Hisense 50P6
  • viewerau
    • May 2020
    • 305
    Re: Hisense 50P6
    Thanks Diah....testing asap...Mothers Day in Australia, so tied up with family at the moment....
    Signature:Seemingly hopeless tv fixer
    • viewerau
      • May 2020
      • 305
      Re: Hisense 50P6
      May I please ask a question before I conduct the test with only 1 working ribbon please? I am afraid to do this wrong, and then be remorseful for not asking first.
      You said....
      Originally posted by Diah
      after you approved the LVDS and both ribbon are fine... do this test ( in order to know which half of screen are good )
      1- disconnect LVDS from main boards side... fix your jumper 12 V to T-CON fuse ( use yours original T-CON )t
      2- disconnect only one ribbon cable ( from T-CON side) of the half screen which it show at yours Video bright line
      turn on the set and upload photo
      if- its clear color pattern or one color ... turn off the TV wait little to discharge.. then reverse the ribbon ( connect the bad side and disconnect the good one ) Note : always disconnect ribbon from T-CON side then turn on and let see photo too
      in case both side are not good displaying..... try do the test same way with yours donor T-CON.
      Disconnect the main LVDS cable at the mainboard end
      If I disconnect the one remaining main ribbon cable cable at tcon end,and the other end connected to the edge boards, then connect the jumper between the 12v on p/s rail and the fuse marked P on the t-con, and then power the set, should that give me one picture on one side or the other, and then.....
      If I totally disconnect that ribbon cable and move it to the other side of the tcon, should that ribbon be disconnected at tcon side, connected at edge board side, then connect the jumper between the 12v on p/s rail and the fuse marked P on the t-con, and then power the set, should that give me one picture on one side or the other, and....
      MY APOLOGY FOR ASKING, BUT I DO NOT WANT TO STUFF UP AGAIN
      SORRY.
      • Diah
        • Feb 2013
        • 6397
        Re: Hisense 50P6
        yes. you are correct.
        • viewerau
          • May 2020
          • 305
          Re: Hisense 50P6
          Well, nothing happened...
          Backlights were all lit as per usual, and looking at the front of the screen, the usual dim looking screen.
          No change noted on swapping cables.
          I thought this may be the case, as with nothing connected to the tcon board except the unconnect ldvs at the mainboard, my head was tying to tell me that nothing much would work, but as usual, I am probably hopelessly wrong?
          • viewerau
            • May 2020
            • 305
            Re: Hisense 50P6
            Is it time to give in?
            • ruckusman
              • Jan 2009
              • 26
              #126
              Re: Hisense 50P6
              My apology for being a bit slow with this reply.
              Before I did anything I checked to see if the pin on the PS had 12v when turned on...it did.
              I then turned it all off and then put the lead on the 12v PS and onto F1 on the t-con and the screen went bright white with no lines.
              then the issue at MB. don't play with T-CON or screen any more..
              remove the black heat sink from the CPU and upload high resolution focused photos of the MB from up and down side..
              @Diah, can I ask, I have a similar screen, different model and boards, however I have just completed this 12v only connection to the t-con test and the screen didn't go white, it stayed dark.
              My Thread here
              https://www.badcaps.net/forum/showthread.php?p=1239967
              Does this mean the issue is more likely with the t-con?
              Is it possibly a firmware issue with the t-con?
              Something worth trying?
              thanks
              Glenn
              • Diah
                • Feb 2013
                • 6397
                Re: Hisense 50P6
                you need first to replace good ribbon cable.. with out ribbon its useless to test or repair
                • viewerau
                  • May 2020
                  • 305
                  Re: Hisense 50P6
                  Thanks again Diah,
                  I'm sorry, but I am hopelessly confused in the above reply...please forgive me for not understanding what to do at the moment.
                  In posts #117 and #120, if I have read these right, you said to do the test with just the one good ribbon, which I have done, and reported back on the results.
                  Now it appears you are saying that testing with just one ribbon was useless.
                  PLEASE..I try hard..what am I doing wrong?
                  Sorry for my continued asking.
                  • Diah
                    • Feb 2013
                    • 6397
                    Re: Hisense 50P6
                    i am not the manufacture of Hisense or the T-CON LOL.... i asked you to do test and the result was nothings.... it mean yours TV T-CON at stand alone mode .. will start working only if the panel complete connected.
                    • viewerau
                      • May 2020
                      • 305
                      Re: Hisense 50P6
                      I realise you are not manufacturer...just an ace helper.
