Power Mac G4 MDD "Mirror-Door" won't power up
  • gogo75
    • Apr 2012
    • 6
    • Bulgaria
    #81
    Re: Power Mac G4 MDD "Mirror-Door" won't power up
    All small caps are Fujicon RK,main filter cap YAGEO LG.
    PSU is open,on table.Test with resistors(resisitive wire) and with water rheostat.
    Voltage acros main cap is 280v-no load,255-260v min. load.
    Normal load-acording to label on PSU
    3.3V-2.0 to 17A /in my case-2.3A
    5V- 1.0 to 20A /in my case 1.3-1.4
    12V-1. to 16A /in my case 1.4-1.5
    -12V-0 to .4A / abbout 30mA
    25Vsb-0 to 4.2A /bulb 24V/5W
    5Vsb-0 to 1.5A /bulb 6V/3W
    • Toasty
      • Jul 2007
      • 4171
      #82
      Fujicon are crap.
      Yageo are crap.
      You have replaced crap with crap. No wonder it won't run properly.
      veritas odium parit
      • gogo75
        • Apr 2012
        • 6
        • Bulgaria
        #83
        Thank You!
        And what about Rubycon?I have one 470/400V(used) and I'll try it tomorow.Small caps no matter crap or not must work at least 48 hours.I'm gona replace only main,cose see R107-current sensor for PFC.
        Bad main cap will draw more charge current,right?
        And one more thing:
        with those loads except 12V/not load on line 12V/, 5V become 3.8V and 3.3V become 2.98V
        • Toasty
          • Jul 2007
          • 4171
          #84
          280v is low. What is your mains voltage and why is it not filled in in your profile?
          Take your mains voltage & multiply by 1.414. That gives you the standby voltage on the main cap. It will rise significantly to 350v or better when powered on, as the PFC comes online.
          A weak mains cap is a possibility. Or the switchers were not replaced with the correct part or are not matched to originals.
          veritas odium parit
          • gogo75
            • Apr 2012
            • 6
            • Bulgaria
            #85
            And the results-nothing changed except 300V on main cap.
            Main suply 220V,STW20NM50 are new,from same tube,every replacemant is exact value/may be crap caps,but same value/.
            Any ideas ...???
            I traced the KA3504-PGin and PGout not connected,+12V current sense too.
            • Toasty
              • Jul 2007
              • 4171
              #86
              20v is quite an improvement.
              Test the voltage across mains at standby with no load. Should be ~310v. Then, jumper the unit on and check again. Report.
              Low output 3.3/5/12 when on and loaded is indicating PFC not "kicking" high enough. The small caps will affect that.
              veritas odium parit
              • gogo75
                • Apr 2012
                • 6
                • Bulgaria
                #87
                Yesterday I can't work on it,but today I replaced all small caps with Rubycon and the results:
                1. no load 300V main cap
                2. load 3.3V/1 Ohm drop to2.95V;5V/4 Ohm drop to 3.6V;295V main cap
                3. load 12V bigger than 0.3A-PSU shuts down
                Pins 4 and 19 of SUB1 are some feedback from opto's,
                8 is PWM to 11N50/switchers of T1/,
                9 is feedback PWM,
                10 feedback from PFC,
                5,11,15,16 not connected
                12 +15V from 7815
                6,7,13,14 GND
                17,18 temp. sensor
                1,2 line monitor
                3 PFC switchers 20NM50
                I want to know voltages on pins 4&19 /sb,min load/ because both changed from "SB" to "ON".Wich one is "PG"/"on" ,"start" command/ and wich one is feedback?
                • gogo75
                  • Apr 2012
                  • 6
                  • Bulgaria
                  #88
                  Update-main cap 375V SB and ON.PFC part of ML4824 work fine.After replace of R122-2/increased resistivity from 10 ohm to 3.5Mohm/ PFC "blink" halogen bulb of 150W.
                  Still no change in secondary side-voltages drops....
                  • Toasty
                    • Jul 2007
                    • 4171
                    #89
                    >>After replace of R122-2/increased resistivity from 10 ohm to 3.5Mohm<<
                    What does that mean? You changed a resistor? Why?
