Tv Philips 47PFL3188H/12 (chassis tpn10.1e la) No led No power
  • fanaticgames
    • May 2017
    • 138
    • italy
    I have this philips tv that doesn't turn on (no red led), it had 4 capacitors leaking on the output and I changed them but it still doesn't work, any suggestions?
    the output voltages I get are:
    11/12 11.3v
    9/10 11.3
    Ps on: 3.6v
    1/2 0v
    the motherboard heats up on the cpu side
  • fanaticgames
    • May 2017
    • 138
    • italy
    Re: Tv Philips 47PFL3188H/12 (chassis tpn10.1e la) No led No power
    the only zones that heat up (about 45 degrees) are these, is that regulator 1117 25 normal that it heats up?
      • 12084
      • U.S.
      heat those other electrolytics nearby with a hairdryer for a couple minutes and try it while its still hot, no change, heat the rest of the electrolytics on the board and try it, see if there's any temporary change.
        • 12084
        • U.S.
        Same old procedure, test all diodes and resistors on powerboard and check all solder joints, is a good start.
        • fanaticgames
          • May 2017
          • 138
          • italy
          done, no change
          • fanaticgames
            • May 2017
            • 138
            • italy
            OK, but where is the entry dim/on off and ps_on what should I find?
              • 12084
              • U.S.
              Test it, meter on vdc, black probe on metal chassis ground, red probe on pin 2, on/off, tv in standby, take note, leave probe where it is power on tv, take note, do the same for pin 3 ps-on. Suppose dim could have various readings depending on settings.
              • fanaticgames
                • May 2017
                • 138
                • italy
                the tv just doesn't turn on or rather it seems to me that the motherboard automatically turns on the power supply, because if I disconnect the motherboard there are 8v on the main lines as I attach the cable that goes from the power supply to the motherboard the voltages are present which I wrote in the first post
                is it normal that by connecting only the motherboard the voltage goes from 8 to 11.3 as if I turn it on?
                  • 12084
                  • U.S.
                  ok, looks like you are missing 2 on/off, that's the backlight signal that comes from the mainboard, I would check the powerboard as stand alone.
                  • fanaticgames
                    • May 2017
                    • 138
                    • italy
                    with this model do you need to bridge ps on to gnd or do you need to inject a voltage greater than 2V on ps on?
                      • 12084
                      • U.S.
                      I suppose the easy way is to slip the wire from pin 2 off of cable on powerboard side, you just take a little flat screwdriver and lift the little tab a little and it slips out, with that wire out inject about 3 volts and see if backlights come on.
                        • 12084
                        • U.S.
                        ps on is getting voltage, its on/off that's missing.
                        • fanaticgames
                          • May 2017
                          • 138
                          • italy
                          now i try, i have the 3v jig used with lg tv
                            • 12084
                            • U.S.
                            maybe try tracing pin 2 back thru the mainboard and see what component it's going to.
                            • fanaticgames
                              • May 2017
                              • 138
                              • italy
                              injecting the 3v on pin 2 (ON OFF) the power supply does not turn on the voltage on the 12V remains at 8V
                              • fanaticgames
                                • May 2017
                                • 138
                                • italy
                                putting the 3v on ps_on I think the power supply turns on because on the 12v line I find 11.7v but the backlight does not turn on
                                are you sure philips is like samsung and should turn on the backlight too?
                                  • 12084
                                  • U.S.
                                  ok, thinking it must be ground, then try UNHOOK cable from powerboard to mainboard, leave it off, take three 1k ohm resistors and jump 1 from ground to ps-on, 1 from ground to on/off and 1 from ground to dim, then plug in power cord and see if backlights come on and stay on.
                                    • 12084
                                    • U.S.
                                    You wouldn't think they would need to make tvs in a thousand different configurations but they just have to for some reason.
                                      • 12084
                                      • U.S.
                                      You can also do a dirty test on those caps you changed, set meter on 20k ohms and see if they all do the same thing with a probe on each leg, reverse probes, they should rise or fall in a steady manner.
                                      • fanaticgames
                                        • May 2017
                                        • 138
                                        • italy
                                        tried it, it remains off, the voltage remains at 8V
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
                                        • CurtisC
                                          Philips 75pfl5704/F7 No sndby power
                                          by CurtisC
                                          Hello everyone. I'm brand new to the group. I'm trying to fix this Philips 4K TV. I have minimal experience with most of this so forgive me if I don't understand half of what is posted on these forums. I'm trying to find my way through it.
                                          Basically I got the TV from a previous owner who said it just died on them. So I wasn't there when it broke. It will not power on, no lights, no backlight, no sound.
                                          The output of the power supply has a 27 pin connection to the main board. Pins 18-27 (labeled P-On+20v) are the only pins reading power at 12v each. The pins marked ALL+3.3v, which...
                                          04-01-2023, 11:53 PM
