SMPS - Can they all handle wide range of Input Voltage?
  • ketone
    • Apr 2017
    • 21
    Hello Forum - See I got this SMPS Module!....its sourced from a US device and I'm in Australia.
    As we know Supply voltages in Australia 240v Versus 120V US.
    The Model of the SMPS is EAX39561401 and is used in LG and JVC DVD/VCR Player/Recorders...same model is used in both Australia and US...but perhaps they have differences??
    What's the chances I can use it in Australia - plugging it in to 240v instead of its origin country at 120v?
    Is it expected that most SMPS in such devices would handle between 100-240V by default?
    How can I be sure it will not go Boom!
    TIA
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: SMPS - Can they all handle wide range of Input Voltage?
    NO, it's not safe to assume that it will work at both voltages.
    A lot can but it's not guaranteed. Companies that target multiple countries tend to make units that are wide input just to reduce the number of SKUs for cost.
    Sometimes cheaper capacitors are used in low voltage areas but this depends on whether the IC/inductors are sufficient to begin with for wide-voltage.
    • ketone
      • Apr 2017
      • 21
      eccerr0r thanks for your thoughts!
      Is it possible in anyway to ascertain if the module is able to handle a wide range input voltage or not?
      FWIW here is the Circuit from an SM....it does not say specifically unfortunately.!
      EDIT
      I noted from the Schematic it states C103 can be either 100uF 'WIDE', 150uF 'NARROW', and 63uF 'S.AFRICA, INDO, CIS' - wondering what 'WIDE' is referring to.
      At the moment C103 is a 150uF so its NARROW.
      Voltage in S.AFRICA, INDO, CIS' is 230v
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        You must check that capacitor C103 is really rated for 450v as the schematic shows.
        A quick Google search shows it is commonly rated for 250v only (cost cutting option for 115VAC countries...)
        There could be more differences too...
        • ketone
          • Apr 2017
          • 21
          Thanks Per
          Yes currently C103 is a 250v 150uF - so "NARROW' and lower voltage.
          I could change it easily for a 450V 100uf 'WIDE'
          or 63uF 450V cap..
          Not sure what 'WIDE' gives me as in what input range it then allows.
          the 63uF is meant for S.AFRICA so I know its supply voltage is 230V...pretty close to Australia's 240V supply.
          Then as you say there could be differences not listed in the Schematic...
          • ketone
            • Apr 2017
            • 21
            I just spotted that Australia uses the 63uF 450v for the same module - spotted from a picture of one on sale in Australia - ebay.
            Still hard to ascertain if any other differences from a picture.
            • CapLeaker
              Leaking Member
              • 8203
              Shouldn’t that info be on the sticker on the unit? It should state the voltage and amps.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Originally posted by ketone
                Thanks Per
                or 63uF 450V cap..
                Narrow and wide might actually just be the two different footprint rings on the board...
                Only one way to found out: mount a 450v cap and see if it explodes when you connect it to mains
                  • 31070
                  dont forget to change the fuse to half it's current value
                  no pun intended.
                  • ketone
                    • Apr 2017
                    • 21
                    Well yep I think so.... will rig up a 25/50watt dim bulb/load lamps in series with the power supply. Still Im not sure that would save any damage...maybe less smoke !
                    • ketone
                      • Apr 2017
                      • 21
                      Shouldn't that info be on the sticker on the unit? It should state the voltage and amps.
                      No stickers - the model is EAX39561401 and they use the same Model number for use across different countries and different Electrical Devices its used in...so not very helpful..perhaps thats hinting that they are all basically the same but who knows!
                      The schematic I posted highlights the different Capacitor C103 as a difference between locations.
                      Will see how she blows! I mean goes after changing the Cap.
                      • ketone
                        • Apr 2017
                        • 21
                        For Ref
                        Uploaded pictures of a 240v EAX39561401 board
                        and a 120V EAX39561401 Board for visual comparison.
                        Physical size of Cap C103 looks the same between the two boards...so perhaps the terms 'NARROW' and 'WIDE' seen on the Schematic do refer to Input Voltage ranges?!
                          • 31070
                          remove or upgrade the varistor V101 if you dont want a dramatic explosion!
                          • CapLeaker
                            Leaking Member
                            • 8203
                            That varistor cording to schematic is a 681d14. Since it is 680V rated, it should be good.
                              • 31070
                              if it's not different for 120v
                              • ketone
                                • Apr 2017
                                • 21
                                Thanks for questioning!
                                I just checked the Varistor V101 and it is the 650V as per Schematic...and this correlates with the one version of the part as seen in the Parts list.
                                .. been looking over the Parts listed for this SMPS.
                                Cant see any further gotchas wrt to Voltages as far as I can see.....so once the 450v Cap turns up and installed will test with wooden stick and Dim Bulb.
                                • CapLeaker
                                  Leaking Member
                                  • 8203
                                  You don’t need both, but either or. Lol
                                    • 31070
                                    and a new fuse.
                                    the current flow at 220v is only half that of 110v
                                    • CapLeaker
                                      Leaking Member
                                      • 8203
                                      that's a valid point right there!
                                      • ketone
                                        • Apr 2017
                                        • 21
                                        and a new fuse.
                                        Good thought - will put in a 750ma fuse
                                          ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...
                                          09-07-2024, 02:50 AM
                                          AD7276, AD7277, AD7278, AD7274, AD7273​ Datasheet
                                          The AD7276, AD7277, AD7278, AD7274, AD7273 are 12-bit/10-bit/8-bit, high speed, low power, successive approximation analog-to-digital converters (ADCs), respectively. The parts operate from a single 2.35V to 3.6V power supply and feature throughput rates of up to 3 MSPS. The parts contain a low noise, wide bandwidth track-and-hold amplifier that can handle input frequencies in excess of 55 MHz.
                                          The conversion process and data acquisition are controlled using CS and the serial clock, allowing the devices to interface with microprocessors...
                                          10-07-2024, 05:32 AM
                                        • eccerr0r
                                          220VAC locales... ever used DC to feed switch mode power supples...and how many volts is generally okay?
                                          by eccerr0r
                                          For those in 220V locales, anyone power their SMPS with DC, and how high of a voltage is okay?
                                          What kind of PSU?
                                          I suspect that 240V * sqrt(2) = 340V DC is probably fine because that would be about how much the the primary rectifier ends up with peak voltage. Just wondering, other than input capacitor voltages, can one go up above this 340V without damage? Will that input capacitor be the upper bound?
                                          Wondering if exactly that, can I feed near 400VDC into bona fide specced at 220V SMPS without damage?
                                          Currently have a 120/220V switchable SMPS I want to see if I...
                                          04-22-2024, 08:03 PM
                                          Texas Instruments TPS51427ARHBT TPS51427ARHBR Dual D-CAP Synchronous Step-Down Controller for Laptop Computers
                                          The TPS51427A TPS51427ARHBT TPS51427ARHBR are dual synchronous step-down controllers designed for laptop and mobile communications applications. This device is part of a low-cost suite of notebook power bus regulators that enables system designs with low external component counts.
                                          The TPS51427A includes two pulse-width-modulation (PWM) controllers, SMPS1 and SMPS2. The output of SMPS1 can be adjusted from 0.7V to 5.9V, while the output of SMPS2 can be adjusted from 0.5V to 2.5V. This device also features a low-dropout (LDO) regulator that provides a 5-V/3.3-V output, or adjustable...
                                          10-23-2024, 02:37 AM
                                        • dkneyle
                                          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                          by dkneyle
                                          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                          02-01-2022, 02:08 AM
