Maybe I am doing something wrong when reading memory, I am using first time Neoprogrammer software.
Samsung ue32t5300ak
Well, I don’t know what you have and how you do things, so I dug up my CH341A (I don’t use it) and found the first SPI chip I came across in a DIP package, inserted it into the programmer’s ZIF connector and read the dump twice and the checksum matches in both cases.Last edited by lotas; 11-27-2025, 04:06 PM.Comment
Try AsProgrammerAttached FilesPremium supporters get full download access and other benefits.
I measured my CH341B programmer with oscilloscope and I think it is still problematic. When reading memory CLK looks like on image. When I try to read MISO and MOSI lines and connected probes to this lines, PC lost connection to CH341B programmer. Voltage on CLK pin seems strange, like 4 level logic is used.
I soldered EN25Q40B out. Before that I noticed LED behavior was changed, no any blink at all after power up from remote. I not erased EN25Q40B when it was in TV but somehow with different actions it become clear. When reading soldered out EN25Q40B it has only FF in memory, it was fully empty. I write to memory firmware from https://www.badcaps.net/forum/troubl...67#post1758367 , write was OK verification was OK.
I soldered chip back, but not get TV working. LED behavior is now not as before (1 long 5 short blinks). When power on from remote is pushed, then LED blink very fast and after that blinking has very strange and long pattern and after it LEB remains on for long time and in some period have 5 blinks.
TV is UE32T5372AUXXH, on PCB is type sticker bn91-21809k , can be that firmware from https://www.badcaps.net/forum/troubl...46#post1758346
works?Comment
I told you right away that you need to desolder the SPI flash and read it, then write a dump, but after your experiments, everything was deleted. Yes, try a different dump; it depends on the software version currently installed.
The same thing happened, only with a laptop. Experiments counting dump...
https://www.badcaps.net/forum/troubl...ing-programmer
Excellent free advice is given here to assist you sorting out your TV if you choose not to take the advice and waste your time trying to read and write a flash ic in circuit then go ahead!I soldered EN25Q40B out. Before that I noticed LED behavior was changed, no any blink at all after power up from remote. I not erased EN25Q40B when it was in TV but somehow with different actions it become clear. When reading soldered out EN25Q40B it has only FF in memory, it was fully empty. I write to memory firmware from https://www.badcaps.net/forum/troubl...67#post1758367 , write was OK verification was OK.
works?
I must say Lotas has been very patient with offering you advice. Myself I read the comments you made not following the advice given and was tempted to tell you, but again I think it would have fallen on deaf ears.
Who knows your reasoning why you went against the advice given.
Anyway I suggest if you wish to get help is that you follow Lotas information provided to you. Failure to do so will mean you will go round in circles wasting your time! If that's what you wish to do then I think the advice will not be forthcoming!Comment
Yes, it was not wise to not solder chip out. I was not expecting that just reading and measuring it will erase content.
At least I fixed CH341B programmer and get confirmed that reading chip on PCB of this TV did not work.
Have EN25Q40B dump inside some information for what PCB type/version it is?
How to find working version for bn91-21809k?Comment
There's no difference here; it fits all of this series and is the same for all models in this 32T53xxxx series. The only difference is the firmware version number. If the firmware version is updated, the data in the 25Q40 will also change, meaning the firmware version in the 25Q40 should match the firmware version in the eMMC. What if the second dump didn't help either?Comment
This information is hard to clearly understand.There's no difference here; it fits all of this series and is the same for all models in this 32T53xxxx series. The only difference is the firmware version number. If the firmware version is updated, the data in the 25Q40 will also change, meaning the firmware version in the 25Q40 should match the firmware version in the eMMC. What if the second dump didn't help either?
If the firmware version in the 25Q40 should match the firmware version in the eMMC, so not all firmware version in the 25Q40 fits with all PCB versions as the can be different firmware version in the eMMC. Or all models in this 32T53xxxx series have same firmware in eMMC?
Is in 25Q40 dump somewhere information with what eMMC firmware version it works?
I try to understand how things work not just fix it.
I desoldered IC401, read it, content was OK at first look, but if I compared it to initially written Samsung UE32T5300AU BN94-15341P EN25Q40.BIN
I find 3 differences, is it possible that also MCU/CPU in TV writes to IC401?
It cannot be read error as CRC32 is same with all reads.
I tested also other IC401 dump from this thread, file ic401_en25q40.BIN.
No success, LED did not blink at all. Probably stay in standby, IC401 3,3 V is present but 1.8V and 13V are missing.
Need I write UE32T5300AU BN94-15341P EN25Q40.BIN back to IC401 and start to search error on PCB hardware?
How to test, what is not working on PCB?Comment
Problems arise due to an incorrectly installed or crashed status register, even if the dump is fully functional. Try first removing the protection (uncheck all the boxes and write it down), then erasing the chip, then writing the dump, and then installing and writing the status register.Comment
Samsung Galaxy Tab S / E SM-T805W SM-T800 SM-T378V SM-T805W Schematic & Board View
Samsung Galaxy Tab S 10.5 SM-T805W.sch.pdf
Samsung Galaxy Tab S 10.5 SM-T800.pdf
Samsung Galaxy Tab E 8.0 SM-T378V.pdf
Samsung Galaxy Tab S 10.5 SM-T805W.bv.pdf...-
Channel: Schematics and Boardviews
09-29-2026, 10:33 AM -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