                    All lines must be loaded. Loading only one will cause an imbalance and shut it down. Have you tried it plugged into machine?
                    veritas odium parit
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4953
                      • New Zealand
                      #90
                      For my AcBel I did a first test after repair and powered it up according to this: http://haertle.ch/tinker/ps/
                      Short PS_ON to GND (as usual) but you also need a 10-30 Ohm resistor (you will need more than 1/4watt) between GND and 3.3v Sense line. I used a 15 ohm 5-watt.
                      The PSU powered on without any other load and all voltages were correct and stable.
                      I do not know if the same can be done with the Samsung version, however.
                      -David VanHorn
                      • Ed in SoDak
                        • Jul 2010
                        • 10
                        #91
                        Hi to the group,
                        Revisiting the thread after a long hiatus. The MDD that I fixed due to help from this thread is still going strong some years later in constant use.
                        I just picked up today a better base MDD system also with a bad PS. As it happens, it's the same MDD I referenced earlier in the thread that had its PS replaced with one bought off ebay, so it was on it's second supply when it failed again.
                        As a quick check of the system, I plan to swap in the repaired supply from my working MDD. At that point, if it works, I'll have two toasted PSs to experiment on (hopefully not a third), and a far better system to play with in the meantime.
                        Earlier in the thread I posted about my diagnosis of this MDD's original PS and it follows the typical failure pattern. I didn't bother to repair it then, as my first attempt has worked so well. So I guess I have a backup plan in place if I terminally smoke something.
                        I can't add much to the most recent replies tech-wise, but do have some advice on basic desoldering techniques and the typical tools we laypersons can easily acquire or already own.
                        Desoldering braid works best if "fresh,", that is, bright-colored and un-oxidized. If your braid is dull-looking, try buffing the outer parts so they are shiny. It doesn't take much oxidation on copper to really mess with a good and fast-acting wicking job. Tinning the very end of the braid will help it take up solder faster than bare braid. If your pre-tinning of the braid moves up too far, just snip off the fully-soldered part, leaving just a fraction of an inch pre-tinned.
                        Same goes for your iron or other reworking tools. If the tip of your iron is wasted away and pitted, it won't present a large heating surface to the work. File it down to a nice flat wedge-shaped point and tin it with a bit of solder before going to work. The melted solder and flux on the tip helps to increase the heated mass and transfers the heat to the work more quickly.
                        Be sure to clean and correct any connections of the tip to the iron itself. The same condition of oxidation, as seen when using old desoldering braid, can happen in the tip's connection to the iron. Just loosening and retightening the tip's fastener can really help heat transfer.
                        As an iron heats and is flexed under use, the tip may loosen a bit, so I give the tip a little gentle tightening with a pair of needlenose or whatever. You can get a feel for what's loose and flaky, or what's actually twisting the tip's connection instead of getting a snug fit. Heat transfer is everything, even moreso than which specific brand of iron or tip you choose. It's not "more heat" that does it, but "effective" application of the heat.
                        Soldering isn't like a slow-cooker on your stove. Leaving the iron on a joint while waiting for things to happen and pressing harder on the joint will cause more problems than you're trying to fix. A slow-heating iron can do more damage by all the prodding and pressing and waiting and such you do while trying to force it to do the job. That just heats up the parts you want to insulate from heat and can start to lift circuit traces, cook out the soldering flux and generally waste your time.
                        It's best to go in with a fresh, clean, hot iron, with tinned tip and get the job done quick. Watch that solder flow liquid, then get off it when it makes a good bond. Move nothing, lest the joint crystallize in a "cold-solder" joint. Those appear pasty-looking and gray instead of shiny and smooth. Desoldering is similar. The sooner you can flow the entire joint and suck it off quickly, the better. There's countless documented cases of failures due to to factory-soldered bad connections. Sometimes the "fix" is nothing more than "reflowing" the factory connections. Not so here with the Mirror Door Mac and its known capcaitor issues, but certainly applies elsewhere. It happens far more frequently than one might think that an expensive flat-panel TV or toehr gear fials for nothing more than a sloppy solder joint. So learn to recognize how they look or at least be aware. High-frequencies used in a circuit, like a Gigahertz Mac, have been known to actually crystallize a solder joint, kinda like how an opera singr can shatter a champagne glass. We don't see that here as a big issue, but it was a major fault in some earlier Macs and plenty of TVs and computer monitors with a tube-based display. Next up on the failure roster is bad caps! So these same techniques can be applied elsewhere and that's a lot of the fun in trouble-shooting. Reapplication of what you've learned elsewhere and it grows from there. For some of us, the "fixing" part is more fun than the using!
