"Delta Power" MAX-500ATX 450W power supply (not real Delta)
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: "Delta Power" MAX-500ATX 450W power supply (not real Delta)
    Originally posted by i4004
    >Any more comments?
    it's peculiar to put godo components to these crap psus.
    nest up it'll blow the main switcher, then you swap that too.
    after that transformer will melt, will you fix that too?
    hehe...you get the point...
    what you did helps it somewhat, but only real help for it is garbage dumpster.
    See the thread about my yuelin, I covered all those points and more.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      yeah but if you cant trust it then whats the use?
      sigpic
      (Insert witty quote here)
      • i4004
        • Oct 2006
        • 2029
        #43
        but did you send it to jonny to stack it against simillar fsp model and then see what hapens on prolonged full-load?
        <wink>
        • JACKSON
          • Sep 2009
          #44
          Newbie2:
          I have this powersupply in my desktop for 1year and 9 monthes. The big coil between wiring bundle and heatsink (T90-XXXXX) has been black and short between wires. Can you please tell the p/n for this coil? I hope to replace it or I have to buy a new PS.
          This unit if very noising!
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Originally posted by JACKSON
            Newbie2:
            Good luck getting a new one. If you have another cheap power supply to take apart, try getting it out, BUT make sure you put the correct legs in the correct holes. Usually it is silkscreened underneath the coil.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #46
              Unless your power supply looks better than the one on the first page, I would recommend you get a new power supply. A burned coil could mean there is something seriously wrong with the power supply.
              I mean if you really really want to fix it for learning purposes, you can get a coil from another power supply like 370forlife said, or if you have copper wire you can rewind the coil. Keep in mind that any such modifications to the power supply can make it a fire hazard (especially if it's not working correctly in the first place).
              With that said, I still recommend you get a new power supply (and maybe keep this one for random spare parts if you like).
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                I'm sure sunpro would just jumperwire right through it...
                I think your right, it would just get a new power supply (a quality one, not another one of these works of art...) putting a in a new coil is pretty hard to do.
                • Newbie2
                  • Sep 2005
                  • 885
                  Sorry for reviving my old thread, but here are the voltage readings of this power supply from my Celeron 2.2GHz PC:
                  Multimeter voltage readings:
                  +12V: 12.21V
                  +5V: 5.16V
                  +3.3V: 3.43V
                  Motherboard voltage readings:
                  -12V: -11.62V
                  +5VSB: 5.10V
                  Also, the voltage readings were taken with the PC under 100% CPU load from Prime95.
                  My gaming PC:
                  AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                  ASUS M4A77TD AMD 770 AM3 Motherboard
                  PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                  G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                  TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                  WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                  ASUS Xonar DG 5.1 Channel PCI sound card
                  Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                  Antec Three Hundred Mid-Tower Case
                  Microsoft Windows 10 Pro 64-bit
                  Microsoft Windows 7 Ultimate SP1 64-bit
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    nice! thats good, considering the level of S*** that thing was!
                    sigpic
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      I've think sunpro is kind of the step up from their parent company, leadman. Not much of a step, but a step none the less.
                      Too bad most sunpro's are just rebranded leadman's now. At least leadman uses their "saftey series" power supplies with input filters and bridge rectifiers now. But their thermal fans cause the caps to blow up within a matter of hours.
                      • Newbie2
                        • Sep 2005
                        • 885
                        Today, due to curiosity, I actually hooked up this power supply very quickly to my main system, and surprisingly it powered up without any problems and booted into Windows. The voltage readings I took from my multimeter for this cheap power supply for the +12V and +5V rails were actually good, I think 12.23V and 5.15V at POST. A PCI-E power adapter to convert two 4-pin peripheral connectors to the 6-pin PCI-E power connector was used for my GeForce 9600GT video card.
