Hisense 50P6
  • viewerau
    • May 2020
    • 305
    Re: Hisense 50P6
    Thanks ruckusman.....I saw the information and the red circled diodes in your other post.
    So far, 5 mobs from AliExpress and Ebay have told me that they don't have the cable/ribbon with the same written specs.
    If I get to the set still not responding after all the effort others have put in for me so far, then I guess that I just have nothing to lose in trying to remove those diodes.
    I am not the smartest with a soldering iron, but do I just heat the iron and hit the solder on the rear of the diodes to get them to come off?
    Thanks for thinking of me....cheers
    Signature:Seemingly hopeless tv fixer
    • ruckusman
      • Jan 2009
      • 26
      #142
      Re: Hisense 50P6
      I predict that if you check them, you will likely have a short as I did.
      Those components prevented my unit from displaying a correct image, I had precisely the same symptoms as you, the lines up the screen.
      You'll need a magnifiying glass to see the solder point to test them.
      The centre pin is ground on both sides - all of the others pins 1, 2, 4, 5, 6, 7, 9 and 10 should not go to ground in a short circuit.
      The diodes are tiny SMD components, for the time and effort that you've put in it's worth getting a hot air pencil, they aren't too expensive nowadays.
      I have one similar to this one, from well over a decade ago, when I first got it I found the temperature as tested to be very accurate, it has served me well.
      https://www.aliexpress.com/item/1005004961381060.html
      Others may have other recommendations.
      You can trim your cable by just a few Millimetres if you're careful.
      Like in that video you posted, remove the blue plastic, then carefully in several passes cut the few milllimetres where the tracks have lifted, then reattach the blue plastic stiffener.
      Once you've achieved that, I would remove the t-con, insert that end carefully, close the clip and do not remove that cable end again.
      • viewerau
        • May 2020
        • 305
        Re: Hisense 50P6
        Thanks a lot....what setting do you use on an elcheapo multimeter (no beep function), and is the power to be off, and ribbons undone from tcon?
        Lastly, the ribbon that is damaged cannot be shortened, as how it is now, there is no play between connections....the only way to do it, would be to unscrew my tcon from its existing position, and somehow mount if further down, and not in the existing place
        • ruckusman
          • Jan 2009
          • 26
          #144
          Re: Hisense 50P6
          Leave the ribbons connected to the t-con, then you can use the TV back panel metal as ground.
          It makes it much easier as the diodes are so small, you don't want to be managing two multimeter leads whilst trying to touch each pin on the diodes and only one pin at a time if possible.
          Meter set to diode test if you have one, that may give you a red led indication.
          Otherwise the lowest resistance value and if it's short circuit to ground you will get zero ohms resistance.
          Have you gone to a local TV repairer that keeps good parts from unrepairable TV's as spares to see if they have one?
          • viewerau
            • May 2020
            • 305
            Re: Hisense 50P6
            I am again blessed. The person whom supplied me with the donor boards has been able to grab the two ribbon cables for me
            I am fortunate to have his assistance.
            They are in the post to me, and I will respond here in due course.
            • viewerau
              • May 2020
              • 305
              Re: Hisense 50P6
              Strips arrived this afternoon....hopefully try tomorrow.
              • viewerau
                • May 2020
                • 305
                Re: Hisense 50P6
                OK...
                My new findings.
                With power disconnected...
                Fitted new strips to go between t-con and edge strips
                1)Obtained backlights only, no picture or stripes on tv
                I then turned off, and disconnected the strip between the tcon and the edge board that feed the right side when looking at the tv
                I connected the power
                1)No change, backlights only, no picture or stripes on tv
                I then powered off again, reattaching the right hand ribbon to the edge board, and unclipped the strip feeding the left hand of the tv.
                1)Obtained backlights again, then the picture changed to these images, cycling through all the time, in a slow fashion.
                In every instance, as the tv responded to the remote to turn it on, the red standby light flashes 17 times on start up.
                The pictures attached show what happened on the screen when the left hand ribbon was disconnected from the tcon board.
