AC-DC rectifier 5V, 2A learning and testing
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Hello guys,
    I have a TV box power supply adapter, 5V, 2A that's not working correctly. Input is AC 230V 50 Hz.
    I would like to use this as a learning example.
    First of all, when adapter is connected to AC power, there is 5 V DC at its output (4.95V) when no load is connected.
    If a small light bulb is connected (5V, 0.3A), the output voltage drops to 0.85V and there is a weak light on the bulb.
    Attached is a picture of PCB. There are two black IC s on the board. The smaller one 4 legs is probably a voltage feedback chip. On it is written something like: PC817C 1452, and I cannot see that anything is written on larger 8 legs chip.
    So when load is connected voltage drops and even green LED light becomes weak. Even after I remove the adapter from the AC power, its DC output remains 0.85V for a long time.
    What could be the problem in such cases, i.e. when there is output voltage with no load connected?
    Thank you.
    • Jul 2011
    • 6057
    Re: AC-DC rectifier 5V, 2A learning and testing
    Can you please show the back side of this board thanks
    • lotas
      • Jan 2016
      • 4710
      • Russia
      Usually these capacitors are the problem, especially at the power output.
        • Jul 2011
        • 6057
        Originally posted by Adenitz
        Hello guys,
        Thank you.
        Here is the data sheet for the part that you were asking about
        https://cdn.badcaps-static.com/pdfs/...34e9701c06.pdf
        The 8 pin ic chip is probably some type of switching transformer power supply regulator
        • Adenitz
          • Jan 2021
          • 122
          • Congo
          Hello and thank you all for your replies.
          The backside of PCB is given in the attached picture.
          The caps don't show and visual signs of wearing (bumps).
          One capacitor is 400V , while other two are 47 uF 50V and 470 uF 25V.
          Should I try to replace the caps?
          What could be a reason for voltage drop if bulb is connected, 7V, 0.3A should not be a large load for 5V 2A power supply, right?
          • lotas
            • Jan 2016
            • 4710
            • Russia
            Capacitors do not always show a malfunction if the cover is swollen, some of which have rubber squeezed out on the back side, where the conclusions are, the ESR increases (the main reason), but because of them it happens mainly that it does not hold the load, try changing that which is 12v output. (470x25)
            • redwire
              • 3912
              I had a (new) 5V 2A PSU that was very weak, it could not supply even 0.5A without sagging voltage and it was a bad IC, the DIP-8.
                • 31158
                thats clearly a USB psu, i seriously doubt it is designed for more than 1A
                • cmlewis89
                  LG 47LB5DF blown power supply board
                  by cmlewis89
                  Hi folks,
                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                  09-03-2024, 07:50 PM
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • Thomasraud
                  Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                  by Thomasraud
                  i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                  QUOTED
                  -It works on charger (without battery connected-only charger)
                  -It works on battery (without charger connected-only battery)
                  -& it also works when plugged in battery & charger, but it's not charging the battery
                  //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                  and..
                  QUOTE
                  The IC cannot maintain the input current level
                  06-28-2022, 06:47 PM
                  Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                  by momaka
                  This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                  Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                  Macron Power Technology Co. LTD.
                  Let’s look at the PSU itself.
                  The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                  06-02-2021, 10:05 PM
                • Crystaleyes
                  Inverter Welder Strangeness
                  by Crystaleyes
                  Hola peeps.
                  I'm placing it in this topic, because from what I can see, it is essentially a modified SMPS, but please move if there is a 'correct' forum section.
                  Recently, I bought an essentially brand new, but defective, 155 amp inverter welder.
                  The unit would turn on fine, with the digital display and fan doing their thing, however when attempting to strike an arc, the rod would merely spark or just get stuck onto the steel.
                  Now I know that many (if not most) in here would simply not have bought it, but I am still learning this trade...
                  03-27-2023, 04:04 PM
