Hisense 50P6
  • viewerau
    • May 2020
    • 305
    Re: Hisense 50P6
    Thanks Diah
    Signature:Seemingly hopeless tv fixer
    • notallbad
      • Oct 2012
      • 1190
      Re: Hisense 50P6
      you may find the 17 blinks is normal and not an actual fault indication, assuming this is a smart tv.
      Under normal operation when power is 1st applied it will prob flash 17 times, then after from stby will prob only flash once or twice.
      • viewerau
        • May 2020
        • 305
        Re: Hisense 50P6
        Possible I suppose, but seems excessive to me if it is a normal thing.
        Cannot find any firmware for any Hisense TV on their Australian site, so I have sent an email to their support site asking them to provide me with a download or link to the firmware.
        • Diah
          • Feb 2013
          • 6397
          Re: Hisense 50P6
          No way at cold start TV blink 17 time... the most count will be 4-5 as each blink described as one script lunch from Firmware.. this why it could be there are cliché at firmware or emmc fault.
          • viewerau
            • May 2020
            • 305
            Re: Hisense 50P6
            Still no response from Hisense Australia re some firmware.
            I have sent a second request.
            • Diah
              • Feb 2013
              • 6397
              Re: Hisense 50P6
              who in urgent need to repair his Hisense ... need to call them... so thier understanding.
              Call them and ready yours serial lable as printed on the back of the TV.
              • viewerau
                • May 2020
                • 305
                Re: Hisense 50P6
                OK...will ring them next business hours.....thanks
                • viewerau
                  • May 2020
                  • 305
                  Re: Hisense 50P6
                  I have been in touch with Hisense via phone.
                  As advised by Diah, they asked for the serial number, my name, address, model number, email addy eyc.
                  They say it will take them 2-3 business days, as they send updates of firmware only of an AM.
                  So I will update everyone in about 5 days I guess, as the weekend is nearly here in Australia.
                  Thank you.
                  • viewerau
                    • May 2020
                    • 305
                    Re: Hisense 50P6
                    I have just received the email. with the updated firmware.
                    Instructions are:
                    The software provided is the latest version available. It should only be used for updating
                    HISENSE television units with matching Model and Serial number.
                    Instructions:
                    1. When TV is on, unplug Power Cord on the back of TV.
                    2. Plug in USB stick with Upgrade Firmware into TV USB port
                    3. Hold the POWER button on remote control and at the same time turn on the
                    TV by connecting the Power Cord back. Release POWER button on remote
                    control only when you see ‘Software Updating' on TV.
                    4. TV will then update automatically, and restart when update complete
                    Important: Do not interrupt the update; do not use the remote control and
                    keep the unit ON all the time.
                    5. Remove the USB memory key.
                    6. Press Quick Setup button on remote, go to
                    Settings -> Support- >Restore To Factory
                    Default. Then follow the installation guide to finish setting up the TV.
                    My problems...
                    Ala
                    3) with no remote, I figure I just use the sets main power button?
                    6) No remote to press "Quick setup,Settings -> Support- >Restore To Factory Default.
                    I do have a Harmony 300 remote, so I went to Logitech, entered the Hisense 50P6 info , and it located a code, I downloaded it onto the remote, but it does not have any assignments for buttons....
                    MENU, QUICK SETUP, FAST ACCESS TO ALL APPLICATIONS, HOME.
                    The original remote model from Hisense is EN2B27.
                    I have raised a ticket number with Logitech requesting if any other codes they have for Hisense tv's have these remote functions, and am awaiting their response.
                    Thank you.
                    • Diah
                      • Feb 2013
                      • 6397
                      Re: Hisense 50P6
                      did you played the firmware..... many android apk are free can handle full rc on all model. just need mobile with IR sender.... they are better than any other universal RC in market.
                      • nomoresonys
                        • 12206
                        • U.S.
                        #51
                        Re: Hisense 50P6
                        Remotes: https://www.ebay.com.au/sch/i.html?_...acat=0&_sop=15
                        • viewerau
                          • May 2020
                          • 305
                          Re: Hisense 50P6
                          Sorry for the long delay.
