In changing memory module the "PWR S/W" (black and white wires) became disconnected from the board. The board is a Bestec ATX-250-12E in an eMachines T2893 tower. Can someone put me on a schematic for that board or just tell me where to reconnect the "PWR S/W connector
Bestec ATX-250
Re: Bestec ATX-250
Junk the PSU. The worstec ATX-250-12E has flaws in it's 5vsb rail, which causes it to fail after a few years, dilevering way over 5 volts and frying the motherboard.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
Re: Bestec ATX-250
Greetings, and welcome to the forum.
It sounds like you are describing the wires connecting the POWER switch on the case to the main printed circuit board inside the case. Is that correct? The Model number you gave, Bestec ATX-250 12E is the model number of the power supply, which is inside the metal box with that label on it.
That model power supply is very controversial. It has a serious design flaw, and with time is known to not only go bad, but also to burn out the main printed circuit board and other assessory components.
I do not have an emachines computer, but have worked on a number of Bestec power supplies. The Bestec ATX-250 12E cannot be trusted unless it has serious modification of the 5vsb circuit. I am sure some of the others can help you with the location where that Power switch wiring attaches to the main pc board.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
Re: Bestec ATX-250
Couldn't find much information on what your motherboard model is, but a few sites said it's an Intel D845GVSR (also under the name of SEABREEZE-T3). If you have the CD that came with your T2893, see if there's a motherboard manual in there. If not, here's the manual for the Intel D845GVSR (I suggest that you look at it closely in order to verify that you have the same motherboard).
Page 32 of the manual says pin 6 is the power switch, so I guess you'll want to connect the power switch on pins 6 and 8 (8 is ground).
Before you do anything, however, take everell's advice and replace the power supply. That particular Bestec is known to be problematic.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
