Tv Philips 47PFL3188H/12 (chassis tpn10.1e la) No led No power
  • nomoresonys
    • 12276
    • U.S.
    Re: Tv Philips 47PFL3188H/12 (chassis tpn10.1e la) No led No power
    ok, so looks like the only thing working is injecting 3 volts, so if you can maybe slip both pin 2 and 3 out of the cable connector and apply 3 volts to each, might need to apply voltage to dim also.
    • fanaticgames
      • May 2017
      • 138
      • italy
      I will try now
      • nomoresonys
        • 12276
        • U.S.
        Thinking its a mainboard issue, the ps-on is being sent but the on/off is not, can you trace that on/off signal back thru the mainboard?
        • fanaticgames
          • May 2017
          • 138
          • italy
          Originally posted by fanaticgames
          I will try now
          same 3v on pin 2/3 the power supply works but the backlight doesn't turn on (I think you need a working motherboard for that)
          • nomoresonys
            • 12276
            • U.S.
            I think this powerboard should be able to start alone but I don't know how it's done, maybe it did start and just can't seem to get the backlight on voltage to kick in for some reason. It's an interesting problem, prolly easy for some of these guys to figure out.
            • nomoresonys
              • 12276
              • U.S.
              #26
              oh, with everything hooked up as normal, try the flashlight test, shine it on an angle if needed, hit the menu button on tv, see if you can see any text or anything.
              • fanaticgames
                • May 2017
                • 138
                • italy
                #27
                but there is no red power led on, the tv does not turn on
                • nomoresonys
                  • 12276
                  • U.S.
                  #28
                  try unhook backlight cable at powerboard, plug powercord in, see if you get a led on front.
                  • fanaticgames
                    • May 2017
                    • 138
                    • italy
                    #29
                    it doesn't work anyway
                    • nomoresonys
                      • 12276
                      • U.S.
                      #30
                      ok, go to the state where you are getting the 11.3, I think thats with everything connected right? then see what voltage you have at the the 2 big caps there, a probe on each leg, check them both.
                      • fanaticgames
                        • May 2017
                        • 138
                        • italy
                        #31
                        the voltage is there, honestly everything seems to be there, on the motherboard I detect all the voltages 12v, 5v 3.3v
                        • nomoresonys
                          • 12276
                          • U.S.
                          #32
                          maybe check that cable, make sure you have continuity from end to end for pin 2, give it a wiggle too, in case it's broken somewhere.
                          • nomoresonys
                            • 12276
                            • U.S.
                            #33
                            how is the bridge rectifier, the 2 outside are measured in vdc, the 2 inside are measured in vac.
                            • nomoresonys
                              • 12276
                              • U.S.
                              #34
                              see what voltage you get at the backlight connector, I think you measure from plus to minus.
                              • nomoresonys
                                • 12276
                                • U.S.
                                #35
                                maybe check all the transistors on the poerboard, they're labeled starting with Qxxx, make sure none of the 3 pins are shorted to either of the other 2 pins.
                                • fanaticgames
                                  • May 2017
                                  • 138
                                  • italy
                                  #36
                                  I found the power supply board at a good price, when it arrives I replace it completely hoping there are no problems on the motherboard too
                                  • fanaticgames
                                    • May 2017
                                    • 138
                                    • italy
                                    #37
                                    always better to follow first impressions, it's a motherboard problem, even with the new power supply it's the same, I'll try to repair that or look for a second-hand motherboard
                                    • GMAN6325
                                      Gman6325
                                      • Mar 2023
                                      • 16
                                      I'm pretty sure the 3.6v is your stby voltage. I would try jumping the 3.6v to the on/off pin. I bet that the main board isn't sending signal to on/off pin to turn it on. I just had this issue on a Samsung. Ended up being the CPU on mainboard
                                      • fanaticgames
                                        • May 2017
                                        • 138
                                        • italy
                                        #39
                                        But I don't even have the red standby led
                                        • bohaboha
                                          • Nov 2012
                                          • 1017
                                          • sweden
                                          #40
                                          Hi is the problem solved ?
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
                                          • CurtisC
                                            Philips 75pfl5704/F7 No sndby power
                                            by CurtisC
                                            Hello everyone. I'm brand new to the group. I'm trying to fix this Philips 4K TV. I have minimal experience with most of this so forgive me if I don't understand half of what is posted on these forums. I'm trying to find my way through it.
                                            Basically I got the TV from a previous owner who said it just died on them. So I wasn't there when it broke. It will not power on, no lights, no backlight, no sound.
                                            The output of the power supply has a 27 pin connection to the main board. Pins 18-27 (labeled P-On+20v) are the only pins reading power at 12v each. The pins marked ALL+3.3v, which...
                                            04-01-2023, 11:53 PM