                      I'll go and start to see if I can find out something about the TV T-CON at stand alone mode.
                      My guess is it must be the tv in standby, as both t-cons won't start it.
                      • ruckusman
                        • Jan 2009
                        • 26
                        #131
                        Re: Hisense 50P6
                        I think he meant that the t-con in standalone mode won't display anything [it doesn't have a standalone mode], it will only display something when connected to the main board also.
                        I recall he said something like that previously, related to firmware on the t-con.
                        Diah feel free to correct me if I am wrong.
                        • Diah
                          • Feb 2013
                          • 6397
                          Re: Hisense 50P6
                          wrong, stand alone will display colored pattern or white screen depend on T-CON type. but the panel should be connected with all ribbon so the t-CON will start working in this mode.
                          OP did test with just only one ribbon... because the other one damaged .. the result was nothings.. so his t-CON will start working in this mode only if all ribbon connected.
                          • viewerau
                            • May 2020
                            • 305
                            Re: Hisense 50P6
                            Does this mean I have to source another ribbon from somewhere, to move forward with further testing?
                            • Diah
                              • Feb 2013
                              • 6397
                              Re: Hisense 50P6
                              yes. i wrote to you at post #127
                              • viewerau
                                • May 2020
                                • 305
                                Re: Hisense 50P6
                                right now don't buy ribbon.. just do the test but be careful don't damaged the good one too....
                                later if you are at the right way again... will tell you how we can fix ribbon ( ONE TIME TRY PLUG IN )
                                I am so lost now...wasn't this post #120 telling me to test with just one ribbon?
                                Sorry I keep misunderstanding.
                                • Diah
                                  • Feb 2013
                                  • 6397
                                  Re: Hisense 50P6
                                  say thanks GOD you found later the damage ribbon.. who knows could be the issue too.
                                  • ruckusman
                                    • Jan 2009
                                    • 26
                                    #137
                                    Re: Hisense 50P6
                                    Thank you, now I understand firstly, that there is possibly a t-con standalone mode and what it might display; and
                                    For that standalone mode on his unit, both ribbons from the t-con to the panel must be connected; and
                                    All of this depends upon the particular t-con model.
                                    • viewerau
                                      • May 2020
                                      • 305
                                      Re: Hisense 50P6
                                      I see strips on AliExpress, however the numbers don't match...is it critical to have exactly the same numbers and description that is on the original?
                                      eg...this is similar, but different numbers
                                      https://www.aliexpress.com/item/1005004782849662.html
                                      • viewerau
                                        • May 2020
                                        • 305
                                        Re: Hisense 50P6
                                        I have found how to repair a strip, albeit, my existing lead would end up too short.
                                        This may help someone else though.
                                        https://youtube.com/watch?v=SNOzbpfSpec&feature=share
                                        • ruckusman
                                          • Jan 2009
                                          • 26
                                          #140
                                          Re: Hisense 50P6
                                          I've just succeeded in repairing mine.
                                          It may assist you with yours once you get the replacement ribbon cable.
                                          You can also trim yours shorter, BUT not as short as in the video you found.
                                          Jut a few millimetres of the end where the tracks have lifted may get it back to a working state.
                                          My solution was the removal of BOTH of the ESD diodes from the outer buffer boards.
                                          BOTH ESD diodes had a short circuit and both had to be removed for the TV to correctly display an image.
                                          • Prott
                                            [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                            by Prott
                                            Hello dear badcappers!
                                            The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                            Backstory:
                                            After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                            If there is a way to narrow down which memory module is faulty it would make my life much...
                                            06-03-2024, 12:05 PM
                                          • Kiberge
                                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                                            by Kiberge
                                            HI guys!
                                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                            04-22-2024, 11:28 AM
                                          • Diah
                                            Hisense 2020 ULED 55U8QF Little Factory Fault end with Big damage !!
                                            by Diah
                                            this set delivered today to my home to inspect and write report to company sold this set 2 weeks before and the customer reject it as it had fault at picture. its look the transport damage happened during the customer sending it back to the company or on the way to me.. who care its not may fault. LOL
                                            this ULED had full array LED backlight. from first look after remove the back cover with dozens of screws as 2 part cover. i found the ribbon cable at the panel side they was not correct fitting in place ( see photos before take the T-CON driver boards & After.) my wounder which...
                                            11-14-2020, 01:43 PM
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
