LG 26LG40-UA odd menu problem (possessed)
  • Toasty
    • Jul 2007
    • 4171
    Complaint of menu coming up on screen and random switching of functions. Unit will also turn itself on at random. Random menu can not be turned off by remote "menu" button or any controls. Turning unit off and back on by remote or manual power button does not clear problem. Unplugging unit does.
    Came into shop without the symptom and ran 2 days with no problems. Customer had unplugged unit 2 months prior and used another set. I was unable to duplicate problem. Returned unit to customer.
    Tonight they called saying it was doing it again. It has been 7 days since its return and has been plugged in that long. It was running fine all day and then it started again. Unplugged set for a few minutes and problem cleared. Was fine as of 2 hours ago.
    Any ideas what is going on?
    Toast
    veritas odium parit
  • Toasty
    • Jul 2007
    • 4171
    Re: LG 26LG40-UA odd menu problem (possessed)
    Unable to upload owner and service manuals. Both PDF's, both around 5.5 meg...?
    Let's try this another way until TC can figure it out:
    Owner's Manual
    Service Manual
    There!
    veritas odium parit
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      I start by doing an extra thorough visual inspection focusing on cold solder joints, crimped wires and bad connector pins.
      I know, you knew that.
      Some days a body just doesn't feel like doing the simple sh*t.
      It's boring!
      Mann-Made Global Warming.
      - Dr Seuss
      • PlainBill
        • Feb 2009
        • 7034
        Make sure you're at the latest firmware level. This COULD be some sort of overrun error. Scope the signal from the IR receiver to the interface chip. As PCBONEZ suggested, check for suspicious solder joints.
        PlainBill
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          crud on the button board?
          windex,spills,ect.
          or noise/ripple on supplies.
          • Wizard
            • Mar 2008
            • 2296
            Change all the switches or replace the buttons board.
            RCA was infamous for this years ago, more worse with smoker.
            Cheers, Wizard
            • tmwalsh
              • Jan 2009
              • 119
              I'd bet on spikes in the power supply, or bad connections causing the microcontroller go go nuts. The menu showing up is the sort of thing that one would expect when the thing was reset to its factory state after losing power.
              tom
              • Toasty
                • Jul 2007
                • 4171
                Update:
                I have not seen the unit again. The customer unplugged it for a minute and plugged it back in. No problems since. I do not know if I will see it again, if they can correct the issue that quickly and easily.
                It would also be a bitch to try and find a problem that is that intermittent. Leave it running on the bench for a week... not!
                I did ask them to run their fingers across all of the control buttons on the side of the TV the next time it happens. If it clears, then that would be the place to start. If not, well.....
                I'll update if I ever see the unit again.
                Thanks to everyone for the input!
                Toast
                veritas odium parit
                • Toasty
                  • Jul 2007
                  • 4171
                  Upload of PDF manuals again. Had to do it from my site.
                  Above off-site links are no longer valid. Files deleted.
                  veritas odium parit
                    LCD LED TV Service Menu Codes
                    TCL LED TV Service Menu Code
                    LG LED TV Service Menu Code
                    10-31-2024, 03:58 AM
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • jaaa1976
                    HP EliteDesk 800 G4 Mini PC -There is a problem with the security device on the unit
                    by jaaa1976
                    Hi everybody !
                    I bought this pc from ebay with error - There is a problem with the security device on the unit
                    please fix my bios.
                    Model: HP Elitedesk 800 G4 mini PC (65w)
                    serial no. 8CC93326J4
                    PRODUCT NO. 4KW04ET#ABU
                    32- 16mb bios attached
                    Thank you so much...
                    12-19-2024, 06:48 PM
                  • Zeonalbasta
                    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                    by Zeonalbasta
                    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                    09-13-2024, 01:17 PM
                  • vf fa
                    EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                    by vf fa
                    Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                    I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                    So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                    01-31-2024, 01:40 PM
