Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    • Jan 2016
    • 5398
    • Russia
    #401
    Originally posted by Farolf
    Hello, my UE40MU6400UXZT suddenly stop working. No standby light. Lotas could you please check dump? Thank you!
    Give it a try, don't forget about the status register, there's a thread on how to install it here.
    • Farolf
      • Jul 2026
      • 8
      • Italy
      #402
      Hi, today I tried to write the fix and the TV came back to life! Thank you Lotas!
      For everyone who bought black CH341, check the voltage between pin 4 and pin 8 on the 25Q40 while the programmer is reading or writing, not just in standby. In my case it was 3.3V but jumped to 4.4V during read or write.
      To solve, lift pin 28 of the CH341B and connect it to 3.3V regulator. Also pin 9 needs to be connected at 3.3V. After this, you should have 3.3V all the time.
      If you need a new memory like I did, I bought mine from DigiKey, search for W25Q40CLSNIG-ND (unfortunatly W25Q40CLSSIG is not avaible anymore).
      It's 150mil instead of 208mil, but it can be soldered on the board with a little care.
      Hopefully this helps someone else.
      • coofe
        • Oct 2019
        • 9
        • slovakia
        #403
        Hi can you help me on this dump from mainboard BN41-02568B , BN94-12405A , CY-KK040HGNV3H. Sticker on MB UE40mu6475UXXC . Restarts no logo on strartup , backlight ok Thx
        • coofe
          coofe commented
          Editing a comment
          Is this thread still active ?
      • sistem50
        • Apr 2026
        • Казахстан
        #404
        Good afternoon. I need your help fixing a firmware dump for my TV. SAMSUNG UE50MU6100U.
        • dfani511
          • Apr 2021
          #405
          Hello, anybody can help me with this backup to repair it please? UE55MU6172U - BN94-12646J
          • Steve97
            • Nov 2026
            • Austria
            #406
            Hello, after a power failure my TV stopped working.
            Looks like IC1604 became corrupt.
            The sticker says:
            UE65MU6199UXZG
            BN94-12571V
            If someone could help (lotas) would be nice.
            • neighbor
              • Sep 2025
              • romania
              #407
              Hey guys,so my parents TV again had a 25Q40BV wipe (like one year ago) and I took the old dump fixed by lotas (big thanks to him) copied, put register checks and it only shows diode blinking but no boot.
              Am I correct to assume that it must have a different header now, because OS (automatically thru internet) was updated a few months ago?
              How do you proceed in this case?
              This time I did not take the broken dump (which probably differs after recent OS update).
              Attached the old broken dump taken 1 year ago before OS update.
              • neighbor
                • Sep 2025
                • romania
                #408
                working dump of W25Q40CL (or W25Q40BV) for UE50MU7000 updated to last OS version (past 2022)
                most likely will not work on TV's with older OS versions.
                • Yanleb
                  UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                  by Yanleb
                  My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                  Disconnecting the main board from the power supply makes the backlight come ON.
                  I did disconnect the panel cables and the WIFI modules, the board is still dead.
                  I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                  Thanks.
                  11-18-2024, 12:34 AM
                • ogabuga
                  Asrock B650E PG-ITX BIOS_WHP1 /25Q40/
                  by ogabuga
                  Hello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D​
                  01-28-2025, 04:48 AM
                • daniel0799
                  Full 25Q40 dump for TP-LINK TL-SG1016D V7 (RTL8382L + 2x RTL8218B, PCB KB616010558)
                  by daniel0799
                  I’m looking for the **full 512KB (25Q40) SPI dump** for **TP-LINK TL-SG1016D V7 (unmanaged)**, PCB code **KB616010558**, with SoC **RTL8382L + 2×RTL8218B**.
                  My current dump only initializes 8 ports and the LEDs are misaligned, so I believe I have a firmware from an 8-port model.
                  I need a complete dump (bootloader + firmware) from a working switch to restore full 16-port operation.
                  If anyone has this model or a similar V7 revision, please share the BIN file or point me to a resource.
                  I can provide photos of my board and the flash...
                  10-22-2025, 11:12 AM
                • alro7779
                  Samsung UN55MU6103F video problem; has colored stripes on the display
                  by alro7779
                  Hello, everyone!
                  A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                  09-27-2025, 11:29 PM
                • totof
                  Samsung UE55MU6102K IC1604 dump needed - TV don't start
                  by totof
                  Could you help me...
                  I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                  Then motherboard connected, standby led is on and current consuption is 18W.
                  Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                  Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                  The model of my TV is :
                  Power supply BN44-00807A
                  Main Board BN41-02568B / BN94-12765W
                  Panel CY-GM055HGLV3H...
                  05-01-2023, 04:30 AM