                Doing some other reading, many sites suggest I check the VGH/VDD/VGL levels on the tcon, with strips on and off to the edge boards, to try to ascertain whether their is a short on the panel from a low/missing VGL. Thus I have soured my tcon board looking for these test points, but cannot find them. Does this find like I should be trying this as well, but what happens when I can't find them on the tcon boaard?
                So different reactions to my initial tests, but am still at square one....STUCK.
                • ruckusman
                  • Jan 2009
                  • 26
                  #148
                  Re: Hisense 50P6
                  17 flashes is normal, mine does that when working properly.
                  Your symptoms are similar [identical] to mine.
                  I scoured my t-con for errors [incorrect voltages - one was a negative voltage source, which was correct and near zero, two others with effectively zero voltage which was protection mode - the incorrect voltages on the t-con was a symptom of the blown diodes, NOT the actual cause of display issues], you can measure the voltages at each inductor but I suspect you're dealing with blown diodes also.
                  Check my thread again for the details.
                  Now do you have u-ribbons?
                  Meaning are there two separate boards on each side feeding the screen [4 in total].
                  If so you can try leaving BOTH t-con connectors installed and unplug the u-ribbons between the edge connection boards one at a time.
                  For me this was inconclusive as I didn't get an actual picture, BUT I did get the lines up the screen whereas I'd only had backlights only previously.
                  My diodes on the edge connection boards were on the end of the left and right outer end connection boards - you'll need a magnifying glass to see them, as although they've got 10 pins [connections] they are the size of a flea, literally.
                  Mine were both labelled D001, there may be more than one diode on your outer edge boards - check them all if there are.
                  Remember the centre pins [upper and lower] on the TVS protection diodes are ground and any of the other 8 pins which goes to ground is a short.
                  With one blown diode removed and the other outer edge board u-ribbon disconnected, I still didn't get a correct image, then once I'd removed the second blown diode all was well.
                  I was expecting to have to deal with other blown components, so that was pleasant surprise.
                  good luck
                  • viewerau
                    • May 2020
                    • 305
                    Re: Hisense 50P6
                    Thank you rucksman.
                    I don't have the edge boards fully exposed, as the bottom section of the bezel is still in place.
                    I can see two of the boards connected directly to the panel via that bonded tape, but perhaps there are two under the bezel as well.
                    I'll delve into those tomorrow and see what I can, and report back.
                    Thank you...everyone helping is greatly appreciated.
                    • viewerau
                      • May 2020
                      • 305
                      Re: Hisense 50P6
                      This is what I can see at present
                      • Diah
                        • Feb 2013
                        • 6397
                        Re: Hisense 50P6
                        with new ribbon cable. if you do the stand alone test.. do you have correct panel pattern color or not ?
                        i would suggest dont play with ribbon any more.... keep them plugged in to avoid damage them again.
                        • viewerau
                          • May 2020
                          • 305
                          Re: Hisense 50P6
                          Thanks Diah...do you mean to do this test again ...
                          if yes then do the test i mentioned...
                          feed the F1 on T-CON 12V from power boards while the LVDS always disconnected from T-CON side... tell us what do u have on screen
                          • viewerau
                            • May 2020
                            • 305
                            Re: Hisense 50P6
                            Sorry, I just realised that post #150 shows a different t-con image than what is mine.
                            I got that image off the net.
                            This is my board.
                            Maybe the vgh or vgl has to be on the edge boards and not the tcon?
                            If I wanted to try a tape method to see what that would do, which pins would I need to block off on either tcon strip?
                            • ruckusman
                              • Jan 2009
                              • 26
                              #154
                              Re: Hisense 50P6
                              This is my board.
                              That's your 'edge' boards in that shot [I assume that shot is inverted] - they are connected to the t-con by the ribbon cables you've been having issues with and they run along the edge of the screen.
                              Find the protection diodes on those edge boards and check them for short circuit to ground.
                              • viewerau
                                • May 2020
                                • 305
                                Re: Hisense 50P6
                                Thank you.....
                                2 questions please...