                          I got hold of the firmware from Hisense Australia, transferred it to the USB stick and inserted into the USB port of the Hisense
                          Held down the power button for 60 seconds, then turned on at the PowerPoint, held power on/off for another 60 seconds, however, all that keeps happening is that the screen turns on displaying these lines again
                          Tried many times, but it just won't boot into the USB update
                          The diffence now though, is that the power button no longer does the 17 blinks, and now does 4 as it turns on and keeps showing the lines, with the lines slowly shifting to the left of the tv as you look at it
                          • viewerau
                            • May 2020
                            • 305
                            Re: Hisense 50P6
                            Missing pictures
                            • viewerau
                              • May 2020
                              • 305
                              Re: Hisense 50P6
                              I have tried all those suggestions that you see on google for resetting the tv...eg, hold down power button, disconnect etc....none of them does anything and all I am left with is that the telly turns on, goes to these lines, and responds to nothing other than the power on/off button on the remote.
                              I am using a Harmony remote, and Logitech sent me an exact file to synch onto it.
                              The file on the usb stick simply won't boot.
                              Have I reached the stage where I need to give in?
                              ps...this is what I am doing with update firmware ......I wonder if I am doing it right?
                              https://i.imgur.com/TIf0fos.jpg
                              • viewerau
                                • May 2020
                                • 305
                                Re: Hisense 50P6
                                Here is some firmware if it helps someone?
                                https://hisenseaus-my.sharepoint.com...6%2FJ0423&ga=1
                                • lotas
                                  • Jan 2016
                                  • 4651
                                  • Russia
                                  #56
                                  Re: Hisense 50P6
                                  Wrong!
                                  • Diah
                                    • Feb 2013
                                    • 6397
                                    Re: Hisense 50P6
                                    1- usb formatted as FAT32 MBR mode
                                    2- the first file with format .pkg dont extract it. just copy it on the stick
                                    3- you may need to rename the file upgrade_loader.pkg in case didnt start
                                    4- no need 60 second. as son you press power on RC and keep press plug the tv in wall
                                    5-insert the USB at USB Ver2 ( black socket at the side of the TV
                                    • viewerau
                                      • May 2020
                                      • 305
                                      Re: Hisense 50P6
                                      Originally posted by lotas
                                      Wrong!
                                      It would be appreciated if you could tell me the right way?
                                      EDIT
                                      Thanks Diah
                                      • viewerau
                                        • May 2020
                                        • 305
                                        Re: Hisense 50P6
                                        When I right click the file,(my link) it will only allow these options
                                        Preview
                                        Download
                                        Copy to
                                        Details
                                        If I select Copy to...I can't seem to save it
                                        If I download it, it turns into this zip folder
                                        If I extract then, it just comes back with all those folders again.
                                        My apology for not understanding how to simply grab that one file
                                        HELP....
                                        • nomoresonys
                                          • 12206
                                          • U.S.
                                          #60
                                          Re: Hisense 50P6
                                          How bout, left click hold, drag and drop, send to should also work.
                                          • Prott
                                            [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                            by Prott
                                            Hello dear badcappers!
                                            The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                            Backstory:
                                            After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                            If there is a way to narrow down which memory module is faulty it would make my life much...
                                            06-03-2024, 12:05 PM
                                          • Kiberge
                                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                                            by Kiberge
                                            HI guys!
                                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                            04-22-2024, 11:28 AM
                                          • Diah
                                            Hisense 2020 ULED 55U8QF Little Factory Fault end with Big damage !!
                                            by Diah
                                            this set delivered today to my home to inspect and write report to company sold this set 2 weeks before and the customer reject it as it had fault at picture. its look the transport damage happened during the customer sending it back to the company or on the way to me.. who care its not may fault. LOL
                                            this ULED had full array LED backlight. from first look after remove the back cover with dozens of screws as 2 part cover. i found the ribbon cable at the panel side they was not correct fitting in place ( see photos before take the T-CON driver boards & After.) my wounder which...
                                            11-14-2020, 01:43 PM
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
