Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
How much power can a "35" transformer make?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    That new Rosewill Deer 350W has a "35" labeled transformer. (labeled as ERL-35-2005)
    I just noticed the HEC made Xigmatec NRP-PC502 500W psu also has a "35" labeled transformer (labeled as ERL-35-24) as seen in the second-down picture here: http://www.jonnyguru.com/modules.php...tory4&reid=158
    so can a "35" labeled transformer do 500w, as the HEC's obviously did.
  • linuxguru
    • Apr 2005
    • 1564
    Re: How much power can a "35" transformer make?
    Depends on the switching frequency, the max magnetic flux density that the ferrite can handle without excessive heating, and the engineering design margins. As a rule of the thumb, for commodity ferrite EI or EE transformers in a conventional half-bridge topology with BJT switchers (almost all PC PSUs), 35-size primary transformers can handle about 250..350W.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      So about 99% of the time they can only do 250-350W unless they are a special type of transformer?
      • linuxguru
        • Apr 2005
        • 1564
        Yes, for almost all commodity designs. It's possible to go higher with specialty ferrites, higher switching frequencies and MOSFET switchers, but you won't generally see those in PC PSUs, which are price-sensitive and use commodity parts where possible.
        • yanz
          • Nov 2004
          • 910
          that deer "35" transformer is a fake "35" transformer. it maybe just a "33" transformer.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            The one in the new one is an actual "35" transformer, but in the old deer I rebuilt a while back, that was a fake "35" just a relabeled 33.
            • yanz
              • Nov 2004
              • 910
              i see. i have a hec 300W (working) that has a "ERL-35" transformer, and it is taller about 1 cm(?) than the deer's.
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                The one in the new deer is about 1/4" taller than the "35" in my old deer.
                • learnmore
                  Help choosing replacement transformer for Levoit 600S SMPS
                  by learnmore
                  Hello Community,
                  I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                  Peace
                  LM...
                  11-04-2025, 09:35 AM
                • ohren
                  Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                  by ohren
                  Hello!
                  I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                  Measured voltages with no load:
                  After rectifier diodes
                  12V: 6.17 V
                  5V: 5.67 V
                  Secondary transformer pins AC measurement (really don't know if this says anything)
                  12V: 2-2.5 V
                  5V: 1.04 V
                  I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                  03-18-2023, 10:33 AM
                • mikey5791
                  Is it possible for transformer substitution?
                  by mikey5791
                  Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                  Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                  My questions are
                  1. How do i test to see if the transformer is in good working condition?
                  2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                  Hope you guys understand what i was asking. My intention is...
                  11-03-2022, 02:11 AM
                • dennis_elx33
                  3PHASE STEP-DOWN Transformer in Check
                  by dennis_elx33
                  Hello All,
                  i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                  Problem statement: Power tripped Off
                  Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                  Action Done:
                  1) Replaced the faulty parts with good spare.
                  2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                  12-02-2024, 06:52 AM
                • Boardview and Schematic Bot
                  ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                  This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 04:40 PM
