Voltage Regulators and Heat Issues
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Re: Voltage Regulators and Heat Issues
    Originally posted by redwire
    OK from your picture it's an Ali/fleabay piezo buzzer/beeper, which is a piezo-disc with built-in oscillator. It already has an inductor and 2SC1623-L6 transistor, two resistors inside. Attached pic is one I took apart.
    *So nothing can be done to make it much louder, you have to go bigger in size.
    Operating Voltage: 3-24VDC, 10mA, Frequency 3,900±500Hz, 95dB
    Drive Method: Drive Circuit Built in
    B072HRZXLG TMOEC piezo buzzer HYDZ2312
    You can also get just the piezo disc, some with two-wires or three-wires (needed for the self-oscillating type) and drive it with pulses from the Arduino. Junk smoke detector ones are best I find, for loud alarms because they have a huge disc.
    So i just now found out that with even 5 volts on it, it's loud as all hell!!!
    sigpic
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      OK so with this new revelation about the speaker only needing a much smaller dc voltage to make a very loud sound, i'm thinking a 12v regulator connected to the Arduino's Vin then power the sensor off the +5 pin on the Arduino, rely on internal VRef for sensor readings, then just hook that speaker to a digital out pin and bring it high if and when i need the alarm. That simplifies my design by a lot and simplicity breeds reliability!
      sigpic
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        That changes things now does it...
        I was playing with one of my piezo buzzers with built in oscillator and it was quite flaky, probably because it's cracked. But it was modulating kind of funny until I noticed I had my finger on and off the hole the sound comes out of the case...
          • Jul 2011
          • 6070
          Originally posted by EasyGoing1
          My question is ... is there anything I can do to lower the heat output from the regulator? I've got a decent heat sync on it (three times the size of the regulator itself) and the heat sync gets so hot that you can't touch it for more than a second or so ... I'm not OK with my project wasting energy like this.
          Thank You for any info you can offer,
          I use these boards before and they work very well and you do not need a heat sink on them
          http://www.futurlec.com/Mini_Power.shtml
          I know that the input for this chip is 12 volts and drop down 5 volts
          But the IC chip that is used comes in different flavors if I remember right there is a 15 volt version of it
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            It's surprising how loud these piezo buzzers can get... The flaky one I have is only a about 1cm in diameter.
            I have another piezo buzzer from an expired CO alarm with a 4cm piezo element. This necessarily is also really loud, but even that 1cm one is quite piercing.
            I have one apparently raw transducer that I never could get much volume from, makes me want to double check it's not got an oscillator in it.
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              Loved the story about unknowingly covering the audio output hole ... brilliant! lol
              I've noticed piezo's do really well when they can be fastened flat against any kind of hard material ... which will act as an amplifier for the sound waves. It's not uncommon to see just the disc secured to the chassis of some device ... the chassis at that point becomes a speaker... the technology is stupidly simple yet their application is vast and potent.
              sigpic
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                These buck converter ICs ... they all seem to claim that they switch at some frequency ... are these things PWM devices?
                sigpic
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8716
                  Yes, all switch mode power supplies use some sort of PWM to regulate.
                    Arduino Nano Controller with a 15 watt Laser hook up issues
                    This project that I am working on the Engraving Machine has been a challenge to make everything to work together
                    The information on the internet is hit and miss for the most part
                    It is a good thing that I know how and what it takes to hook up most micro controllers yes each model is a little bit different but for the most part they are the same
                    The BIGGEST problem has been the markings on these Arduino Nano Controller boards not all are the same some board are marked better than others
                    You see how I have to hook up the laser and Nano Controller...
                    09-13-2020, 04:37 PM
                  • yuii
                    ThinkPad W530 - faulty CPU regulators?
                    by yuii
                    Hello
                    I've got two W530 boards, one with K1000M and one with K2000M graphics card. The first one had an issue of turning off under heavy CPU load after about 30 minutes or in idle. GPU load wasn't causing it to shut down. Trying to turn it back on would only make the power LED to come up for about 2 seconds without fan spin or thinklight flash, and that's it. It also wasn't charging the battery after it died.
                    Gently pressing the laptop in left upper corner would fix this problem for a couple of days.
                    The latter is completely dead and has the same 2-second power blink, nevermind...
                    11-01-2023, 02:59 AM
                  • gretti
                    MSI Z370-A Pro, works but does not power off or reboot and USB issues
                    by gretti
                    I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                    The MSI BIOS included the ME firmware for the board. The size...
                    10-16-2025, 02:14 AM
                    Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                    The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                    Securing a good thermal interface between...
                    10-07-2024, 04:35 AM
                  • SoulFreeze
                    Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                    by SoulFreeze
                    Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                    After repairing the above issue, I realized the following remaining problem,
                    Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                    The computer recognizes headphones are connected and displays a popup in windows
                    Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                    06-21-2025, 09:53 AM