                        Stagger the work. If there's 30 joints to desolder, don't just work on up the line unless t moving quickly. It mught be better to do a few at one end and move to the other end for a spell, in order to avoid concentrating al your work in one small area with chance to coll down in-between. If you work a bit in one area, then move over a bit or waiting a bit before removing more solder, you can avoid overheating some particular part.
                        There's plenty of junk electronics to practice on to be found curbside or in your own garage. Work on some junk before the all-important Mac Resurrection Project. Time spent learning the proper way will smooth the real goal when you feel you're capable. You're not on the clock, so take your time and make it fun, instead of a high-pressure bound-to-fail March into the Unknown.
                        I did my MDD repair and all my other R&R adventures with that lowly Radio Shack desoldering bulb. Mine is the type that's permanently married to an iron. I first make sure the screw to the pencil iron's shaft is tight to the desoldering dealy. I find you need to tend to it like an old car-battery terminal to make sure it's getting maximum heat transfer. How soon after plugging it in before it melts some solder put on the tip is a good indicator of heat transfer.
                        It will heat a good-sized joint without help, but always try to get the tip positioned so it doesn't just suck air instead of solder. It helps to prime the tip or even add some fresh solder to the joint you're trying to clear. It seems counter-productive, but the added heat mass and conjoined flow actually hasten melting of the joint. The extra solder can help with making sure the hole in the tip isn't sucking air, as it will be surrounded with solder and thus make a good vacuum. A little additional assist from a prod or probe while the side of the tip's hole works the lead will help free the component's lead from the hole. You don't need to do much more than make sure the lead is free and clear such that yout can wiggle it a bit.
                        If it resists these attempts at freeing it, at least you get an idea which lead(s) might be sticking and will take additional work to remove the complicated heatsink assembly. After knowing that, I can take further steps, such as trying again, resoldering the hole only to reapply the desoldering tool to try for a better "suck," or I may use cautious prying, etc. while lifting the loose end of the assembly along with a well-positioned iron tip to the offending junctions. Practice makes...
                        It's kinda crude, but I often use the side of the hole of the tip itself as a sort of hook or pry to help get under bent-over leads and help get them straight enough to remove the part cleanly. Get the joint melted and try to snag the bent-over lead using the solder sucker's tip.
                        Get the holes cleared so you can wiggle them to prove they're freed up or at least reveal the ones that need more attention, don't waste time, allow time for a sip of beer or a smoke while an area recovers from your invasion and you'll make headway without unduly stressing the parts or circuit traces.
                        I browse the forums while the cooling occurs and sometimes I may only get a part or two swapped out i an evening. I'm easily distracted, LOL! But it wasn't a high-stress task to take it slow and easy that way, either, and I can take stock of things better by taking my time.
                        The only thing I try to do fast is to shorten the effective time the iron is on the board.
                        -Ed
                        Solder quick, then inspect. Move on.
                        • jasonsjwou
                          • Dec 2012
                          I fixed my G4 power supply by following these posts.
                          I replaced
                          the main cap (CapXon 390uf 420v) with Nichicon 390uf 450V
                          Q1 and Q2 (had hell of time re-inserting the thin leads of thermister on the heatsink)
                          Powers up, runs fine.
                          Thank you for all those who walked this path in the past.
                          • haroldblum
                            • Jan 2015
                            • 8
                            The TH2 on my power supply is blowing fuses and shooting sparks. It is green in color.. I don't know if that is because it is burnt and originally was blue. Does any one know what size it is and which way the lettering goes.
                            • haroldblum
                              • Jan 2015
                              • 8
                              I fund the lettering on the part
                              SCK
                              048
                              • haroldblum
                                • Jan 2015
                                • 8
                                SCK
                                048
                                Max. Approx.
                                Zero Power Steady Resistance Thermal Thermal Operating
                                Part No Resistance State at Max. Dissipation Time Temperature
                                at 25ºC Current Current Constant Constant (ºC)
                                (Ω) at 25ºC at 25ºC (mW/ºC) (Sec.)
