Pinout of LG 4 pole 3.5 mm component video cables?
  • ohren
    • Mar 2015
    • 119
    • Sweden
    I hope this forum is appropriate to ask about pinouts for tv manufacturers.
    So I just acquired an LG 42LE530N and noticed it uses a 3.5 mm jack for component video. To confirm component input working I dug out a 4 pole 3.5 to RCA camcorder cord and tried all configurations before realizing that GND must not be on pin 3.
    Is there a standard pin out for this? Or is it LG specific?
    What is it?
    It's easy enough to find pin outs of 3.5 mm composite AV, but couldn't seem to find any for component video*. Maybe I looked in the wrong places.
    * Technically I found two on pinoutguide.com, but they didn't sound very standard (https://pinoutguide.com/Audio-Video-...s_pinout.shtml).
  • lotas
    • Jan 2016
    • 4621
    • Russia
    Re: Pinout of LG 4 pole 3.5 mm component video cables?
    component video plug
    https://www.huoltopalvelu.com/LG-tel...mm-GBR-adapter
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4347
      • Italy - Milan
      component is used in America, not in Europe, may you are searching for composite (yellow plug)?
      • lotas
        • Jan 2016
        • 4621
        • Russia
        Used everywhere in old technology and AV, S-video, Component video.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4347
          • Italy - Milan
          ok not in italy then..
            • 12206
            • U.S.
            Oh no there's no component video in italy, only on this new tv here right or are they wrong, don't think so, so you are WRONG d. pee https://www-sinergy--store-com.trans...en&_x_tr_hl=en
            • ohren
              • Mar 2015
              • 119
              • Sweden
              Originally posted by lotas
              Yes, that seems to be an example of a product whose pinout I'm wondering about. I should've mentioned I was asking about YPbPr.
              Component video works fine whenever I use it. Must be a glitch in the matrix where I live.
              Anyway there wouldn't be much point in asking for the pinout of composite video — it's one way or the other. With YPbPr there are 24 permutations assuming a common GND.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4347
                • Italy - Milan
                I can tell you the one on my Panasonic adapter:
                --------,__ __ __ __
                ........!__!__!__! __)
                From left (handle) 1 ring Red, 2nd ring GND, 3rd ring Green, Tip Blue
                • R_J
                  • 9551
                  Does this component input have one or two jacks, IE: one for audio and one for video?
                  If it is only one jack it could be a 5pin + shield
                  • ohren
                    • Mar 2015
                    • 119
                    • Sweden
                    Thanks for taking the trouble! When you say Panasonic adapter, do you refer to an adapter for your Panasonic TV, or for your Panasonic <something else>?
                    Anyway, that's unfortunate, since GND is in the same place as the one I already tried.
                    It's two jacks; one for YPbPr video and one for stereo audio. I'm simply making the assumption of 4 pole + 3 pole. Haven't ever come across the kind of 3.5 mm plug you're describing — sounds like a monstrosity.
                    They naturally took care to show the video cord plugged into the audio jack in the illustration in the manual, as if it weren't complicated enough for the average user
                    • R_J
                      • 9551
                      Have you tried using the sleeve as ground and the tip as green (as provided in your 1st post link)?, This should give a B&W picture if it works, then you can connect the blue and red
                      The jack I provided in #9 was from the 42le530n (LD01D chassis) service manual
                      • lotas
                        • Jan 2016
                        • 4621
                        • Russia
                        Pinout
                        • ohren
                          • Mar 2015
                          • 119
                          • Sweden
                          No but I did now, and yes, that was correct. I didn't think of just trying green, thanks! Otherwise, the prospect of manually holding RCAs tips to sleeves and keeping track of it all wasn't very appealing
                          Pinout
                          Thank you very much for taking the trouble! More than I could've asked for.
                          Now I won't have to second-guess whether the manual is in fact correct (it is NOT — the jack labels are correct), whether the two jacks are are 3, 4 or 5(?) poles, and which is Pb and which is Pr.
                          For the next person:
                          Both jacks are 4 pole. Component plug (as T,R,R,S) is: Y, Pb, Pr, GND. Audio in is shared with composite in which is V, L, R, GND, meaning that you're required to get another 4 pole adapter just to connect stereo audio. Awkward design.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4347
                            • Italy - Milan
                            i mean for Panasonic lcd tv, it has a double plug, the other smaller is for audio
