Samsung UE70TU7100 - flickering horizontal lines
  • mrsith
    • Mar 2021
    • 146
    • Wielka Brytania
    Hello again good souls.
    Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
    I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and panel boards don't appear hot in touch.
    Any guides where to look for highly appreciated! Thanks!
    https://streamable.com/vva038
    • 12122
    • U.S.
    Re: Samsung UE70TU7100 - flickering horizontal lines
    check the little mlc caps on the panel driver boards for shorts or very low ohms.
    • mrsith
      • Mar 2021
      • 146
      • Wielka Brytania
      Nothing shorted there, every single cap tested.
      Maybe one of these resistors is bad? How can I comfortable test them?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4300
        • Italy - Milan
        i see no images of defect..
        • mrsith
          • Mar 2021
          • 146
          • Wielka Brytania
          File hosters archive videos after 24h. Here's an active link:
          CLICK
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4300
            • Italy - Milan
            gate drivers fault, your only option is the masking tape method, post a **sun light** photo of the tcon, steady hand please..
            • mrsith
              • Mar 2021
              • 146
              • Wielka Brytania
              Unfortunately this unit doesn't have a separate t-con. LVDS tape goes straight from main board to the panel board.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4300
                • Italy - Milan
                If there aren't silkscreens (i think it), must use the dog penis method, at random...
                • mrsith
                  • Mar 2021
                  • 146
                  • Wielka Brytania
                  Love the naming. I was playing around quite a lot with the main LVDS tape, gonna try my luck with the small tapes interconnecting panel boards.
                  • mrsith
                    • Mar 2021
                    • 146
                    • Wielka Brytania
                    I have found an area on one of the small tapes, interconnecting the panel boards. I have been looking at the side that's striped, obviously. The area, if covered, causes the flickering lines to disappear completely, but the picture is still not perfect - something is definitely off with red colour. I have managed to isolate the issue to one particular pin (see photos - Netflix logo on good side of the screen, Youtube at the bad one).
                    EDIT: It's not visible very well on photos - red colour seems to be saturated very little, almost grayed out, and striped/dotted a little. Difficult to describe this, the picture with the white Youtube icon seems the most accurate.
                    The overall effect is far better than flickering lines present previously, but that's still not it. What can I do now? I've been reading about cutting signals instead of blocking them - i.e. cutting ckv1 and ckvb1 and strapping them together - what's the actual difference? Worth giving it a shot here?
                    Again, many many thanks for your time and effort guys!
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4300
                      • Italy - Milan
                      no need of cutting lines, that is made when tcon is integrated with panel, try locating on the panel small boards the testpoints related to clock signals, i.e. CKVxxx, then with multimeter you locate the corrispondence on the input connector, the you mask one CKV at a time..
                      • mrsith
                        • Mar 2021
                        • 146
                        • Wielka Brytania
                        Should I keep that shown above pin covered when doing this?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4300
                          • Italy - Milan
                          remove it
                          • mrsith
                            • Mar 2021
                            • 146
                            • Wielka Brytania
                            Covering any single pin did not resolve the issue. Tried covering them one by one, all of them, in pairs, random amounts in random combinations. Was getting various results, the best of which was a perfect picture showing every ~5 sec for around 1 second, then getting striped again etc.
                            I suppose there's not a slightest chance that the issue is actually produced on the other side of panel, which looks fine?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4300
                              • Italy - Milan
                              If the panel has got side tabs must be removed on the side where the lines and bands starts..
                              • mrsith
                                • Mar 2021
                                • 146
                                • Wielka Brytania
                                Unfortunately this panel has no side tabs at all. Is there any hope left?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4300
                                  • Italy - Milan
                                  sorry, i forgot to mention, if you have an oscilloscope you can trace the clock lines from the main board, so you can mask them, better to mask only those requested.. clocks are about 22khz for a normal full hd resolution, those lower like 100hz are starting signals, if you mask those, there is one per side, it's equal to mask all clocks
                                  • mrsith
                                    • Mar 2021
                                    • 146
                                    • Wielka Brytania
                                    Regular multimeter was just enough to find ckv pins.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4300
                                      • Italy - Milan
                                      with frequency meter...?
                                      • alfatv
                                        • Sep 2020
                                        • 353
                                        You get this effect when you block VGH
                                        • Ihandyrepair
                                          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                          by Ihandyrepair
                                          Hi guys
                                          I just started fixing 4k TV few months ago. so I am still learning a lot
                                          I got this tv from friend complaint is ghosting or horizontal lines on image.
                                          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                          then it started to show the ghosting white image.
                                          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                          it has 3 thin small boards at the bottom of the...
                                          12-05-2022, 04:18 PM
                                        • Rubenlily
                                          Samsung QE50Q67TAU - horizontal lines
                                          by Rubenlily
                                          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                          I'm no expert but I've done the tape...
                                          08-16-2023, 01:12 PM
                                        • x_orange90_x
                                          Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                          by x_orange90_x
                                          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                          09-04-2023, 12:09 PM
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
                                        • x_orange90_x
                                          Samsung UN46C8000XFXZA Horizontal lines
                                          by x_orange90_x
                                          I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                                          I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                                          07-15-2023, 05:06 AM
