Samsung UE70TU7100 - flickering horizontal lines
  • mrsith
    • Mar 2021
    • 146
    • Wielka Brytania
    Re: Samsung UE70TU7100 - flickering horizontal lines
    Originally posted by Davi.p
    with frequency meter...?
    Regular diode mode was enough to locate ckv pins area. Tried covering them in various combinations - every single pin, one by one, in pairs, all of them etc. I've been getting various results but never a perfect picture. Was getting close, but not close enough.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4327
      • Italy - Milan
      i have seen other users that obtained good quality covering 13 pins or more..
      • mrsith
        • Mar 2021
        • 146
        • Wielka Brytania
        After playing with tape for countless hours I have finally managed to find the right amount of pins to cover. Indeed I was covering not enough of them. Thanks for your support people!
          • 12196
          • U.S.
          Nice work, so how many pins covered was the magic number?
          • mrsith
            • Mar 2021
            • 146
            • Wielka Brytania
            Exactly 11. Picture wasn't 100% perfect but good enough.
            • Ihandyrepair
              Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
              by Ihandyrepair
              Hi guys
              I just started fixing 4k TV few months ago. so I am still learning a lot
              I got this tv from friend complaint is ghosting or horizontal lines on image.
              never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
              then it started to show the ghosting white image.
              I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
              it has 3 thin small boards at the bottom of the...
              12-05-2022, 04:18 PM
            • Rubenlily
              Samsung QE50Q67TAU - horizontal lines
              by Rubenlily
              First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
              I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
              I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
              I'm no expert but I've done the tape...
              08-16-2023, 01:12 PM
            • x_orange90_x
              Samsung UN46C8000XFXZA vertical bars/horizontal lines
              by x_orange90_x
              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
              09-04-2023, 12:09 PM
            • arctor
              samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
              by arctor
              hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
              04-26-2025, 05:22 AM
            • x_orange90_x
              Samsung UN46C8000XFXZA Horizontal lines
              by x_orange90_x
              I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
              I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
              07-15-2023, 05:06 AM