                                (A) (mΩ)
                                SCK-1R38 1.3 8 64 21 59 -40~+200
                                SCK-1R58 1.5 8 62 21 66 -40~+200
                                SCK-2R58 2.5 8 75 20 63 -40~+200
                                SCK-037 3 7 91 21 73 -40~+200
                                SCK-046 4 6 117 20 62 -40~+200
                                SCK-048 4 8 87 27 76 -40~+200-------------------------------------------------
                                SCK-056 5 6 121 20 66 -40~+200
                                SCK-057 5 7 98 20 65 -40~+200
                                SCK-065 6 5 159 20 74 -40~+200
                                SCK-075 7 5 161 20 79 -40~+200
                                SCK-078 7 8 108 28 57 -40~+200
                                SCK-086 8 6 130 20 68 -40~+200
                                SCK-105 10 5 178 20 79 -40~+200
                                SCK-125 12 5 185 19 59 -40~+200
                                SCK-152 15 2 704 21 77 -40~+200
                                SCK-154 15 4 261 19 79 -40~+200
                                SCK-164 16 4 261 19 79 -40~+200
                                SCK-204 20 4 283 18 90 -40~+200
                                SCK-224 22 4 308 20 80 -40~+200
                                SCK-253 25 3 425 21 76 -40~+200
                                SCK-403 40 3 511 22 83 -40~+200
                                SCK-404 40 4 360 22 86 -40~+200
                                SCK-473 47 3 501 20 77 -40~+200
                                SCK-802X 80 2.5 693 19 71 -40~+200
                                SCK-1202 120 2 1010 19 65 -40~+200
                                • haroldblum
                                  • Jan 2015
                                  • 8
                                  [QUOTE=haroldblum;515716]
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    #97
                                    TH2 is a NTC type thermistor. Its job is to limit the inrush current of the PSU. It should be replaced with a new one after you replace switching transistors Q1 and Q2.
                                    Since the PSU blows fuses, then the switching transistors are almost certainly shorted. The thermistor burning is just a side effect from having a short up ahead, which puts very high current thru it. It goes in series with the circuit, so it cannot be the cause of blowing fuses.
                                    A working TV? How boring!
                                    • haroldblum
                                      • Jan 2015
                                      • 8
                                      SCK
                                      048
                                      SPECIFICATION
                                      Max. Approx.
                                      Zero Power Steady Resistance Thermal Thermal Operating Part No Resistance State at Max. Dissipation Time
                                      Temperature
                                      at 25ºC Current Current Constant Constant (ºC) (Ω) at 25ºC at 25ºC (mW/ºC) (Sec.)
                                      (A) (mΩ)
                                      DIMENSION
                                      Unit. mm
                                      Disc Ø D max. L. min. d. nor. P. nor. T. max.
                                      15 16.5 29 1.0±0.02 8±1.2 6
                                      V-I CHARACTERISTIC CURVE
                                      POWER DERATING CURVE
                                      R-T CHARACTERISTIC CURVE
                                      • haroldblum
                                        • Jan 2015
                                        • 8
                                        Thanks for the info I will replace Q1 and Q2 also
                                        By the way would you happen to know where I can find these parts?
                                        ntc thermistor sck-048 4ohms 8amps
                                        I will try looking up the transistors after I figure out how to get the nut and bolt off of them to de-solder
                                        Also the fuse size was 240v 8amps can I use 120v 8amps
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4953
                                          • New Zealand
                                          #100
                                          Check the bridge rectifier and filter capacitors for shorts too, use a series lightbulb when powering up for testing after you change parts
                                          -David VanHorn
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • sew333
                                            Restore on AC power - question. Power outage and pc not booted again. But in power co
                                            by sew333
                                            Hi my pc: 10850K stock 4800mhz
                                            2x16 GB DDR4 GSKILL 3000mhz XMP
                                            Seasonic Tx-850 Ultra Titanium
                                            Gigabyte Rtx 3090 Gaming ( 2x8pin,2 separate pcie cables )
                                            Asus Z490 Maximus
                                            1 TB SSD
                                            Hi . I have an question. 5 days ago i had momentary power outage for brief moment. When power back pc not booted itself. I just presset reset button to turn on pc.
                                            In bios i have option RESTORE ON AC POWER - ON.
                                            But when i cut power by pressing off BUTTON on power cord for second and then turning on pc booting itself...
                                            01-05-2022, 08:13 PM