                                1)How do you remove the speakers that are seemingly fixed with blue round fixings shown in post 5, image 1
                                2)When the edge board is fully exposed and I measure the diodes you say, do I do this with power off/standby/power on?
                                • viewerau
                                  • May 2020
                                  • 305
                                  Re: Hisense 50P6
                                  This is the end of each board..which to check?
                                  I have found I have to have all power off when checking a diode.
                                  Mine appear to be marked 4267H, and there are two of each marked DOO3 and DOO4
                                  How do I actually check them please?
                                  Thank you
                                  • viewerau
                                    • May 2020
                                    • 305
                                    Re: Hisense 50P6
                                    I am unsure if I am doing things right or not, but tried to help myself again, so I could offer up some results for comment.
                                    Boy are those diode things small!
                                    At this stage I just ensured the power was off and I got my cheapo multimeter into diode mode.
                                    With the edge boards in place (it'd probably be easier with them out of their clips) I found that by trying to put the negative probe to the top of the array, and hoping to make a connection to opposite legs with the positive probe, I find I did get some readings.
                                    The 4267H on the board that is last, which is for the right side of screen, they both gave gave numbers around 1433-1436 and then dropping, and the one's on the right, gave numbers of about 1000 and dropping.
                                    I will try again tomorrow, as it was very difficult to try place a bright led light on the board, position a magnifier glass, and also place the probes on correctly, as the bottom legs were hard to see whilst it was all held in place.
                                    Should each pair of legs give a reading, and is it necessary to measure them with the probes set all one way (ie negative to top and positive to bottom), or both ways. Should each set of legs show the same values etc
                                    Thank you
                                    • ruckusman
                                      • Jan 2009
                                      • 26
                                      #158
                                      Re: Hisense 50P6
                                      They're tiny aren't they...
                                      Leave the edge boards all connected up, including all t-con ribbons.
                                      Don't worry about the diode function, just test each pin for short to ground.
                                      They are 5 connections going top to bottom on them - the centre pins are going to ground - top and bottom - use those pins to check the continuity to ground on the meter.
                                      So if you can put one lead to the metal chassis of the screen [ground] and test the two outer pin pairs, one at a time across both the top and across the bottom.
                                      Check my thread for which pin was short, it was pin 2 - counting left to right with the type right way up.
                                      Yours may be different if there's a short on another pin, it was just one short, one short on each of two diodes on my unit that stopped it working.
                                      • viewerau
                                        • May 2020
                                        • 305
                                        Re: Hisense 50P6
                                        Hi all.
                                        I have not had time to try to fix this issue, however, user ruckusman sent me some detailed information regarding the removal of one of the diode chips (D004) from the edge board.
                                        I did this today, instant success, in that everything boots up and it now displays everything.
                                        The only hassle I have is to now work out why I get some intermittent lines flashing on/off at the bottom of the screen.
                                        Well done ruckusman....you were 100% spot on with your analysis.
                                        Video https://streamable.com/6rcwwz
                                        • viewerau
                                          • May 2020
                                          • 305
                                          Re: Hisense 50P6
                                          Just in case you cannot see the video.
                                          • Prott
                                            [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                            by Prott
                                            Hello dear badcappers!
                                            The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                            Backstory:
                                            After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                            If there is a way to narrow down which memory module is faulty it would make my life much...
                                            06-03-2024, 12:05 PM
                                          • Kiberge
                                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                                            by Kiberge
                                            HI guys!
                                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                            04-22-2024, 11:28 AM
                                          • Diah
                                            Hisense 2020 ULED 55U8QF Little Factory Fault end with Big damage !!
                                            by Diah
                                            this set delivered today to my home to inspect and write report to company sold this set 2 weeks before and the customer reject it as it had fault at picture. its look the transport damage happened during the customer sending it back to the company or on the way to me.. who care its not may fault. LOL
                                            this ULED had full array LED backlight. from first look after remove the back cover with dozens of screws as 2 part cover. i found the ribbon cable at the panel side they was not correct fitting in place ( see photos before take the T-CON driver boards & After.) my wounder which...
                                            11-14-2020, 01:43 PM
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
