Power Supply 2273+3362 PSU in STBY
  • rigeback
    • Mar 2011
    • 421
    • Malta
    Got a PSU that I can't seem to find a manual for "Power Supply 2273+3362".
    5V and 12V is present and I PS/On bridged turned on the backlights although the led were flickering and could be culprit as the monitor has been idle for some time.
    D2 Diode has 12V on both sides which seems a bit strange?
    • 20795
    Re: PSU in STBY
    C910 and R901 solder joints look a little suspect. If you have an ESR meter check all the electrolytics
    • re-atari
      • Oct 2010
      • 136
      Re: Power Supply 2273+3362 PSU in STBY
      As do both solder joints on R930.
      • rigeback
        • Mar 2011
        • 421
        • Malta
        Re: PSU in STBY
        I don't have an ESR meter but I already changed out 3 caps that were swollen, I think the problem is in the low voltage switching or the led
        • R_J
          • Jun 2012
          • 9535
          If D2 voltage is 12v on both sides it because the led boost circuit is not working, likely cause is an open led in the backlight circuit. If the backlight is open, the circuit will go into over voltage protection and shut down.
          • rigeback
            • Mar 2011
            • 421
            • Malta
            Correct, bridging PS/ON indicates a power loss when the led strip is connected and will put the rest of the system in protection.
            I've removed the led strip and will consider ordering it.
            Thanks you all for the input.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
            • CMCM
              Russound CA4 Power Supply Repair
              by CMCM
              Hello Everybody,
              Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
              Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
              The outputs marked 12v and 20v are all measuring only 1v.
              The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
              The capacitors physically look clean (no bludgesor leaks) and...
              07-03-2025, 01:12 PM
