Toshiba 39L433D need firmware
  • lulz45
    • Sep 2021
    • 5
    • eu
    I'm trying to fix my sister's Toshiba 39L4333D TV with motherboard model number 32L4300 REV: 1.02.
    After a power outage the tv automatically turns on when plugged in and does not respond to any input (remote or direct buttons).
    It stays on the last viewed channel.
    Searching for other threads on this forum I've found another user that had a similar issue, but the url for the firmware is dead (toshiba link).
    I've tried to download a bin file I've found online to flash the firmware, but it seems incompatible, it still turns on by itself but this time it remains stuck at the logo splashscreen.
    Thanks in advance.
    EDIT:The model number is 39L4333D not 39L433D. I've missed another three.
    • 12206
    • U.S.
    Re: Toshiba 39L433D need firmware
    try a simple reset, unplug tv from power, press and hold power button for 30 seconds let go, leave tv unplugged for a few minutes, then plug it in and try it.
    • lotas
      • Jan 2016
      • 4617
      • Russia
      You need firmware number "7.1.92.61.01.1".
      • lotas
        • Jan 2016
        • 4617
        • Russia
        Toshiba firmware 7.1.92.61.01.1
        https://drive.google.com/file/d/1llg...oece1Qs96/view
        • lulz45
          • Sep 2021
          • 5
          • eu
          I already did that, but since I could not remember on which firmware I tried that
          (I've tried 2 bin files I've found online, 1 same model and the other it was a similar model), I've flashed the backup I've made, unfortunately it still behaves the same way.
          • lulz45
            • Sep 2021
            • 5
            • eu
            I'll try that file, lotas. Thanks.
            Will report later.
            • lotas
              • Jan 2016
              • 4617
              • Russia
              There, you will probably need to change to your panel, that is, "39" and the letter at the end "X" - this is the manufacturer of the panel, as in the instructions.
              • vinceroger69
                • Mar 2012
                • 6714
                lotas pdf conveted to english
                MAJ RL / TL / VL 933 / 963
                RL/TL933Toshiba
                IMPORTANT: Be sure to remove the USB Wifi dongle before proceeding with the software update
                1. download the “software version” (.zip) from our site
                2. Unzip the file and open the folder
                3. Before putting the files on a USB drive, check the file name:
                “xxRL933K_562000_INIT_CLEAR.bin” where xx represents the size of the screen in inches and K the type of
                panel (there are also L panels, check the back of the TV, for the serial number, to
                know your type of slab). For example, for a 40RL933, rename the file as follows:
                40RL933K_562000_INIT_CLEAR.bin
                4. Put the files on a USB key
                5. Unplug the television completely from the mains socket.
                6. Insert the USB key containing the update into the side USB port.
                7. Switch the television on again by reconnecting the mains plug: The green and orange LEDs indicate that the
                day is loading...
                8. Once the update is complete the screen displays:
                9. Remove the USB key.
                10. Switch the TV off and on again,
                11. Reset the TV via the MENU, SETTINGS by validating the line “Reset TV”.
                12. Reinstall user settings (channels, network config, etc.)
                • lulz45
                  • Sep 2021
                  • 5
                  • eu
                  I saw your other posts too late, I have already flashed the firmware through USB.
                  Way easier than using a programmer.
                  It works now, it responds to inputs, at least in the initialization menu.
                  Thanks a lot.
                  In case there are any issues related to the wrong filename I will reflash using the correct filename.
                  Again thanks.
                  • lotas
                    • Jan 2016
                    • 4617
                    • Russia
                    RL/TL933Toshiba
                    day is loading...
                    OK, yes, I meant about it, but it's too late, apparently it went well.
                    • alex39t
                      • Nov 2013
                      • 50
                      • greece
                      IOTAS i want your help i have a toshiba 40l6353dg after logo stuck no image only backlight i have test some bin for 25q16 but no change my board is 32l4300 1.02 do you have opinion for this?
                      • lotas
                        • Jan 2016
                        • 4617
                        • Russia
                        Put your original 25q16 firmware back in place and try updating the firmware via usb.
                        The name of the firmware should look like this "UPDATE_50L7363C_1926101_INIT_CLEAR#.enc".
                        • alex39t
                          • Nov 2013
                          • 50
                          • greece
                          I have to hold a button when i want to update?
                          • lotas
                            • Jan 2016
                            • 4617
                            • Russia
                            Manual
                            • alex39t
                              • Nov 2013
                              • 50
                              • greece
                              IOTAS i try it but the same only logo and after that only logo do you have something ?
                              • robertadag
                                • Jul 2024
                                • Italy
                                Hello everybody, since the beginning of this year my toshiba lcd 39L2333D is stuck under update channels. I would like to reboot or download the proper firmware. Anybody can help here?
                                • anlu
                                  Vestel Firmware - Toshiba 32W133DN
                                  by anlu
                                  Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                                  Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                                  02-04-2023, 12:59 AM
                                • DarrenHD
                                  Firmware for older Toshiba TV 22CV100U
                                  by DarrenHD
                                  HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
                                  I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
                                  https://support.dynabook.com/support...tentId=2865076
                                  Thanks!
                                  06-16-2025, 11:56 AM
                                  09-06-2024, 05:27 AM
                                  09-06-2024, 05:59 AM
