LG 43UK6500AUA no LCD image, backlight and sound okay
  • nomoresonys
    • 12123
    • U.S.
    Re: LG 43UK6500AUA no LCD image, backlight and sound okay
    Thanks B0ba that will help a lot of us trying to fix these defects.
    • Videograph
      • Apr 2025
      • Україна
      Greetings. I have the same TV with the same problem. I’ve been suffering for the second day, I decided to turn to the Internet and found you. I succeeded, but the picture is very blurry. Which contacts on the CN1 cable did you cover? I've tried different combinations but the winking picture doesn't go away. Thank you very much in advance!
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
      • tuner2000i
        Philips 65PUS8518/12 distorted image after main board replacement
        by tuner2000i
        hello everyone,
        I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
        The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
        07-15-2025, 01:15 PM
