Sony XBR-65X900E 4 Blink Code
    • 12116
    • U.S.
    #41
    Re: Sony XBR-65X900E 4 Blink Code
      • 12116
      • U.S.
      #42
      I looked at a similar board over and I see several places that are labeled fuses but I'll be damned if I can tell where they are, I know some will have a label but just not be included in a particular design.
      • my2k2zx2
        • Jan 2023
        • 20
        I think I'll try a new main board and see if that gets this working again. Not sure what issues it might have at this point.
          • 12116
          • U.S.
          #44
          ok, if you are sure you are getting a new mainboard, something you can try if that there is a cap and not a fuse, is just remove it with a soldering iron and try the tv, I have seen this work, that is removing a shorted cap and tv working with it removed.
            • 12116
            • U.S.
            #45
            if you find a place with decent prices send me a message, still need one for my 900c.
            • my2k2zx2
              • Jan 2023
              • 20
              Going to see if I can find one in a known working condition on ebay.
              • lotas
                • Jan 2016
                • 4554
                • Russia
                #47
                The fuses are in the photo, the motherboard has nothing to do with error 4 associated with the LCD Panel ...
                • my2k2zx2
                  • Jan 2023
                  • 20
                  The circled fuses are not blown.
                  So the above chart is showing 4 red flashes means the panel itself is the issue?
                  • lotas
                    • Jan 2016
                    • 4554
                    • Russia
                    #49
                    This is everything related to the panel, backlight (leds), led driver, power led driver...
                    There is a problem with the panel or with the T-con, then the error would be "5".
                    • Storyteller12
                      • Jun 2020
                      • 624
                      I think it’s backlight related. Unplug the blue tabbed cable from the main board and plug the tv in. It will do a backlight test and if it the leds are good the leds will stay lit
                      • Storyteller12
                        • Jun 2020
                        • 624
                        Note you might have to unplug the lvds cables going to the tcon also.
                        I'm not sure as I already had the screen out and those cables unhooked when I discovered the led test cycle.
                        • my2k2zx2
                          • Jan 2023
                          • 20
                          It's going through a color pattern, checkerboard pattern. No signs of it turning off. It's playing ambient music as well.
                            • 12116
                            • U.S.
                            #53
                            I had 4 blinks plus many shorted caps on mainboard, have not decided on replacing mainboard but I think thats the issue.
                            • lotas
                              • Jan 2016
                              • 4554
                              • Russia
                              #54
                              I had 4 blinks plus many shorted caps on mainboard.
                              It could not be a short circuit, but a very low resistance on this bus (processor core power), just like on this 4 ohm board.
                              • lotas
                                • Jan 2016
                                • 4554
                                • Russia
                                #55
                                Well, you wanted to order a motherboard (and that would be the same mistake).
                                • my2k2zx2
                                  • Jan 2023
                                  • 20
                                  I found a set of all boards from a supposed cracked tv.
                                  Might get that and change out all the boards.
                                    • 12116
                                    • U.S.
                                    #57
                                    Well whats the answer then, storyteller just said if the backlights stay on they are ok and they stayed on.
                                    • lotas
                                      • Jan 2016
                                      • 4554
                                      • Russia
                                      #58
                                      The answer is this - the protection of the led backlight is turned off and the processor thinks that everything is in order with the backlight.
                                        • 12116
                                        • U.S.
                                        #59
                                        ok, just to satisfy curiosity can you test that cap on the new mainboard when you get it, to see if it reads the same.
                                          • 12116
                                          • U.S.
                                          #60
                                          ok, I get it, thanks for explaining, so it could still be a backlight issue.
                                          • EazyBone
                                            Sony 85x90CK 4 red blink
                                            by EazyBone
                                            So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                            But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                            Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                            Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                            Yesterday, 12:53 PM
                                          • x_orange90_x
                                            Sony KD-75X750H no backlights
                                            by x_orange90_x
                                            I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                                            Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                                            07-16-2025, 07:49 PM
                                          • cheeky2
                                            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                            by cheeky2
                                            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                            01-08-2024, 05:56 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • EazyBone
                                            Sony XR-77A80J OLED 5 Blink
                                            by EazyBone
                                            Another eazybone post took on this OLED now.
                                            Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                                            I'm thinking I have a power board issue though, which is one of the options
                                            Now to check pin voltages from PSU to main and PSU to tcon
                                            Pic 2
                                            1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                                            2 bl err -- 0.16
                                            3 evdd on --0
                                            4. Ac off det 3.187
                                            5 power on -- 3.362 BUT fluctuating randomly to 3.352
                                            6 stby...
                                            10-24-2023, 09:09 PM
