LG 70uh6350 no picture
  • kubectl
    • Dec 2022
    Hey, all! I have a LG 70UH6350-UB.BUSMLJR that does not power on. The standby button is lit but pressing power on the television only causes the standby light to flicker once very briefly and remain lit.
    I have torn the back off the TV and am trying to diagnose if its a main board or power board issue. The legend shows various 12v and 24v pins however the 12v legs I do get a reading on only show around 7.5v. If I hit the power button, and set max hold, I see the 12v pins go to almost 12v and the 24v pins hit 24v.
    My guess is that this is a main board issue and the voltages I am reading are standby voltages and something is functioning enough on the mainboard to briefly wake up the TV but nothing happens. Certainly not an expert though and open to any and all input.
  • nomoresonys
    • 12276
    • U.S.
    Re: LG 70uh6350 no picture
    can you post a good straight on picture of each board and one of the whole back, as to see how everything is connected.
    • lotas
      • Jan 2016
      • 4752
      • Russia
      chassis UD64J
      • kubectl
        • Dec 2022
        Hopefully the service manual posted is what you need. I will need to return to my dads house (his TV) in order to get any more pictures.
        The service manual states to check the 12v/24v pins and says to check ST-BY 3.5v but no specifics as to which pins. Is that 3.5v the one illuminating the standby light? If so, I have not verified voltage but the light is on.
        • kubectl
          • Dec 2022
          For posterity; Replacing only the main board resolved the issue.
          • nomoresonys
            • 12276
            • U.S.
            thanks for the followup, glad to hear it.
            • brithepi2k
              Samsung UE75TU7020k No picture, Standby blinks 2 times
              by brithepi2k
              My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
              04-23-2025, 10:05 AM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • stylishconsultant
              un60j620dafxza - Samsung No Display Problem
              by stylishconsultant
              Hi All,
              Need help.
              I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
              So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
              problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
              might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
              09-04-2024, 03:26 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • IAmOrion
              LG55UB850V no picture or audio, just flashing LED's help please?
              by IAmOrion
              Hi members, I came across this forum when searching a fault on my LG 55UB850V TV.
              Rather than hi-jack another members post/thread I thought I should start my own even though it's an almost identical issue.
              The thread I refer to can be found here:
              https://www.badcaps.net/forum/troubl...-s-help-please
              My boards are the same, and my issue it the same. I have NO Picture and NO Sound. Nothing. When first turning on the TV at the...
              01-28-2024, 06:50 PM
