Hisense 50P6
Re: Hisense 50P6
It's just that your computer perceives files with the pkg extension as rar (you installed, checked the box so that these files can only be opened by the rar archiver).
If you need to quickly do this, then try on another computer.Last edited by lotas; 04-20-2023, 04:49 AM.Comment
Re: Hisense 50P6
Try Lotus solution, if still stuck maybe this, scroll down to manual update section: https://knowtechie.com/how-to-update...e-tv-software/Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Re: Hisense 50P6
manual update.......cannot do that nomoresonys as the tv is stuck with the lines on it, and I cannot see the menus.
I have uninstalled all my rar, onezip, etc apps...still won't let me move the file anywhereSignature:Seemingly hopeless tv fixerComment
Re: Hisense 50P6
Another tutorial there, he talks a lot but does go into detail, might help: https://www.youtube.com/watch?v=KjGDubuxhaYLast edited by nomoresonys; 04-20-2023, 05:19 AM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Re: Hisense 50P6
I think you are looking at the auto update part, the manual part is way down the list there but doesn't go into great detail.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Re: Hisense 50P6
Ok, so is that the first file after you extract? then you should be able to move that file to your usb drive, right?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Re: Hisense 50P6
Back to square one again.
The usb simply seems to be doing nothing.
I keep power unplugged, and drain the power by either holding down the tv or remote power button for 60 seconds.
I then keep holding the power button and plug in the power, holding, awaiting device notification or boot, but that never arrives.
I did also change the file name to upgrade_loader.pkg....no difference.
Tried either usb port...ditto
My luck with repairs is abysmal.
Are we at the end of any help now?
Thanks all.Signature:Seemingly hopeless tv fixerComment
Re: Hisense 50P6
1- usb formatted as FAT32 MBR mode
2- the first file with format .pkg dont extract it. just copy it on the stick
3- you may need to rename the file upgrade_loader.pkg in case didnt start
4- no need 60 second. as son you press power on RC and keep press plug the tv in wall
5-insert the USB at USB Ver2 ( black socket at the side of the TV
I am certain that this is what I have done.
I did not realise that you could not see the file, but it is as before, posted here again, and is file number 3
I did it all again
No change
I d/l it and it shows as usb_AA6501U.pkg
I transfer the file onto formatted FAT 32 stick
I plugged it to tv and it would not boot.
I removed usb, changed file name to
upgrade_loader.pkg
Reinsert to tv
All no go still
I do not know what/how to format is as FAT32 MBR mode
I look in google via search, and it says ....
"The first is to simply format the drive using the MBR format. This can be done in Windows by right-clicking on the drive in My Computer and selecting Format. In the Format dialog box, select the option to format the drive for MBR."
When I do this I only have the options
NTFS
FAT32 (default)
exFAT
In disk management it shows my usb as D 14.32GB FAT32 Healthy Primary Partition
It shows no errors.
Am I doing this right?
THANK YOU
EDIT...file ext only shows .pkg the once.Last edited by viewerau; 04-20-2023, 07:30 AM.Signature:Seemingly hopeless tv fixerComment
Re: Hisense 50P6
if you have srick smaller than 32Gb will be fine.. however to make MBR mode
open CMD on yours PC
write
Code:1- diskpart press inter disk part will start 2- list disk it will show you all disk on PC be sure to choice yours usb stick for example if it under disk 1 3- select disk 1 4- clean 5- convert mbr 6- create partition primary 7- active 8- list partition 9- select partition 1 10- format fs=fat32 quick 11- assign 12- exit 13- exit
Re: Hisense 50P6
Maybe that usb drive doesn't want to play nice with your tv, try a different one, you have any less than 8gb?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Re: Hisense 50P6
lotas, Diah,nomoresonys...
I followed Diah instructions exactly, thanks for the very clear instructions.
I used a 4GB usb stick this time.
Loaded it with the file, changed it's name to upgrade_loader.pkg
Inserted it to Hisense usb port, press power on remote, await boot to let go of power button
Unfortunately it still does as it did before, going straight into the coloured vertical lines, with nothing thereafter.
Tried a number of times, as well as trying in both of the Hisense usb ports.
Gosh, it seems so simple a thing to do, but this Hisense is simply not behaving for us.
Anything else we can try do you think?
Thank you everyone.Signature:Seemingly hopeless tv fixerComment
by ProttHello dear badcappers!
The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
Backstory:
After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
If there is a way to narrow down which memory module is faulty it would make my life much... -
by KibergeHI guys!
I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when... -
by Diahthis set delivered today to my home to inspect and write report to company sold this set 2 weeks before and the customer reject it as it had fault at picture. its look the transport damage happened during the customer sending it back to the company or on the way to me.. who care its not may fault. LOL
this ULED had full array LED backlight. from first look after remove the back cover with dozens of screws as 2 part cover. i found the ribbon cable at the panel side they was not correct fitting in place ( see photos before take the T-CON driver boards & After.) my wounder which... -
by RictechHello everyone. 😀
As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
There are no devices that have exploded or otherwise show signs...-
by howardc64
- Prior owner tried a replacement main board. No difference.
- Samsung 2x red blinking standby LED = panel fault
- Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
- Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
- Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
- Loading...
