
                                          Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
                                          by Joekhoe
                                          Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
                                          I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
                                          The replacement as follows:
                                          1. IC7905 : TNY264PN (first found exploded)
                                          2. Q7915 : BT169D (exploded too)
                                          3. IC7901 : 1608B (controller ic)
                                          4. IC7601 :...
                                          09-17-2020, 05:52 AM
                                        • klassic
                                          Sharp Aquos LC-60LE635E three blinks
                                          by klassic
                                          Hi community,
                                          I will describe my problem with a TV in those short following terms to be the most precise :
                                          What i have :
                                          power board DPS-162KP-1
                                          main logic board QPWBXF733WJN2
                                          symptoms :
                                          white led light logo at startup,
                                          after 2 minutes, blinking 3 times a row, repeating
                                          no backlight (and apparently no picture, checked panel with flashlight)
                                          no startup sound
                                          powerboard investigations :
                                          1-2 PNL : 0v
                                          3-4 GND
                                          5-6-7-8 UR : 13.15v
                                          9-10-11-12...
                                          10-24-2023, 01:39 PM
