Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • cortador
    replied
    Re: Samsung UN55MU6103F IC1604 dump
    This is the dump of the eprom of the samsung that did not work
  • cortador
    replied
    Hello, the board had another fault, if it worked without problems, then I will dump the other memory, which was the one that also failed
    Thank you very much
  • lotas
    replied
    Originally posted by cortador
    OK muchas gracias, no funciono mirare otras opciones
    After writing the dump, did you set and write the status register (0x88, 0x42)?
  • cortador
    replied
  • lotas
    replied
    Hello
    I could review this eeprom of a samsung ue65mu6402uxx that does not work and when removing the connection from the source the leds light up
    Thank you
    Try.
  • cortador
    replied
    Hello
    Thank you
  • lotas
    replied
    Yes, it should be 0x88, 0x42.
  • avalente123
    replied
    I tested and it works. Thank you very much. The only thing that not correct was protect SREG1 need to be 88 and only 8A. So i tested and tv starts again can it be like SREG1 8A?
  • lotas
    replied
    Originally posted by avalente123
    Hello
    I have one UE49MU6405U with no boot problems. I have the Ic1603. It is possible to fix it?
    Thank you
    Try.
  • avalente123
    replied
    Hello
    Thank you
  • lotas
    replied
    Originally posted by _adi_
    Thank you for the response.
    I have the original one already saved
    Try.
  • _adi_
    replied
  • lotas
    replied
    Dears,
    I have a Samsung 55MU6102 with no stand-by light. In order to not bother you with my problem, I downloaded many dumps of the IC1604, and I have written the memory with it.
    So far I got only to have red light on the st-by led, but the TV don't want to start.
    As long as I cannot figure how to fix the original dump of the IC1604, I would like to ask you if you can help me to fix it.
    Please excuse me if my English is not so good.
    It is necessary to lay out the original, native dump, if you have not saved it and have already written other dumps to it, then this will be a problem.
  • _adi_
    replied
    Dears,
  • lalodbs
    replied
    Originally posted by lotas
    Try.
    thank you very much lotas 100% working
  • lotas
    replied
    Originally posted by lalodbs
    help samsung un43mu6103f does not turn on, nor the attached power led my dump
    Try.
  • lalodbs
    replied
  • Willail
    replied
    Here is someone else's dump eeprom 24c512 from the same motherboard and in the same way fff, 000.
    Hello Lotas,
    Thank you for the dump eeprom 24C512. So, the 24C512 is not the problem for my TV. Probably the 25Q80 or the eMMC is faulty. I want to put another dump in the 25Q80. Is the same way to write the dump for 25Q40? May i put the registers? Do you know if someone who has this dump?
    Thanks a lot
  • lotas
    replied
    Originally posted by Willail
    Yes, i tried to disconnect the LVDS cable and turn it on. But, nothing happens only the red light of standby which stay lit. Do you know how to update the eMMC? Do you have read the dump of 24C512? it is amazing there is a lot of FFF and 00000 in the top of the lines. It is possible to find a schematics where i could check some voltages? Thanks à lot for your help
  • Willail
    replied
    It's more likely a problem in the eMMC firmware, or there is no voltage on the dc / dc converters or broken hdmi inputs ..., you tried to disconnect the LVDS cable and turn it on.
    09-07-2024, 05:50 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    Yesterday, 05:12 AM
  • totof
    Samsung UE55MU6102K IC1604 dump needed - TV don't start
    by totof
    Could you help me...
    I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
    Then motherboard connected, standby led is on and current consuption is 18W.
    Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
    Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
    The model of my TV is :
    Power supply BN44-00807A
    Main Board BN41-02568B / BN94-12765W
    Panel CY-GM055HGLV3H...
    05-01-2023, 04:30 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • jeangonbay
    Samsung UE43MU6105K IC1604 dump needed - TV don't start
    by jeangonbay
    Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
    The model of my TV is UE43MU6105K
    Main Board: BN41-02568B
    BN94-12007Y
    Could you help me to repair the dump please. Thank you.
    02-16-2024, 05:46 AM
