Technika 32E21B Usb Firmware
  • RAZ777
    • Feb 2022
    • 18
    • uk
    Hi guys,
    Wondering if anyone would have the usb firmware for this tv?
  • lotas
    • Jan 2016
    • 4752
    • Russia
    Re: Technika 32E21B Usb Firmware
    If this is a simple TV (not Smart), then it is unlikely that the manufacturer released an update for it via usb, but what is wrong with the TV?
    • RAZ777
      • Feb 2022
      • 18
      • uk
      Hi
      These are renowned for corrupting firmware, sometimes starts, but normally sticks in standby- 100% positive this is the fault.
      Did try similar firmware found for blauplunkt(same main brd) now starts ea time but screen different /corrupt.
      I know if I get the correct one it will take it and work.
      Its just finding someone who has it I suppose.
      • lotas
        • Jan 2016
        • 4752
        • Russia
        Do you have a TP.MSD306.P72 motherboard? And the panel (matrix) you have is LC320EUN?
        If you updated with firmware via usb from blaupunkt, what was the name of the update file? "Merge" ?
        • RAZ777
          • Feb 2022
          • 18
          • uk
          Hi
          Its the TP.MSD309.BP85 motherboard, that does sound like the screen but I will have to look it up to be sure.
          It was firmware for this M/B but blau I loaded- just was different screen(was all I could find in days of searching- thought if lucky screen might just be inverted and reset in engineer screen but not that lucky.
          • lotas
            • Jan 2016
            • 4752
            • Russia
            Yes, now, in order to select the firmware, you need to know the exact motherboard number and panel number (since the panels have HD and FULL HD resolution).
            • RAZ777
              • Feb 2022
              • 18
              • uk
              Hi
              just rechecked there- thats the correct board model & the screen is LC320EUN-SFM1
              • RAZ777
                • Feb 2022
                • 18
                • uk
                I searched days for this using the TP.MSD309.BP85 board & LC320EUN screen numbers couldn't find this usb software anywhere.
                Anyone who may have this software would be a very welcome help with this?.
                Thank you.
                • RAZ777
                  • Feb 2022
                  • 18
                  • uk
                  Hi
                  Do you know where it is possible to select this firmware from?
                  • RAZ777
                    • Feb 2022
                    • 18
                    • uk
                    If I even could get the usb file for a different make tv that has the same M/B & screen I would not mind if only the splash screen/manufactures start up name was different?
                    • Diah
                      • Feb 2013
                      • 6435
                      from what i know.. this MB most the time get defect at DC to DC Req. which support RAM / CPU low voltage 1-2 -1.3V.. i would first follow the low V circuit.
                      • RAZ777
                        • Feb 2022
                        • 18
                        • uk
                        Hi
                        Thanks for your reply, I am 100% certain its the firmware, its listed as a common fault, plus the firmware I found worked/cured the startup/standby problem - just wrong screen type.
                        • lotas
                          • Jan 2016
                          • 4752
                          • Russia
                          I found the firmware from Q.Bell QXT.32KF TP.MSD309.BP85 (LC320EXJ-SE E1) for the programmer, but the last letters in the panel number are slightly different.
                          • RAZ777
                            • Feb 2022
                            • 18
                            • uk
                            Hi
                            Thank you, I do not have the programmer, does it have it for usb?
                            • lotas
                              • Jan 2016
                              • 4752
                              • Russia
                              It will be possible to try via usb, here it will be necessary to correctly rename the file so that the update via usb goes, post your update file that you installed on the TV (from Blaupunkt).
                              • RAZ777
                                • Feb 2022
                                • 18
                                • uk
                                This was the one but wrong screen.
                                • lotas
                                  • Jan 2016
                                  • 4752
                                  • Russia
                                  Ok, try.
                                  • RAZ777
                                    • Feb 2022
                                    • 18
                                    • uk
                                    Ok, try.
                                    Lotas Thank you.
                                    I had one of those files before, tried again both, but didn't work.
                                    Still same screen corruption- flashes on initially then goes black.
                                    (I just remember the remote sequence/buttons to access usb upgrade).
                                    Looks like it maybe for the skip.
                                    • lotas
                                      • Jan 2016
                                      • 4752
                                      • Russia
                                      But at the moment, the native remote control may not work or not correspond to the buttons, since you changed the firmware for blaupunkt and the code encoding could change in the firmware.
                                      • RAZ777
                                        • Feb 2022
                                        • 18
                                        • uk
                                        Hi
                                        yes I had thought of that but as I press the part for upgrade from usb it reads the usb/the usb led flashes.
                                        If not that I feel its lost as cannot see the screen.
                                        • zklgfs
                                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                          by zklgfs
                                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                          08-11-2025, 02:14 PM
                                        • gurj1979
                                          Ubiquiti firmware help. US-8-150W POE
                                          by gurj1979
                                          Hi guys.
                                          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                          Got New chip and writes good.
                                          THE PROBLEM...
                                          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                          Does anyone have a Good Firmware I can have?...
                                          07-22-2024, 05:13 PM
                                        • wattage
                                          by wattage
                                          Hello Badcaps Community,
                                          07-13-2025, 04:41 PM
                                        • sikocan
                                          NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                                          by sikocan
                                          I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                                          However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                                          01-11-2024, 01:47 AM
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
