LG55UH615T pulsating Redstanby LED
  • wushumike
    • Jun 2016
    • 41
    • singapore
    Re: LG55UH615T pulsating Redstanby LED
    Originally posted by lotas
    Throw the wires on the cable, and you will find out where the problem is in the power supply or in the LED bar.
    Already did that...confirm is not LED strip because the light switch side....
    • wushumike
      • Jun 2016
      • 41
      • singapore
      I did that already...Confirm not LED strip.
      • lotas
        • Jan 2016
        • 4474
        • Russia
        So the problem is in the power supply (led driver), the LED strips are in order.
        • wushumike
          • Jun 2016
          • 41
          • singapore
          I'll try Dav.P method to check the MOSFET and IC (I did purchase this IC 801 from Ebay but yet to arrive)
          Nothing can get worse, any suggestion to nail the problem are welcome....Only last resort yo get another PS board.
          • lotas
            • Jan 2016
            • 4474
            • Russia
            Well, it's better not to use the TV now until you fix the problem in the led driver.
            Do you know the IC801 number?
            • wushumike
              • Jun 2016
              • 41
              • singapore
              #26
              IC 801 = MAP3516
              I try searching for Datasheet... not available.
              I can only assume this is a 2CH LED Backlight controller chip.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4277
                • Italy - Milan
                #27
                when you buy new ic801 buy n.2 because i think is bad also in your original board
                • wushumike
                  • Jun 2016
                  • 41
                  • singapore
                  #28
                  Thanks Davi.p
                  You have nailed the problem.
                  Ironically, I repaired the original board instead of the one I purchased. I use the purchased (faulty board) and did some comparison.
                  So the problem of my original board is as follows:
                  1. IC 801 faulty ...... internal circuit issue and it also affects the reading of R806 (10K)
                  2. R822 4R7 value increased
                  3. While trying to unsolder the MOSFET Q802 5N40, one of the lead drop off , so I cant say if this MOSFET is good or bad....Anyway I don't have this part but replace it with 9N40 which is better spec then the one used.
                  Replace IC, 2 resistor , 1 MOSFET .... Power Up standalone and no smoke before connecting back to the TV..
                  All back to normal!!!!
                  Anyway I didn't bother to repair the CN board.... probably is the same problem as you mentioned.... IC801
                  Closing this thread.... For those who have same problem, can use this as a troubleshooting reference.
                  Thanks All who have chipped in for this troubleshooting.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4277
                    • Italy - Milan
                    #29
                    Ok happy to hear it.. bye!
                    • estrumpf
                      • Jan 2017
                      • Portugal
                      #30
                      Originally posted by wushumike
                      Thanks Davi.p
                      Hello
                      Plese do you confirme that the resistor next to the 4r7 the 010 is 1 ohm resistor I get 100k value. ????
                      • lotas
                        • Jan 2016
                        • 4474
                        • Russia
                        #31
                        Originally posted by estrumpf
                        Hello
                        01D - 100 kOm
                        • alltvrepairs
                          • Jan 2014
                          • 211
                          • Malta
                          #32
                          These TVs have a lot of bad backlight issues. Sad part is only 1 led has to go bad for the whole tv to shut down.
                          Replacing backlights and turning the backlight setting down usually solves the issue. You can also modify the board to lower the amps to the backlights.
                          There is a thread that describes the process
                          Hi, bumped into this as have same issue. Have replaced all components mentioned here but 1 channel on pcb defective as TV restarts occassionally. Can you share the link for the modification mentioned please?
                          • tvguy12012012120
                            by tvguy12012012120
                            02-07-2025, 05:13 PM
                          • KYBOSH
                            Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                            by KYBOSH
                            I picked this one up today.
                            Previous owner says no signs of life.
                            TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                            Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                            The TV model is QN65LS03BAFXZA - version: CB06
                            The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                            I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                            Will keep you all...
                            04-05-2025, 08:32 PM
                          • fharris1977
                            Vizio D50u-D1 Dead Set No Standby
                            by fharris1977
                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                            12-28-2023, 10:25 AM
                          • An-klamm
                            Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
                            by An-klamm
                            Hello!
                            I have a TV that I can't get any further with.
                            It is a Samsung UE 55HU8590 with one connect box.
                            When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
                            As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
                            Since the TV works without ocb, I assume that it can't be the PSU?!
                            I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
                            Is there...
                            12-04-2023, 01:35 AM
                          • ChristianBr01
                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                            by ChristianBr01
                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                            04-23-2025, 01:48 AM