                        Here are the specifications of my main system:
                        Intel Pentium Dual Core E2180 2.0GHz @ 3.006GHz, 1336MHz FSB (Socket 775)
                        8GB SUPER*TALENT T800UX4GC5 PC6400 DDR2-800 RAM (4x2GB in dual channel @ 802MHz, 2 kits installed)
                        GIGABYTE GA-P35-S3G motherboard
                        EVGA NVIDIA e-GeForce 9600GT 512MB DDR3 PCI-E 16x Superclocked video card
                        1TB WD Caviar Green 10EAVS SATA-II Hard Drive
                        Antec EarthWatts 80 PLUS 380W Power Supply
                        Microsoft Windows 7 Home Premium (OEM) x64
                        Antec New Solution NSK4480 Mini Tower case
                        My computer is now back on its Antec power supply, but now I know that this power supply could actually work as a backup PSU for it.
                        My gaming PC:
                        • Newbie2
                          • Sep 2005
                          • 885
                          For two months now, this Delta Power power supply has been powering this system, ever since its Enermax 300W power supply developed problems:
                          Intel Pentium 4 3.2GHz processor (Prescott, Socket 478)
                          1.5GB DDR RAM (1x512MB PC3200 and 1x1GB PC3200 mix 'n match, running at PC2700 speed)
                          PCCHIPS M955G motherboard
                          Sapphire ATI Radeon HD3650 512MB DDR2 AGP 8X video card
                          250GB WD Caviar PATA Hard Drive
                          Microsoft Windows 7 Ultimate x86 (32-bit)
                          The Enermax 300W that used to power this system somehow gave it stability issues, the PC would freeze when CoD4 or any other 3D intensive application was launched. Swapped out the power supplies with this rebuilt "450W" Delta Power, and it solved the issues.
                          All voltages are stable and the PC runs perfectly.
                          My gaming PC:
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            #53
                            Looking back at the initial pictures on page 1, I still get chills when I see this power supply (mostly because of the tiny heatsinks). But I guess you must have done a pretty good job with this PSU because running a 3.2GHz P4 for 2 months is not bad at all.
                            Check the 5vsb every once in a while, though (like once a month or something).
                            How's the heat output, by the way?
                              • 31071
                              tiny heatsinks are fine with a good fan,
                              you only need to be concerned if it has a stupid fanspeed crippler(controller)
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                Looking back at the initial pictures on page 1, I still get chills when I see this power supply (mostly because of the tiny heatsinks). But I guess you must have done a pretty good job with this PSU because running a 3.2GHz P4 for 2 months is not bad at all. Check the 5vsb every once in a while, though (like once a month or something). How's the heat output, by the way?
                                Concerns me too. I would up the capacity of the secondary rectifiers to ensure they don't blow and take out your hardware and to cut down on heat.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #56
                                  370forlife: I think Newbie2 did change the rectifiers. Each rail has 30A capacity, even the 12v rail. Should be enough for the P4.
                                  stj: I doubt those cheap PSUs have fan controllers (or cripplers as you call them ). I still prefer thicker heatsinks with a slightly slower fan, though.
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    I wouldn't call those heatsinks tiny. I've seen a lot of PSUs that run just fine with heatsinks with half the surface area of these.
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      I just realized there are no pi filters in this design. Does that mean lower-ESR caps can reduce ripple in this case?
                                      • Wizard
                                        • Mar 2008
                                        • 2296
                                        #59
                                        C-L-C filter (aka Pi filter) is best or build a small board with these if you are hobbyist with electronics otherwise look for another PSU with these.
                                        Cheers, Wizard
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          • Bulgaria
                                          #60
                                          It's no the size of surface area that worries me on this one but the base thickness. If the base is not thick enough, heat from the silicon parts most likely won't reach that surface area on top. Thicker heatsinks also have more capacity to absorb sudden changes in temperature.
                                          Been wondering the same thing. I have a strong feeling that this article might answer that question:
                                          https://cdn.badcaps-static.com/pdfs/...0a5b4a973d.pdf
